Thread: Retrofitting cruise control to A4 quattro - possibly the best thread on this subject covering all issues from the basic to the complex.
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 67
  1. Re: retrofitting cruise control to A4 quattro
    swindon uk
    Seeing as your car has multi function steering wheel then you would only need the cruise stalk and steering cowl with the extra cut out. Very easy to install, would take approx 1 hour.
    And no i wouldn't charge if you came to me. Im about 30 mins from bristol.
    Audi A4 saloon, 2.0L tdi s-line. Retrofitted cruise control, DIS and MFSW. VCDS user.
  2. Re: retrofitting cruise control to A4 quattro
    Nov 2008
    Nr Totnes
    Quote Originally Posted by ukdan View Post
    Thanks for the offer, how much would you charge for the whole supply and fit? I have to go up to the midlands once a month so could drop in on the way...... the recode people have mentioned, will my car need it?
    Tim
    A4 Avant 2.0T S Line SE Quattro
    MX5 Mk3 LE 2.0 221 of 300
    Mitsubishi Legnum VR4 340Hp
    A4 Cab 2.4 Sport
    Mazda RX8 Hi Power
  3. Re: retrofitting cruise control to A4 quattro
    swindon uk
    I don't run a business so i wouldn't supply parts and dont charge. I also don't supply a warrenty. i do it to help people out and its a bit of a hobby so if you turned up at my door step with a bag of parts and a can of beer i would be more than happy to fit.
    2 0 0
  4. Re: retrofitting cruise control to A4 quattro
    swindon uk
    As for coding, yes it will need coding to activate cruise control which i can do.
    2 0 0
  5. Re: retrofitting cruise control to A4 quattro
    Nov 2008
    The new stalk will be ignored by the car if its not re-coded. Fairly simple as long as you know what you are doing and have the right tools (software).
    Your basically telling the car its now got cruise.
    2006 A4 saloon 2.0T S-Line Special Edition.
    Mauritius Blue - Xenons, Bose, Heated Valcona, Cruise, Colour DIS, Ipod, Revo. Big Smile.
  6. Re: retrofitting cruise control to A4 quattro
    Nov 2008
    Nr Totnes
    Thanks Fella's
    UKDan you have a PM
    Lateknight, what is the software and where can you get it? I used to use with Evoscan software on my VR4 to adjust the settings of the ECU is it much different?
    A4 Cab 2.4 Sport
    Mazda RX8 Hi Power
  7. Re: retrofitting cruise control to A4 quattro
    #17
    Nov 2008
    The software is just the communication program, so you can talk to the vehicle electrical system. Most non specialists use VAGCOM.
    http://www.ross-tech.com/vag-com/index.html
  8. Re: retrofitting cruise control to A4 quattro
    #18
    May 2010
    caldicot UK
    Cheers lateknight for the advice and parts list. Sounds like it could be a fairly cheap retrofit then!
    Ukdan... what beer do you drink matey?!! I may take you up on your offer! Are there any potential issues removing the steering wheel / airbag? Is there any chance it could deploy? Will the steering wheel go back on as it came off - alignment wise? How confident are you at fitting? Sounds like you know what you're doing as you've done it on your own car already, got all the kit and can use the vagcom software!
    Would be nice to have it fitted!
  9. Re: retrofitting cruise control to A4 quattro
    #19
    May 2007
    knee deep in clunge
    14 Post(s)
    to cover the fitting and coding
    see here
    https://www.vwaudiforum.co.uk/forum/s...ght=dis+cruise
  10. Re: retrofitting cruise control to A4 quattro - possibly the best thread on this subject covering all issues from the basic to the complex.
    #20
    Coventry
    Great thread now stickied.
    Thanks to all for the wide variety of questions. They will help every reader of the thread regardless of their level of understanding.
    Thanks to all.
  1. How To retro fit cruise
    By a8 tech in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-03-2010, 01:34 PM
  2. auto shutdown of convenience systems
    By bigb in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 29-03-2009, 07:40 PM
  3. Can I fit Satnav to my new A4 Cab
    By car@fmcneill.fr in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-04-2008, 10:09 AM
  4. ADVANCED NEW FOUR-CYLINDER PIEZO TDI ENGINE
    Last Post: 17-05-2006, 08:14 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
