Thread: What to look out for when buying a 2nd hand Bora
Results 1 to 10 of 12
  1. What to look out for when buying a 2nd hand Bora
    monsigna Guest
    Hello again i am going to test drive a vw bora tdi highline (2004), Manual 6 speed, Saloon, 1.9 Diesel (130), 04 (54) Plate, 66,000 miles,
    What should i look out for & listen for? the cam belt has been done. any pointers would help.
    ade.
  2. Re: What to look out for when buying a 2nd hand Bora
    Chester-le-Street, United Kingdom
    Quote Originally Posted by monsigna View Post
    ade.
    how much is it?
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: What to look out for when buying a 2nd hand Bora
    Aug 2009
    Manchester UK
    I have just sold the twin of that car although it had done 8k less miles. £5950 from a dealer or £5000/£5250 private sale with no warranty/new MOT/service/free HPI/valet and half tank of derv!
    2005 Golf mk5 GT TDI 140bhp, 2002/52 Bora 1.8T Sport 150bhp, 2001 Golf mk4 GT TDI 115bhp 6spd, 2003/03 Golf mk4 5dr GTI 1.8 T 180bhp 6spd, 2003/53 Bora TDI Sport 130bhp Tip-Auto, 06/56 Passat B6 2.0 TDI 4dr SE 140bhp (185bhp remap), currently 06/56 Passat B6 2.0 TDI 4dr 170bhp Sport (200bhp+remap).......
  4. Re: What to look out for when buying a 2nd hand Bora
    monsigna Guest
    Quote Originally Posted by STEWY L View Post
    how much is it?
    £5,495 full leather
  5. Re: What to look out for when buying a 2nd hand Bora
    Feb 2005
    Selby, North Yorkshire
    They're fairly reliable, but there are a number of issues which are well documented on here. Some cover spaceship mileage wth no problems others don't.
    Listen for clunks from the rear which may indicate worn axle bushes, similar at the front for worn bottom arm bushes. Dogbone bushes also wear causing jerky driveline.
    If cambelt has been done has the waterpump? And was the tensioner changed with the belt?
    Poor economy and loss of power usually means a failing air mass meter (often referred to as MAF).
    On PD engines it is critical that the correct engine oil has been used, otherwise the cam and followers can be toast. I change every 5 or 6K regardless and use Longlife 3.
    If it drives OK and mileage is genuine looks like a reasonable purchase.
    Hope this helps.
  6. Re: What to look out for when buying a 2nd hand Bora
    monsigna Guest
    thanks paul, will be looking at it in about an hour or so. so will give it a good test drive.
  7. Re: What to look out for when buying a 2nd hand Bora
    Feb 2005
    How did you get on?
  8. Re: What to look out for when buying a 2nd hand Bora
    monsigna Guest
    The chap phoned me because he couldnt find all the documents so we postponed it till this evening
  9. Re: What to look out for when buying a 2nd hand Bora
    Feb 2005
    Hope it's OK. FSH is vital.
    If there are lots of receipts, check them carefully - they can tell you a lot!
    Good luck mate.
  10. Re: What to look out for when buying a 2nd hand Bora
    monsigna Guest
    He siad its got a full VW service history including invoices for the work done..
  1. Question Passat 2nd, 3rd gear syncro wear crunch?! which oil/what to do
    By passat938 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-05-2009, 06:56 PM
  2. Notchy 1st to 2nd gear change
    By kimandsally in forum Touran - Sharan - Caravelle
    Last Post: 21-12-2008, 08:25 PM
  3. 2nd gear crunch noise
    By DAVIDBLUEJEAN in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-02-2008, 11:35 PM
  4. Lost 2nd gear, synchro? common failure?
    By Dave Avant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-10-2007, 01:32 PM
