Thread: Odd shudder
Results 1 to 10 of 13
  1. Odd shudder
    Apr 2010
    Ashford, Middlesex
    This afternoon when starting my car to come home from work, the car shuddered for a few seconds before settling to a normal idle - the whole car was shaking, as though the engine was running rough, although it sounded fine.
    Anything to be concerned about, or to check?
    Also, and probably completely unrelated, since then the fuel consumption has improved - I was getting high forties in London rush hour traffic this evening - even after being in nose to tail traffic for a while, it was still showing 43mpg when we arrived home.
    Lang may yer lum reek!
    Current: '09 Audi A4 Avant SE TDI (143)
    Previous: '56 VW Passat 2.0TDI SE - I survived 'BKP' ownership!
  2. Re: Odd shudder
    Mine's done that from time to time. I tend to put it down to cooler weather and me needing to give the glow plugs a proper chance to do their job; also my research on here has led me to believe it could be my DMF on the way out, but I reckon that's been on the way out for the past 60k miles, so I've stop worrying about it!
    Sometimes I've had a lumpy idle when sitting in traffic, no rhyme or reason to it and the car carries on just fine month after month, so unless it gets worse and becomes more of a problem I'd not fret too much!
  3. Re: Odd shudder
    DSG4ME Guest
    Do you mean it seems like the engine is falling out as you push the key to start it, and once running it's fine?
    Both my PD's have done it from time to time, it could be a mount, if the VW ones are the same as Skoda's they will leak a red dye near the mount if they are shot, other than that don't worry, I've noticed my misfire has gone as well, this has to be air density causing it.
  4. Re: Odd shudder
    Apr 2010
    Ashford, Middlesex
    It wasn't as it was turning over to start, but immediately after the engine had started. It only lasted a few seconds before settling down to its normal idle. Maybe I didn't give the glowplugs long enough to do their job - wouldn't be like me, but entirely possible.
    I think you could be onto something with the air density though - I've had a few cars over the years that would run better or worse depending on the weather etc. My Sierra was a particularly moody bugger, never awful, but on a nice cool, clear night would run like a dream. I am fast coming to the conclusion that the Passat is another moody car - yesterday it was running really well - smooth, quiet, good consumption etc, yet today its running like a box of bolts, and the consumption is worse by 7 to 10 mpg on the same journey as yesterday.
    Cars - definitely female.
  5. Re: Odd shudder
    Dec 2009
    14 Post(s)
    Quote Originally Posted by fat controller View Post
    Yes i think you could be right . The thing with the fuel consumption is the crap weather heater on lights etc... that will knock your mpg. As for running like a box of bolts. Not had that one yet
  6. Re: Odd shudder
    Apr 2010
    Ashford, Middlesex
    Quote Originally Posted by rapport25 View Post
    Its hard to describe what I mean by that - not doing anything of note, but just not running 'right'.
    I do worry sometimes that I seem to have a bit of sensitivity to vehicles and how they are running, yet I have only very limited mechanical knowledge to work from. I am known at work as one of the people that can take a vehicle out and decide if it is right or not, and the engineers tend to use me sometimes to get an honest description of a fault.
    The downside of that is that I worry about my own vehicles little 'off-days' (not helped by reading about faults on forums )
  7. Re: Odd shudder
    Can't say I've ever noticed any difference in the way mine runs, whether the engine is cold/hot or whatever the weather is outside.
    The only thing was that last winter when the car was cold, when moving off the clutch would tend to bite suddenly rather than engage progressively, and that might have been down to wear and/or the cold winter, so I await this year's cold weather with interest (or perhaps trepidation!).
    Also, I sometimes hear a bit of noise at idle, which is presuably clutch-related because it disappears/changes when I depress the pedal, but since it's not too intrusive I've just ignored it, on the assumption that if it's normal wear and/or the DMF then I'll get a bit more noise as a warning before it's about to go.
    The only other thing is a very occassional random shudder/rough idle, but I haven't really noticed that so much as the car has reached the higher mileages.
    Oh, and it rattles a bit for a second or two after starting from stone cold, but so have all the other high mileage cars I've owned
    06 Passat 2.0 TDi 140 SE Estate, Reflex Silver, 125,000 miles
  8. Re: Odd shudder
    Mar 2008
    7-10mpg? You definitely have a problem.
    Heater, lights etc make a very slight difference to mpg. What makes far more of a difference is the weather - colder weather makes it worse (although not sure why on a diesel); rain on the roads also makes a big difference; wind obviously; and winter diesel between Nov-April ish has a lower cetane rating so also makes a difference.
    However all those things would only reduce your mpg by 5 at most. To lose 10mpg from one day to another is drastic. There is something wrong with your car - do you have a flat tyre?
    Also mine's perfectly consistent whatever the weather or temperature. YOUR car is moody, they shouldn't be.
  9. Re: Odd shudder
    Apr 2010
    Ashford, Middlesex
    Tyres all good, molgrips, and apart from a misfire (see other thread) the other day, its been fine since - even consumption seems settled at the moment.
  10. Re: Odd shudder
    Merseyside
    I don't think i've ever owned a car that feels like it drives the same every day. Some times my car feels ultra smooth (including the engine, ride, steering & transmission), other times it just feels slightly courser in the way it drives although it still runs well. I think it may be influenced by the mood of the driver! I always find it runs especially well on early morning starts - I know this is caused by the cold denser air with regards to the engine but i'm not sure how it can effect the suspension as the ride always seems smoother.
  1. Anti Shudder Valve shutting down engine
    By Davob in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-09-2010, 10:00 PM
  2. 1.2 E (55) with odd tickover
    By SteveX in forum Polo - Derby - Lupo - Fox
    Last Post: 22-08-2010, 01:56 AM
  3. Please Help sudden shudder and loss of power.
    By con1981 in forum Bora - 1998 - 2005
    Last Post: 29-10-2009, 06:35 PM
  4. Odd Stumble at idle up to 2k 2001 tdi (America)
    By Edjet in forum Chat - Anything with wheels
    Last Post: 22-03-2008, 06:51 PM
  5. A4 Avant '99 Shudder through the car at 60-65
    By radiojuan in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-05-2007, 06:44 PM
