Thread: A8 D3 MMI Screen Opening Problem..Need Help!
Results 11 to 20 of 29
  1. Re: A8 D3 MMI Screen Opening Problem..Need Help!
    Aug 2009
    Chorley UK
    Thanks Saf,
    Will have a look around, mine has blue tooth, touch wood all is OK in that area, just had to put the pin in once when I got the car.
    Philip
  2. Re: A8 D3 MMI Screen Opening Problem..Need Help!
    Sep 2012
    United Kingdom
    does anyone have a step by step instruction to remove the MMi
  3. Re: A8 D3 MMI Screen Opening Problem..Need Help!
    46 Post(s)
    Quote Originally Posted by mantes View Post
    which part? the whole lot or seperate parts?
  4. Re: A8 D3 MMI Screen Opening Problem..Need Help!
    Sep 2012
    United Kingdom
    the whole lot what to take off on the dashboard on the A8
  5. Re: A8 D3 MMI Screen Opening Problem..Need Help!
    46 Post(s)
    which part? there are many components to the mmi system
  6. Re: A8 D3 MMI Screen Opening Problem..Need Help!
    Sep 2012
    United Kingdom
    i need to replace the mmi mechanism which is getting stuck and not working properly when opening so i have bought a new mechanism for it so i need instructions of how to open the dashboard mountings to remove the mmi to replace it with a new mmi mechansim
  7. Re: A8 D3 MMI Screen Opening Problem..Need Help!
    #17
    Jun 2012
    Bristol, UK
    I just replaced mine (found a supplier with the gear) and found the job okay to do (just a bit awkward changing the gear). I do know of someone who will replace the gear if you send them the complete unit for repair. Saved me £250!
  8. Re: A8 D3 MMI Screen Opening Problem..Need Help!
    #18
    Oct 2012
    London
    Hi Mantes. I had searched the net previously and found some useful instruction on doing this.....I have the PDF Document with pics, but not able to upload here (size restriction) so PM me with contact details and happy to email directly to you if you still need help and have not resolved this. Hope this helps you.
  9. Re: A8 D3 MMI Screen Opening Problem..Need Help!
    #19
    Jan 2013
    Ireland
    Hi Happydan, can you send me a copy too (PM me) , I am a new member and cannot send PMs yet :-)
  10. Re: A8 D3 MMI Screen Opening Problem..Need Help!
    #20
    Jan 2013
    Ireland
    OK , I just found this document that helps but if someone has something better please let me know: http://www.audipages.com/Tech_Articl..._remove_D3.pdf
  1. Screen Washer Problem
    By mikehbs in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-12-2010, 09:54 PM
  2. Please Help Q7 MMI High Aux in Problem
    By alsblade in forum In Car Entertainment
    Last Post: 26-04-2010, 03:29 PM
  3. MMI Problem after update
    By dragondownsouth in forum In Car Entertainment
    Last Post: 17-04-2010, 01:43 PM
  4. Please Help 1999 Audi A8 - possible electrical/battery problem
    By Rusch Moore in forum A8 - S8 - V8
    Last Post: 21-05-2009, 05:27 PM
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
