Thread: overcome the deadlock on the rear doors
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 45
  1. Re: overcome the deadlock on the rear doors
    Aug 2013
    Brixham
    Had the locked back door problem for over 4 months but now solved the same way with the engine running and using the Driver's unlock button.
    Many thanks to Fumbler and jfj for the pointer.
    I have now dis-connected the plug at the door pillar so the it stays unlocked until I have the time to service/replace the lock.
    (A very happy) Pete
  2. Re: overcome the deadlock on the rear doors
    Jun 2008
    Is there any preventative maintenance that can be done before this issue occurs?
    thanks
    D
  3. Re: overcome the deadlock on the rear doors
    Gwent
    It is worth peeling back the gaiter at the front of the door and cleaning/greasing the multiplug terminals, make sure the gaiter is refitted properly.
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  4. Re: overcome the deadlock on the rear doors
    Sep 2008
    Just replaced the O/S/R door lock on my Passat B5.5. Door deadlocked, tried every trick in the book to open it, but to no avail. The internal lock mechanism had broken up inside, so manually operating the levers had no effect. Ended up busting off the old lock to get access to the release latch. The most awkward bit was reconnecting the short cable from the external handle ratchet to the lock, there is a [torx] screw hiding behind the rubber door seal to allow removal of part of the door handle, this gives access to this cable. New lock £45:00 of e-bay, and thick end of a days work [my own time]. Conclusion: At the first sign of a door lock playing up, get a fix ASAP while you can still open the door. Grateful for all the advice on here.
  5. Re: overcome the deadlock on the rear doors
    Nov 2006
    9931stevem is a genius! Followed his instructions 2003 Passat Door won't unlock or open.pdf and (to my huge relief) the door opened!! Mine was the fns door not the rear, but the principle's the same. There are so many posts on this site about door lock problems, but this is The One!
  6. Re: overcome the deadlock on the rear doors
    Apr 2014
    Sevenoaks
    Thanks for the previous posts. I ordered a set of splines, £16.40 on Amazon.
    Banging on the car door and pressing the remote open button did not work.
    Banging on the car door whilst swmbo reved the engine to 2000 rpm and kept pressing the driver's door open button did not work.
    But then "Banging on the car door whilst swmbo reved the engine to 2000 rpm and kept pressing the driver's door button open, close, open close ..." performed the required magic :-) :-) :-)
    Disconnecting the door electrics at the hinge stops the door lock motor from locking again. The door can be locked manually by pressing down on the door button and opened by pulling the interior handle.
    I now just have to take the door lock motor off as described in the Haynes manual and in the above PDF file.
  7. Re: overcome the deadlock on the rear doors
    #17
    Gwent
    I recently fixed my nsr door, it opened for the first time in 8 months, so I had a crack at it. I found 2 of the thinner wires had a 'kink' this turned out to be broken cores under the insulation. Also I noticed for the first time, that the gaiter fits to a 'hoop' which is detatchable from the pillar, much easier to thread the gaiter to the hoop then click it back in!
  8. Re: overcome the deadlock on the rear doors
    #18
    Apr 2014
    Sevenoaks
    I was able to thread the door pillar plugs through the tube back into the body of the car. This enabled me to remove the window motor and door lock carrier with all the wiring attached.
    Having taken the lock apart, I decided to order a replacement from ebay for £20 as it is difficult to know which part was causing the problem. Since then I have managed to take the motor apart and found some dirt by the commutator so this could well have been the cause of my problem.
    To separate the motor housing from the lock mechanism only the small T8 screw and the large T20 screw need to be removed. The 8 T10 screws can be left in place. There is a spring that has to be removed and two clips by the T8 screw that have to be released.
  9. Re: overcome the deadlock on the rear doors
    #19
    May 2008
    Chiltons, above Marlow
    Considering these are older cars, not that attractive to thieving swine, do we really need deadlocked doors? As I understand it the locking and the whirring deadlocking are separate actions, what if, as a preventative to the hassle of failure, the deadlock bit was disabled?
  10. Re: overcome the deadlock on the rear doors
    #20
    Apr 2014
    Sevenoaks
    My replacement lock from ebay eventually arrived and I have fitted it to the car. It works fine now that I have also replaced the battery.
  1. Audi steps up the pace with even more extreme 560ps r8 gt
    Last Post: 05-06-2010, 07:24 PM
  2. Rear Doors
    By Borab0y in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-06-2009, 09:59 PM
  3. Question Golf Mk4 GT TDI Rear Wheel Bearing
    By tommi in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2009, 08:21 PM
  4. A6 Stereo problem/question. please help!!!
    By djneils98 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-03-2007, 01:22 PM
  5. Option Codes
    By Samcat in forum Passat - Archive Topics
    Last Post: 23-11-2006, 11:25 AM
