Thread: Felicia 1.3 MPI
  1. Felicia 1.3 MPI
    May 2007
    The Felicia 1.3 MPI engine has two variants, the 135 MPI and 136 MPI. What is the difference between the two? Is it just the kW/BHP using a different ECU? If I have a 135 MPI, can I upgrade it to a 136 MPI simply by changing the ECU?
  2. Re: Felicia 1.3 MPI
    1835 Post(s)
    The 135 and 136 engines are different in that the 136 has higher compression pistons and a different head and cam.
  3. Re: Felicia 1.3 MPI
    May 2007
    Ah. a little more than a quick re-chip then! What else can I do to the sluggish 135 to improve performance a bit :-) Thanks Crasher
  4. Re: Felicia 1.3 MPI
    1835 Post(s)
    Fit the 1.6 AEE engine.
  1. Question seat ibiza 1.4 mpi 2001 "misfire" changed and checked loads
    By barnstormer in forum Ibiza - Cordoba
    Last Post: 28-03-2010, 01:46 PM
  2. Question skoda felicia timeline
    By volvorsport in forum Other Models
    Last Post: 06-12-2009, 03:55 PM
  3. Please Help Felicia 1.3 LX Wiring diagram
    By jon_iz in forum Other Models
    Last Post: 10-04-2009, 07:30 PM
  4. Felicia 1997 1.3 LXi (MPI) - Tappet Noise
    By BugBit in forum Other Models
    Last Post: 21-10-2008, 10:38 PM
  5. 1990 Mk 2 Golf 1.3 Gearbox probs
    By radcliffe in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-03-2007, 12:23 PM
