Thread: Replace waterpump along with cambelt?
  1. Replace waterpump along with cambelt?
    Dec 2006
    Oxford
    Getting my cambelt replaced on Monday (1997 1.9 TDi on 120,000 miles), I've asked for all the tensioners to be replaced along with the cambelt also. Mentioned it to a mate today, he said I ought to replace the waterpump at the same time as it acts as a tensioner in it's own right?
    Anyone able to confirm this please?
  2. Re: Replace waterpump along with cambelt?
    Chipped2 Guest
    Yes, replace waterpump at 120k. The reason is that it is driven by the cambelt which will have to be removed again if the waterpump fails during the next 60k.
    You should only be charged for the waterpump and new antifreeze as you are already paying for most of the preparatory work to be done.
    Also replace the Auxilliary belt and the Power Steering belt as there is no point in refitting the old belts. (approx Ł20)
    At the next cambelt change at 180k it is a good idea to have the Al;ternator freewheeling pulley replaced as these can partially seize throwing off the belt and snapping it.
    Use VW parts as they are very reasonably priced, guaranteed to fit and often cheaper that aftermarket belts etc.
  3. Re: Replace waterpump along with cambelt?
    Dec 2006
    Oxford
    Thanks for the comprehensive answer, I'll get the waterpump & extra belts changed at the same time. Thanks again.
  4. Re: Replace waterpump along with cambelt?
    Aug 2007
    The waterpump is not driven by the cambelt (timing belt).
    The cambelt drives the balancer shaft, diesel pump and camshaft.
    The coolant pump is driven by the auxiliary belt.
  5. Re: Replace waterpump along with cambelt?
    Apr 2009
    With both types of engine, early and late,
    it is good practice to replace the water pump.
    Regards
    Jim
  1. Failed cambelt can be costly
    Last Post: 23-08-2010, 01:06 AM
  2. Failed cambelt can be costly
    Last Post: 22-08-2010, 01:02 PM
  3. Question Waterpump and cambelt
    By mark- in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-04-2010, 02:23 PM
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
  5. cambelt questions
    By tdi_geezer in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-03-2008, 02:01 PM
