Thread: Intermittent coolant gauge fault
Results 1 to 1 of 1
  1. Intermittent coolant gauge fault
    Mar 2010
    PLYMOUTH ENGLAND
    Hello
    Was wondering if anyone has had any similar problems or can shine any light on this fault.
    The coolant gauge in my 1.8 1999 audi cabriolet is is only working intermittently. I ve checked the supply on the sender which i think should be between 9.8 and 10.2 volts but im only getting 3 ish.
    The audi manual i ve managed to get hold of recommends checking the current flow diagram (which i cant seem to find anywhere? any suggestions?) or the voltage across the voltage stabilizer.
    My fuel gauge is also a bit tempermental and the supply voltage is showing 11.5 instead of the above voltage.
    Id like to check everything i can before i start changing components in vain hope.
    Thanks in advance for any suggestions
    Rich
  1. Replies: 21
    Last Post: 04-07-2012, 10:32 PM
  2. 99 A6 Avant 4.2 - misfire but no fault codes
    By sparkyjf in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-08-2010, 08:20 PM
  3. Please Help Fitted dis and cruise but having problems with coding etc
    By ukdan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-07-2010, 06:45 PM
  4. Healp needed VAG com
    By Snooze1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-06-2009, 07:47 AM
  5. Vag Results , Anyone want to quote me and repair?
    By pete2vinal in forum Golf MK4 - 1999 - 2004
    Last Post: 13-02-2008, 04:35 PM
