Thread: Aircon/blower problems
Results 1 to 10 of 12
  1. Aircon/blower problems
    Jul 2010
    Gillingham
    Hi guys i have a 1996 b5 a4 2.6 v6 and have the following problem with the aircon/blowers
    Display very temperamental(no display most of the time).
    very weak blow on blowers with it set to max(checked fuse 40 no joy).
    can hear compressor tryin to kick in but gives up after minute or so.
    i have checked if there is any loose connections at rear of unit but all seems fine would replacing the unit be of help or is there something that my thick head isnt seeing????
    please help.
    A4 2.6 (1997) not very well
  2. Re: Aircon/blower problems
    Oct 2009
    buckingham, buckinghamshire
    sound like you climate control unit, the display gives up usualy due to dry joints in the curcuit board , mine did this and i replaced it with one off fleabay.
    you must make sure the all the numbers on the new unit match the ones on your old one or it wont switch the aircon on, even though everything else seems to work ..( i found this out by buying the wrong one )
    the aircon compressor will shut down if the gas pressure is too low, its to protect the compressor etc. has it been gassed up this year?
    the fan running slow could be the control unit, or the bushes in the fan motor.
    Audi A6 2.8 quattro avant.... as dead as a dead thing now
    now messing about in a mk4 2.0 golf gti..
    thats gone...now into an 03 passat 2.0 sport
  3. Re: Aircon/blower problems
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Check pollen Filter also.
    Alan.
    VW T6 150 DSG Camper £££
  4. Re: Aircon/blower problems
    Jul 2010
    Gillingham
    thank you guys i gonna see if i can source a replacement will let yas know
  5. Re: Aircon/blower problems
    May 2010
    essex
    i had the same problem with my c/c interface, got used one from local breakers £20 and solved the problem :-)
  6. Re: Aircon/blower problems
    Jul 2010
    Gillingham
    thanks for all ur comments i found a repair solution where i resoldered the pcb and the control unit now working but the blowers still not working does the fact it needs regassing affect the blowers ???
  7. Re: Aircon/blower problems
    Nov 2008
    20 Post(s)
    I wouldn`t have thought so, it should run regardless.
    Alan.
  8. Re: Aircon/blower problems
    Jul 2010
    Gillingham
    i thought the same alan but u never know with the germans lmao
  9. Re: Aircon/blower problems
    Feb 2010
    Plymouth
    My blower is dieing on me as well.
    Clicking at slow speed or dead.
    Like stevie said, i'd check the bushes out on the motor. I read you can buy new ones on ebay. I'm going to try that first. cheaper option.
    The fan will work regardless of AC. I've had no AC pump for about 6months and before this week my blowers was working fine.
  10. Re: Aircon/blower problems
    Feb 2010
    Plymouth
    I stripped my blower down this afternoon and checked the bushes out.
    Mine are almost warn out but my motor is self where the bushes make contact, has really bad scoring. So need to replace that as well i think.
    here is a couple of pics.
  1. Are there problems with Crafters?
    By goli in forum The Commercial Range
    Last Post: 16-03-2011, 08:21 AM
  2. Problems with VW Transporter Camper
    By eric_peterhead in forum The Classic VW's
    Last Post: 19-03-2008, 04:42 PM
  3. Replies: 22
    Last Post: 08-03-2008, 08:16 PM
  4. Starting Problems
    By blergo in forum Golf MK3 - 1993 - 1999
    Last Post: 26-02-2008, 07:00 PM
  5. Eos water problems
    By ginger in forum Eos
    Last Post: 23-03-2007, 06:38 PM
