Thread: where is crankshaft position sensor?
  1. where is crankshaft position sensor?
    Dec 2007
    I am getting an intermittent crankshaft position sensor fault showing on VCDS 10.8. I want to replace it before it fails completely but need to know where it is and if it goes inside , will any fluids leak out?
    The engine is a petrol AZM with LPG conversion.
    thanks
  2. Re: where is crankshaft position sensor?
    Apr 2009
    If it's the "engine speed sensor", it goes into the
    engine block down behind the oil filter/cooler, near
    the bell-housing.
    No oil should escape.
    If your a Dentist or Gynaecologist....... you wont have
    to remove the oil filter and cooler
    Regards
    Jim
  1. Replies: 21
    Last Post: 04-07-2012, 10:32 PM
  2. ABS Sensor: ABSolute pain!
    By tornadored7 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-11-2009, 04:04 PM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
  5. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
