Quote Originally Posted by gareths quattro View Post
Cheers lateknight for the advice and parts list. Sounds like it could be a fairly cheap retrofit then!
Ukdan... what beer do you drink matey?!! I may take you up on your offer! Are there any potential issues removing the steering wheel / airbag? Is there any chance it could deploy? Will the steering wheel go back on as it came off - alignment wise? How confident are you at fitting? Sounds like you know what you're doing as you've done it on your own car already, got all the kit and can use the vagcom software!
Would be nice to have it fitted!
Only issue with removing steering wheel/airbag is if you discharge any static when removing or installing. Just need to be carefull and discharge yourself. Steering wheel position should not change as you mark it before removing.
