Thread: Help with coding please.
Results 1 to 9 of 9
  1. Help with coding please.
    Nov 2008
    N/A
    I have a 2003 B6 8E A4 1.9TDI Saloon in the UK with locking confirmation via beep and indicators and unlocking via indicators only. Selective unlocking is DEactivated. Anti hi-jack is enabled.
    Could someone please tell me what my coding value should be in Comfort System module 46. I'm not sure what all the options mean and whether they should be enabled or disabled.
    I have been looking at this page in Ross Tech Wiki - http://wiki.ross-tech.com/wiki/index...Comfort_System
    Any help appreciated!
  2. Re: Help with coding please.
    Oct 2009
    Staines, UK
    Have a look at the translation of this page - http://de.openobd.org/audi/a4_8e.htm#46
    '56 Passat 2.0 TDi 140 SE Estate
    Fully registered VCDS HEX-USB+CAN
  3. Re: Help with coding please.
    Nov 2008
    N/A
    Thsnkd bundao, but it's pretty much the same as the ross tech one. I'm not sure if I shoule be activating:
    +8 Anti theft
    +2048 Door/Window reg logic
    +8192 No safe function
    I' not sure what they are for/what they do?
  4. Re: Help with coding please.
    Sep 2009
    Apollo
    Post the complete Auto-Scan using our current release and list any features you would like to enable or disable.
    If you have already changed the coding, please include the original value.
  5. Re: Help with coding please.
    Nov 2008
    N/A
    OK, here's the full scan. I haven't changed anything yet. I already have auto lock at 10mph, blink on unlock/lock, beep on lock & comfort functions activated, with selected unlocking deactivated as it's far too annoying! The alarm fault codes were caused by me yesterday! The value stored in module 46 is 07931.
    Saturday,21,August,2010,14:35:36:42859
    VCDS Version: Release 10.6.0
    Data version: 20100630
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E33A321009 Mileage: 164740km/102364miles
    Address 01: Engine Labels: 038-906-019-AVF.lbl
    Part No: 038 906 019 JT
    Component: 1,9l R4 EDC G000SG 1572
    Coding: 00003
    Shop #: WSC 63351
    VCID: 72EF22CB14C7
    WAUZZZ8E33A321009 AUZ6Z0B0397325
    No fault code found.
    Readiness: 0 0 X X X
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 A
    Component: ABS/ESP allrad 1729
    Coding: 04255
    Shop #: WSC 06435
    VCID: 26470E9BE88F
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AJ
    Component: A4 Klimaautomat 2831
    Coding: 00000
    Shop #: WSC 00000
    VCID: 69DD45A73911
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 E
    Component: int. Lastmodul RDW 0305
    Coding: 00001
    Shop #: WSC 63351
    VCID: 3463E4D32E53
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 B
    Component: Airbag 8.4EP 2000
    Coding: 0010602
    Shop #: WSC 63351 000 00000
    VCID: 3667DEDB382F
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 N
    Component: Lenksáulenmodul 0308
    Coding: 02041
    Shop #: WSC 63351
    VCID: 3E77C6FB101F
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 981 C
    Component: KOMBI+WEGFAHRS. RB4 D42
    Coding: 01400
    Shop #: WSC 00370
    VCID: 2D55F1B7CD79
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0604
    Coding: 00001
    Shop #: WSC 00000
    VCID: EBD1BFAFB3ED
    1 Fault Found:
    01463 - Alarm triggered by Sensor for anti-theft alarm System
    43-00 - Closed
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 BC
    Component: Komfortgerát T3B 1211
    Coding: 07931
    Shop #: WSC 63351
    VCID: 73E127CF6BDD
    Part No: 8E2959802B
    Component: Tơrsteuer.FS BRM 0003
    Part No: 8E2959801B
    Component: Tơrsteuer.BF BRM 0003
    Part No: 8E0959801A
    Component: Tơrsteuer.HL BRM 0003
    Part No: 8E0959802A
    Component: Tơrsteuer.HR BRM 0003
    1 Fault Found:
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 186 J
    Component: concert II GRO 0008
    Coding: 01005
    Shop #: WSC 63351
    VCID: 2E57F6BBC07F
  6. Re: Help with coding please.
    Sep 2009
    Apollo
    Based on that coding 07931 and the coding chart here:
    Audi A4 (8E) Comfort System
    , It looks like the module is coded for:
    +00001 = GB-Alarm (not USA)
    +00002 = Confirmation Anti-Theft Warning System (Blink)
    +00008 = Anti-Theft Warning System
    +00016 = Rear Lid Release Locking at 5 km/h
    +00032 = Central Locking at 15 km/h (or 10 mph)
    +00064 = Comfort Function via Remote Control (not USA)
    +00128 = Right Hand Drive (RHD)
    +00512 = Confirmation Close via Remote (1x Blink)
    +01024 = Confirmation Anti-Theft Warning System Horn Activation
    +02048 = Door-/Window Regulator Logic
    +04096 = Thatcham Anti-Theft Warning (not USA)
    The items that are not enabled are:
    +00004 = Selective Central Locking (SCL)
    +00256 = Avant
    +08192 = No Safe-Function
    +16384 = Side Windows with Insulated Glass
    The coding looks fine. If you wanted to add selective locking, add a value of 4 to the existing coding which would make it: 07935. You might find some of this platform info. here helpful: Audi A4/S4 B6/8E VAG-COM Info
  7. Re: Help with coding please.
    Nov 2008
    N/A
    Thank you very much Dana, is it correct that I should have bit 0008 and bit 04096 both activated for my alarm system here in the UK?
  8. Re: Help with coding please.
    Norfolk
  9. Re: Help with coding please.
    Sep 2009
    Apollo
    Quote Originally Posted by benjie View Post
    Yes, your original coding looks fine.
  1. Help please with problem on my A6 (flashing Glowplug light)
    By oDUTCHYo in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-08-2010, 10:45 PM
  2. Please Help Fitted dis and cruise but having problems with coding etc
    By ukdan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-07-2010, 06:45 PM
  3. Audi a8 2003 Current gearshift program problem
    By eints77 in forum VCDS - Help Requests
    Last Post: 20-07-2010, 02:58 PM
  4. A6 4F (C6) 2.7Tdi Avant, battery empty, fault log
    By luusje in forum VCDS - Help Requests
    Last Post: 05-05-2010, 06:45 PM
  5. Problems with Nav retrofit MMI A6 2008
    By craiglett in forum In Car Entertainment
    Last Post: 31-12-2009, 11:27 AM
