Thread: This could be a bit of a blonde moment but....
  1. This could be a bit of a blonde moment but....
    May 2007
    Little Houghton, Barnsley, United Kingdom, United Kingdom
    I dont know if this is just me being simple (most likly) or what but
    My mk4 golf is need a new offside track rod arm, just been on Europarts and found the part i need but it lists them as LH RH....does this stand for left and right hand? and if so which round is coming from, lookings towards the vehicle or when inside? dont laugh....
  2. Re: This could be a bit of a blonde moment but....
    1840 Post(s)
    Offside is right hand side which is RH.
  3. Re: This could be a bit of a blonde moment but....
    May 2007
  4. Re: This could be a bit of a blonde moment but....
    Pembrokeshire
    22 Post(s)
    suprising how confusing this can be, especially when you stand in front of your car. now, which side is your steering wheel on? correct, the right hand side, because its not a left hand drive. so the right hand side is as viewed facing the rear of the car, and is also known as the offside. the left side, where your passenger sits is known as the nearside, because its near the side of the road. this only applies when a car is driven on the left hand side of the road, so is confusing to yanks, and blondes. sorry if my explanation sounds very patronising at all to you, as its only meant to sound slightly patronising .
    damn that crasher, got there before me.
  5. Re: This could be a bit of a blonde moment but....
    May 2007
    that was on of them 'ahhhh i see' moments! i knew which side was on or off side...but yeah kinda blonde moment
  6. Re: This could be a bit of a blonde moment but....
    Sep 2010
    Preston
    did you notice zollaf error - he said right hand when facing the rear of car - it should be when facing front. simply understood is right hand is drivers side in a right hand drive car. left hand is nearest the kerb in UK
  7. Re: This could be a bit of a blonde moment but....
    1840 Post(s)
    The handing of a cars part location is always viewed as sitting in the seat looking forward. I had a “discussion” one Christmas (too much alcohol) with my family where they insisted that the handing of a part changed depending on how you look at it, which I strongly disagree with. As I said to them, if I did that it would cause immense confusion when it came to ordering parts as ETKA define the left and right as not changing which to me is common sense.
  1. 2003 Polo, changing headlight bulb.
    By nedflanders in forum Polo - Derby - Lupo - Fox
    Last Post: 14-01-2018, 10:35 PM
  2. Gear Selection (Bit Of An Odd One)
    By lc25 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-08-2010, 06:03 PM
  3. Ooo bit windy! So noise and stability?!!
    By Robbus in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-05-2009, 07:38 PM
  4. VWAF Joke Thread
    By auiron in forum Chat - Completely Off Topic
    Last Post: 17-04-2009, 12:18 AM
  5. A little bit of Veyron for all!?!?!?
    By elPaulio in forum Golf MK5 - 2004 - 2009
    Last Post: 21-06-2008, 07:19 PM
