Thread: Audi Headlight Beam Adjustment motors
  1. Audi Headlight Beam Adjustment motors
    sagarh Guest
    I have an A6 that has a on one side a motor in the headlight, which allows me to vary the beam level from within the cockpit. The others side (drivers side) does not, it is a newer headlight, I can tell because the lens on it is very clear in comparison to the other side.
    I am thinking that it has been replaced due to whatever reasons most probably an accident repair but I need obviously to fix the issue with only one side being able to adjust the beam level - its not great...
    So now onto my question, can I just jet a motor and install it into the headlight or is it a case of having to buy a complete new headlight unit with a motorised levelling system?
    Any help greatly appreciated!!
  2. Re: Audi Headlight Beam Adjustment motors
    Sep 2008
    chester
    17 Post(s)
    Not sure if you can modify the existing headlight but I would of thought its not worth the hassle,get the right one from a breakers then sell the other one.
  3. Re: Audi Headlight Beam Adjustment motors
    sagarh Guest
    Thanks for the reply - the breakers I tried was selling the servo motor for the adjustment sepratley... and he was not to keen to help me identify if I just needed the motor or the headlight as well as the motor....(will not be seeing him again!)
    I will see if Audi are more helpfull.
    Thanks!
  4. Re: Audi Headlight Beam Adjustment motors
    Sep 2008
    chester
    17 Post(s)
    If your buying a new one go to europarts or gsf somewhere that stocks Valeo headlights, Audi is mega bucks
  1. Audi a1 e-tron – zero-emissions in the city
    Last Post: 02-03-2010, 07:54 PM
  2. The Audi e-tron
    Last Post: 02-10-2009, 07:30 AM
  3. Audi set for 12th record-breaking year in a row
    Last Post: 31-07-2007, 08:34 PM
  4. How does the Quattro system work?
  5. Audi Cross Coupé quattro - The compact performance SUV
    Last Post: 21-04-2007, 05:41 PM
