Thread: Water running into the boot when I open the tailgate of a wet 2010 A6 Avant
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. Water running into the boot when I open the tailgate of a wet 2010 A6 Avant
    Aug 2009
    Sussex
    We've just taken delivery of our new A6 Avant and I love it with one exception. When the car's wet and we open the tailgate, water pours out of the sides of the channel under the rear window and (usually) splashes into the boot on one side or the other depending on the wind direction.
    This seems like such a poor part of the design that I can't be the only person who finds this annoying; yet a search of these forums gives no results.
    Does anybody else experience this? Has anybody found a solution?
    Here are some keywords for others who might be Googling with this problem:
    boot trunk water leaking rain opening tailgate bootlid
  2. Re: Water running into the boot when I open the tailgate of a wet 2010 A6 Avant
    Aug 2010
    Winchester
    I'm picking up my new a6 avant on Friday, I was in a colleagues new a4 avant today and I got wet after he opened the boot to get my laptop so it's probably across the whole range...
  3. Re: Water running into the boot when I open the tailgate of a wet 2010 A6 Avant
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Quote Originally Posted by SiliconS View Post
    My car is a saloon, so I can't comment about the A6 Avant doing this, but can confirm that Mrs F's TT Coupe has exactly the same problem. We invested in a boot liner for it, mostly to keep the carpets dry.
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  4. Re: Water running into the boot when I open the tailgate of a wet 2010 A6 Avant
    Aug 2009
    Sussex
    Thanks for the responses. I think I'll try channeling the water with some tape and see whether it helps. If I do then I'll post photos.
  5. Re: Water running into the boot when I open the tailgate of a wet 2010 A6 Avant
    my 2008 avant also does this. I don't what you intend to tape but when I complained at dealer I was told the run-off is designed like that to avoid water accumulation under rear window. And not to tape it up. Their solution was to tell me to lift tailgate only slightly at first to allow water to hit drain channel. Which doesn't really work to be honest, you still get water inside.
    It's not good, but my mate's Mondeo hatch does same thing - for same reason.
  6. Re: Water running into the boot when I open the tailgate of a wet 2010 A6 Avant
    Aug 2009
    Sussex
    Quote Originally Posted by fruitbat View Post
    Thanks for the reply. Interesting that the dealer told you that because the design has the opposite effect to what they claim. My C5 A6 Avant didn't have the problem.
    My plan is to put clear tape down the side of the rear window glass to bridge the gap between the glass and the metal and form a thin channel down which water can run towards the hinges. Now that my dealer has fixed the problem I've had with a leaking tailgate I can hopefully put the tape on without it getting disturbed by their technicians.
    When I get chance I'll post a photo to show what I mean.
  7. Re: Water running into the boot when I open the tailgate of a wet 2010 A6 Avant
    That would be great - I'm definitely interested (if it works)
  8. Re: Water running into the boot when I open the tailgate of a wet 2010 A6 Avant
    Aug 2009
    Sussex
    Spurred on by your reply I've just had a quick play.
    The photos below show where I've roughly added some sellotape. (This is not the final solution, obviously!) I've put a strip down the side of the tailgate to bridge the gap between the glass and the metal, and it forms a thin channel down which water can run to the hinge area.
    A quick test with water in the channel under the window gives mixed results. If I open the boot slowly the water does indeed run down this channel without any drips at all but if I open the boot quickly the volume of water overwhelms the narrow channel and splashes out of the side more messily than it did before. I'll leave the tape installed on this side and wait for the next rainy day.
    The third photo shows how the tape looks from the outside. It's not beautiful but it's not particularly noticeable. With better tape more carefully applied it would probably look much neater.
    Last edited by SiliconS; 03-09-2010 at 12:41 PM. Reason: Replacing the tiny attachments with decent-sized photos...
  9. Re: Water running into the boot when I open the tailgate of a wet 2010 A6 Avant
    Tried this at weekend and its definitely better when opening slowly than not having it. I used black tape instead of selly and mine being a black car makes it hardly noticable even when tailgate open. cheers for the pics without them I realise I didn't know what you had in mind.
  10. Re: Water running into the boot when I open the tailgate of a wet 2010 A6 Avant
    Aug 2009
    Sussex
    Good news. Thanks for posting your feedback.
    What sort of tape did you use? It needs to be waterproof but also not deteriorate into a sticky mess if it gets hot/cold. I dislike electrical tape because of its stickiness even though it'd be the perfect width and flexibility. Maybe some sort of vinyl?
  1. Passat boot keeps clicking open.
    By Tomo 21 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-12-2017, 12:13 PM
  2. 130TDi Sport - Water in Boot!
    By peter.james in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-01-2011, 12:46 AM
  3. Replies: 0
    Last Post: 20-07-2005, 08:45 PM
  4. Audi launches efficiency drive with New A6 FSI models
    Last Post: 23-05-2005, 07:34 PM
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
