Thread: Replace Passat Gear Lever Gaiter 52 Reg
  1. Replace Passat Gear Lever Gaiter 52 Reg
    Feb 2006
    Can any one advise how to remove the gear knob on the above vehicle I think it's the same set up as the Mk4 Golf? Thanks
    Mar 2006
    Whitehaven, Cumbria
    I replace the gaiter on My Passat last week. I bought the full gear knob and gaiter from VW.
    Unclip the gaiter at the bottom, the back comes out first. Lift the gaiter up as far as possible and you will see a metal clip. Using a small screw driver or long nosed pliers open the clip so the gear knob can be lifted off. Replace it with the new one using the pliers to squeeze the clip tight then clip the gaiter in at the front first then the back.
    Hope this helps.
  3. PASSAT GOLF ETC - CHANGE GEAR LEVER GAITER
    Feb 2006
    Thanks Chilly, I've already had a look at the job and that answers all my questions,it's on a friends car and I didn't want to proceed until I was sure. Thanks.
    Jun 2007
    I read in an earlier post that in order to seperate the gaiter from the gear knob you had to break the metal collar or clip.
    can the gaiter be seperated from the gear knob without breaking the collar or clip?
    thanks
  1. passat gear lever gator..
    By bigb1970 in forum Passat - Archive Topics
    Last Post: 23-01-2007, 04:01 PM
  2. Gear lever surround
    By Technical in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-01-2007, 09:33 PM
  3. Passat Gear Lever
    By Westfieldmatt in forum Passat - Archive Topics
    Last Post: 20-11-2006, 03:05 PM
  4. Passat Gear Lever Rattle
    By Percy in forum Passat - Archive Topics
    Last Post: 25-10-2006, 07:22 PM
  5. passat 130pd gear lever buzzes
    By c12weddi16 in forum Passat - Archive Topics
    Last Post: 08-10-2006, 11:10 PM
