Hi all. Recently purchased a recon garrett, I got my local indi vw garage to remove old unit an refit new using old ( but cleaned) pipes. Since then I have had a oil leak yet all bolts are tight. It's been back to turbo place an was informed it's perfect. Question, can or does the actual housing leak oil where it's bolted together?
Next task is to replace both feed and return pipes but don't think this is the issue.
Tryin to source a braided hose for the feed pipe but looks like it's not gunna happen.
does any1 have any suggestions as I really don't want to take the thing off again, such a pain in the a$$.
