Thread: Emissions control system warning light on
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. Emissions control system warning light on
    Aug 2010
    London N10, UK
    Hi All
    Brand new to this forum as only had my A4 Cab a week tomorrow. Loving it, except that yesterday the ECS light came on. Did a bit of a search here, but most posts seem to be about TDi's, mine's a 1.8T. Had a similar issue a few years ago with a Passat 1.8T, and my memory is that it took many visits to a main dealer to solve, and they wanted £100 every time they attached a diagnostic tool.
    Any advice?
    Thanks all.
  2. Re: Emissions control system warning light on
    Southern County Softy
    a fault scan will help.
    look in the vagcom section for a member in your area to scan the car.,
    A4 2.5 tdi QS (mapped)
  3. Re: Emissions control system warning light on
    Nov 2008
    Leeming
    Quote Originally Posted by ChristopherF View Post
    Hi All
    Any advice?
    Thanks all.
    Was it flashing or solid, if it was flashing, and the engine is very lumpy, you might have a knackered ignition coil, £30 from Audi
  4. Re: Emissions control system warning light on
    Aug 2010
    London N10, UK
    Quote Originally Posted by blackpool1974 View Post
    Solid. Engine appears to be running normally
  5. Re: Emissions control system warning light on
    Aug 2010
    London N10, UK
    Hi. Took it back today to Bullitt cars in Mill Hill, from whence it came, and it appears not to be serious; they've reset and the light not coming on again...yet. Good friendly and quick service from Mark and the guys.
    They aren't Audi specialists by any means, but seem to knock out decent interesting cars at fair prices.
  6. Re: Emissions control system warning light on
    Nov 2008
    Leeming
    Unfortunately they have only reset the ECU. Did they tell you what the fault code was before resetting ?? it comes on for a reason
    Over time your fuel trim (idle and multiplative) will change either lean or rich and when they reach a certain threshold the emissions light will come back on
    If you are friendly with them get them to look at measuring block 32 on your engine there will be 2 percentages each should be no more than say 5% plus or minus. This will show how lean or rich the engine is running, the emissions light comes on after your ECU decides that too much air is entering the engine or not enough fuel (lean) or not enough air or too much fuel (rich)
    If you have a tiny hole in a pipe it will take a while, sometimes upto 100 miles before the ECU decides to put the light on
    When the car is at idle is it jumpy ??
  7. Re: Emissions control system warning light on
    Aug 2010
    London N10, UK
    yes, they gave me the print-out. it says:
    CODE 001:
    P0130 02 Sensor circuit, Bank 1 - sensor 1: Malfunction. Short circuit to another valve
    CODE 002:
    16804 P0420 Catalyst system, bank 1: efficiency below threshold
    sporadic
    no, not jumpy at idle.
    To be fair to them they said if it comes on again they will fix.
  8. Re: Emissions control system warning light on
    Aug 2010
    London N10, UK
    CODE 001:
    CODE 002:
    sporadic
    Guess what? It's back on!
  9. Re: Emissions control system warning light on
    Aug 2010
    London N10, UK
    well, yesterday I was going to post that they installed a new lambda sensor and all was well. In fact, I was thinking this as I drove into work when the bl**dy thing came on again. anyway, apparently there is a 2nd lambda sensor which they say they will now replace.
    Fortunately this is all under warranty.
  10. Re: Emissions control system warning light on
    Aug 2010
    London N10, UK
    Bullitt have ordered the 2nd sensor and will fit next week. Hopefully will solve the problem.
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. DRLs, is this setup possible?
    By g-black in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-01-2013, 08:37 AM
  3. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
  4. Option Codes
    By Samcat in forum Passat - Archive Topics
    Last Post: 23-11-2006, 11:25 AM
