Thread: Rear window
  1. Rear window
    Jul 2010
    Brighton
    can someone tell me how the rear window glass is attached to the runner in the door, my glass is loose won't go down but will come back up via the motor, i know there is a plastic bracket the window sits on like this http://cgi.ebay.co.uk/Volkswagen-Pas...item27b4913843
    but how does it hold the glass?? is there a pin or something for the hole
    Tia
  2. Re: Rear window
    Norfolk
    Pin and a bush go through the holes in the glass. If one falls out the window twists slightly and jams in place. Door card off to check. Door armour has two holes to look through to check pin and remove/replace.
  3. Re: Rear window
    Jul 2010
    Brighton
    i think the pin and/or bush must of dropped out because the glass is completely disconnected from the bracket
    can you just buy the pin and bush or is it a complete replacement?
  4. Re: Rear window
    Apr 2009
    You can get them separate, but they are
    probably hiding in the bottom of the door,
    after coming loose.
    Regards
    Jim
  5. Re: Rear window
    Jul 2010
    Brighton
    ok thanks, i'll whip the panel off tomorrow and have a look to see if i can find them
  1. Audi plays the long game with latest a8 saloon
    Last Post: 02-05-2010, 05:16 PM
  2. Please Help Mk3 Gti - Loose rear passenger window
    By aris in forum Golf MK3 - 1993 - 1999
    Last Post: 19-04-2010, 08:54 AM
  3. Rear window washer
    By makemineamythos in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-03-2010, 08:56 PM
  4. Passenger (rear) window stuck.
    By Trillock in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-03-2010, 07:45 PM
  5. Lamborghini gallardo lp 570-4 superleggera
    Last Post: 02-03-2010, 08:17 PM
