Thread: front wing corrosion
Page 74 of 75 FirstFirst ... 246472737475 LastLast
Results 731 to 740 of 744
  1. Re: front wing corrosion
    Aug 2008
    East Anglia, UK
    Technically speaking the typical damage in this area is only covered by the three year paint warranty, the corrosion warranty only covers perforation rusting from the inside out and this is more inside, then under and up the other side. Why some plonker specified an absorbent foam for this task is anyone’s guess, total stupidity probably caused by a penny pinching accountant and a young engineer who did not understand rust, only NVH.
    Outside influence by a rubbish design hey. Stopped the vibrations a treat but friction, grit and salt with water as the sponge pushes the plastic sharp inner wing against a lightly protected inner side of wing is never going to work.
    On my second Mk5 Golf before it started I whipped the sponges out, treated them with primer and pained in inner wing with some Epoxy Mastic. Far better than what VW did on my first Golf. Then adjust inner wing so it doesn't rub.
    As for inside that often means from under the paint outwards, not inside of the wing to outside either through or down and around.
    '08 GOLF GT TDI 140
  2. Re: front wing corrosion
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Please be aware that a body shop repair carried out by a VW dealer is only guaranteed for 3 years paint & workmanship) and parts are only guaranteed for 2 years. I have just had a damaged front wing replaced by a VW body shop through a VW dealer . I was surprised by this as I thought I would get a VW gurantee and not a dealership gurantee.
    Skoda Octavia II SE 1.9PD TDI
  3. Re: front wing corrosion
    Nov 2018
    Telford
    Well, this is an update to my original posting and my thanks to Kevster140, VWcabriolet1971 and Crasher for getting back. Not surprisingly after email conversations with the paintshop it has now all gone quiet after they blamed the VW Customer Service team for being the ones stopping them doing the work and vice-versa. I am now left with either pursuing the cost of replacing the wings OR using that money as a deposit on a replacement second hand car which has been in the back of my mind anyway. The sad fact is that after this experience I am more likely to go back to Vauxhalls although generally speaking the VW has always seemed a better build with the reassuring 'clunk' rather than 'clank' sound as humorously portrayed in the old adverts. I have a feeling that any pursuit of the warranty given that the car is 10 years old is just going to be delayed and will be just too much hassle.
    The other option is to buy a couple of wings and remove/fit the new ones myself and then invest in a paint job.
    Anyone got any good sites for parts and how-to videos?
    Thanks.
  4. Re: front wing corrosion
    1837 Post(s)
    This months Car Mechanics magazine covers the job https://www.greatmagazines.co.uk/car...kaAoTVEALw_wcB
  5. Re: front wing corrosion
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    My daughter had 2 front bubbling wings replaced about a year ago with no problems. It seems a little crazy to me that a wing replacement due to rust can reduce the VW body guarantee from 12 years to 2 years !
  6. Re: front wing corrosion
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    I would take them to the small claims court (easy to do - google "small claims court" . I'm fairly sure that they will cave in eventually. good luck. Our local well respected bodyshop (non-VW) gives a better guarantee than all the VW dealers. When my VW body guarantee runs out I will revert to tis bodyshop.
  7. Re: front wing corrosion
    Feb 2009
    Glasgow UK
    Really nice to see this thread still alive and well, going strong.
    Quite simply there is just good sound solid advice contained, that if / when followed should result in a successful claim. I joined this thread back at post #114 some 300,00 views and a million likes ago.
    It really helped me and I like to think I added to the thread and kept it going for another 30 or so pages encouraging others to follow suit.
    Here's hoping it helps hundreds more....
    Edit - I'm back with the Passat that I posted about here some 7 years ago. We now have her back in the family and are trying to resurrect her after being unloved for several years
    Jim
  8. Re: front wing corrosion
    Dec 2020
    Dunfermline
    Hi Jim - could you maybe guide me to the post that summarises the best approach to claiming. I have a 2012 VW golf TDI, and VW have agreed to complete Cill work for Ł600 as a goodwill gesture, and I want to pursue them for a greater contribution.
    What do you advise? Many thanks
  9. Re: front wing corrosion
    Nov 2020
    Essex
    Hi all
    I know this thread will go on forever with VW so simply question
    If I replace new vw OE right front wing would it solve problem by not putting foam back on
    My 2005 was repaired by me and a month latter returned
    I have a 2007 now and same problem with only 97,000 on the clock
    Plus usual corrosion/rust on rear as was 2005 model both estates
    Sidepike
  10. Re: front wing corrosion
    Mar 2022
    Northern ireland
    Hi. Does this thread apply if its the rear wheel arches that are rusting rather than the front? We have a 2013 sharan showing a bit of rust there and also the edge of the adjoining panel. I rang our local vw repair centre today and they told me it's not covered by the 12 year warranty only the 3 year one. He asked if it had ever been painted before, I replied 'no'.
    They said they had never heard of anyone claiming under 12 year anti corrosion warranty successfully. I had mentioned there were thousands of reports of it online. He advised me to take the car to the repair centre for them to look at and they could give me advice...what should I do in this case?
  1. Need price for front wing replacement please!
    By andyledude in forum Golf MK4 - 1999 - 2004
    Last Post: 09-02-2015, 06:23 PM
  2. Replies: 35
    Last Post: 22-01-2015, 11:12 PM
  3. New bentley continental supersports convertible
    Last Post: 02-03-2010, 08:04 PM
  4. How does the Quattro system work?
