Thread: Golf third gear crunching
Results 1 to 8 of 8
  1. Question Golf third gear crunching
    Does anyone know what may be the problem with my Golf (02) 130 bhp 1.9TDI. When revving engine and going from 2nd to third gear I get some crunching as if it wants to jump out of gear. It also happens from 4th to third sometimes again at high revs. It doesn't always happen though. Often when colder it doesn't.
    Is this a clutch problem, is it something to do with the engine - needs a tune? or more serious with the syncromesh on the gearbox - I've heard this is a weakness on the gearboxs?
    Any ideas really grateful.
    Rambo
    May 2007
    Quote Originally Posted by Rambo View Post
    Rambo
    hmm sounds like u've got worn synchros 2 me, i would try not 2 shift 2 quikly till i get this sorted,
  3. Gearbox crunching
    Thanks, but it's not the speed of change and I've just been out, engine warm and changed from 2nd to third high revs expected it to crunch and it didn't!
    So still confused.
    May 2007
    It would not matter how fast you changed if syncro was worn it would still grind. Changing slower may just help to preserved the teeth on the box. How many miles has i done?
    Mar 2007
    coventry
    id change the oil in the g-box no one ever does this so start here might not be enough oil
    but yes it sounds like a syncro has gone if so get this done asap it will only cost more in the long run
    at the mo you only have to change this syncro
    good luck and happy hunting
  6. Thumbs up Crunching
    Its done about 55000 miles. Is it easy/expensive to replace the synchro? As you say I'll start with the gearbox oil but will I be saving up for a new synchro for a long time?
    Mar 2007
    coventry
    firstly the syncro will have to be fixed by a garage or someone who knows what they are doing its nots left over when finished
    this is bad
    my golf tdi is on 215k the syncro has been going for over 2 years so i think i need a g-box
    the crunching is driving me crazy
    I think this may be happening to my mk3 golf, when changing gear and taking foot off the clutch she seems to crunch and judder directly underneith the gearstick.. is this expensive? I thought it may be the clutch going, thats Ł300 to get fixed around these parts.. but if its something else could it possibly less awful?
    Cheers guys,,
    ps: great forum.. big help!
  1. 1sr gear
    By davegilsenan in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 12-06-2007, 03:02 PM
  2. Gear jumps out and non smooth gear changes
    By RIZWAN180 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-06-2007, 09:45 AM
  3. Gear Changing Problem On Mk.3 Golf
    By mac500 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 09-02-2007, 09:02 PM
  4. VW Golf plus 06 gear lever vibration
    By bazza in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 01-12-2006, 10:21 AM
  5. V5 gear box
    By mastermind in forum Chat - Completely Off Topic
    Last Post: 10-04-2006, 03:28 PM
