Thread: Retrofitting cruise control to A4 quattro - possibly the best thread on this subject covering all issues from the basic to the complex.
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 67
  1. Retrofitting cruise control to A4 quattro - possibly the best thread on this subject covering all issues from the basic to the complex.
    May 2010
    caldicot UK
    Hey all!
    I've had a quote of £165 from Euro Performance Ltd (Audi Indy) in South Wales to retrofit cruise control to my A4 quattro. Is this a good quote? I called Audi in Cardiff and they are selling the kit (excluding fitting) for around £195+VAT. Seems like the indy is supplying and fitting all the kit a lot less than i can buy from audi direct!
    Will the indy make any profit from that job? Just thinking the quote sounds too good to be true!
    many thanks in advance!
  2. Re: retrofitting cruise control to A4 quattro
    Nov 2008
    Quote Originally Posted by gareths quattro View Post
    Hey all!
    I assume your talking about a B7 A4 quattro? (Can't find your vehicle info anywhere -so I am assuming this - as its a B7 forum )
    Does your vehicle have either steering wheel controls? (radio etc) or tiptronic paddles on the back of the steering wheel?
    If yes to either you should have already the latest switch control ecu, and all you will need is the Audi retrofit kit (8e0054690 -I think?) which is about £35 +vat and a different lower steering cowl (with extra cut-out for the switch ), which is about £25+vat.
    You can even go cheaper by not purchasing the kit and buying just the switch itself (4E0 953 521 B 4PK) which is about £25 + vat. The only difference being the kit contains fitting instructions and an unnecessary loom that is only required for the A6.
    If in doubt about your switch module you should -if possible- interogate the the switch module electronically via the onboard diagnostic port. (vag-com etc.) The part number displayed for the module should be 8E0 953 549 R. If you have any other version - P or even S - you'll need to (probably) buy a new module at about £125 + vat.
    I think this is what your dealer is quoting for.
    2006 A4 saloon 2.0T S-Line Special Edition.
    Mauritius Blue - Xenons, Bose, Heated Valcona, Cruise, Colour DIS, Ipod, Revo. Big Smile.
  3. Re: retrofitting cruise control to A4 quattro
    May 2007
    knee deep in clunge
    14 Post(s)
    R & Q support cruise
    If you have multi function steering wheel then you only need the cruise switch £25 and the lower cowling £25 then the labour to fit and code
    2 0 0
  4. Re: retrofitting cruise control to A4 quattro
    Coventry
    Would instructions help??
    These are what came with the kit that A8 fitted for me.
    2 0 0
  5. Re: retrofitting cruise control to A4 quattro
    May 2010
    caldicot UK
    Thanks guys for all the replies!
    I'm not quite sure what the difference is between the numbers... B7, b6, etc. Does that correspond to a year, or does B7 cover a few years? I only got my new A4 quattrro on wednesday night! (not brand new)
    My new car is an 2006 A4 2.0T FSI Quattro S Line Special Edition 220bhp - slightly longer title than my previous car... volvo s60 D5 SE! I love the car! Slightly nervous of the reduced mpg, but i guess i can't worry too much about that!
    There are a few buttons on the steering wheel... two scrolling buttons on either side (next / previous track & volume). There's also two other buttons (mode?) and cant remember the other one... they just say no function when i click them.
    That seems quite cheap for the retrofit kit! So do you get the stalk in that kit? And does that include any relays / wiring? I assume the kit contains everything required.
    If i just buy the switch for £25+vat where does the switch mount? Is it a stalk (similar to the indicator stalk) or is it a small box switch that you stick to the dash?
    Cheers for the info Lateknight! That vag-com software... can i buy that fairly cheap off the net and does it come with a lead to connect a laptop, or is it a magic box with a plug to plug into the on board computer? Apologies for not knowing my stuff on the audi, but i've only had it 2 days!
    Cheers A8 Tech! I'll give audi another call tomorrow (or monday if they're closed on weekends) and maybe order the parts.
    And cheers Ben for the instructions! I'll check those out now!!
    It's nice to see that people are so helpful on this website! Looking forward to some interesting discussions as time goes on!
    cheers guys!
  6. Re: retrofitting cruise control to A4 quattro
    May 2010
    caldicot UK
    Dan... many thanks for your PM. I tried to PM you back, but it said because I havent got enough posts yet I can't PM you! It deleted my message as well after I typed a lengthy reply! Agghh!
    Many thanks for your PM Dan. Just wondering how far you are from South Wales. I work in Bristol if that would be easier. And obviously you'll want to cover at least expenses, how much would you charge to install?
    As you've recently fitted it yourself, did you only buy a switch / stalk and the new cover with the larger cutout?
    And the vagcom... was that expensive? Just wondering if its worth me getting that so i can read fault codes / change settings, etc. Not sure if it's a handheld device with a plug to plug into the car, or is it software to go on a laptop?
    cheers!
  7. Re: retrofitting cruise control to A4 quattro
    May 2010
    caldicot UK
    One other question... does the stalk replace the indicator stalk, or, will i have an additional stalk?
    cheers
  8. Re: retrofitting cruise control to A4 quattro
    May 2008
    It doesnt replace it, you'll have an extra stalk underneath the indicator one.
  9. Re: retrofitting cruise control to A4 quattro
    Nov 2008
    cheers
    Its additional to the other stalks on the column.
    Nearly forgot - you'll also need 2 screws N90906802 (£0.10p ea) to hold the switch if you dont opt for the kit.
    Your sounds identical to mine so you will have the correct switch module fitted already from the factory - as you have multifunction wheel.
    So all you need is: Switch - 4E0953521B4PK - £26.12+vat
    2 screws - N90906802 - £0.09p each +vat
    Lower Cowl - 8E0953512P 6PS* (for near black trim*) - £25.59 + vat
    * other trim colours available - but yours should be black with yours being a special edition
    It'll need fitting - which involves removing steering wheel inc. airbag -caution req'd here for novices-
    It will also req coding onto the vehicle.
    B6 - Audi A4 between 2001 - 2005.
    B7 - Audi A4 between 2005 - 2008
    Main differences are the full height radiator grille on the B7 (B6 had seperate upper and lower grille split by the bumper). B7s also have 2 piece taillights - 1 on body, 1 on boot/tailgate (B6 has single piece on body only)
    2 0 0
  10. Re: retrofitting cruise control to A4 quattro
    Nov 2008
    Nr Totnes
    Just caught up with this thread, cheers for the info all, something my car should have had but I didn't realise it was so cheap to retro fit.
    A question though, to recode the car after fitting? I presume that is an Audi thing or local Audi specialist? Sorry newish to A4 ownership myself
    TIA
    Tim
    A4 Avant 2.0T S Line SE Quattro
    MX5 Mk3 LE 2.0 221 of 300
    Mitsubishi Legnum VR4 340Hp
    A4 Cab 2.4 Sport
    Mazda RX8 Hi Power
  1. How To retro fit cruise
    By a8 tech in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-03-2010, 01:34 PM
  2. auto shutdown of convenience systems
    By bigb in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 29-03-2009, 07:40 PM
  3. Can I fit Satnav to my new A4 Cab
    By car@fmcneill.fr in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-04-2008, 10:09 AM
  4. ADVANCED NEW FOUR-CYLINDER PIEZO TDI ENGINE
    Last Post: 17-05-2006, 08:14 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
