Thread: 2.0tdi passat bkp 2005 - injector?
Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
  1. Re: 2.0tdi passat bkp 2005 - injector?
    #21
    Aug 2019
    Coventry UK
    Hi Friends,
    I had a break down with my car Passat 2.0 TDI fitted with BKP engine with 2005 Plate and AA has diagnosed it with the below 2 fault codes
    17925-power supply relay ecu j271 or j363 electrical malfunction p1517
    18578-supply voltage for fuel injector group a open circuit p2146
    I tried the same technique of disconnecting the Injector harness one by one and cranking the car and could root cause it to the first Injector from the Injector Harness inlet side.
    But my question now is about the injector part number that I needs to order.. As when I looked at the part numbers on all the 4 injectors..
    It has the below part numbers.
    1) Injector1 Part Number - 03G130073M - Found Faulty..
    2) Injector2 Part Number - 03G130073D
    3) Injector3 Part Number - 03G130073S
    4) Injector4 Part Number - 03G130073D
    My question is that- is there any difference with the above 3 different part numbers on my sensors
    03G130073M / 03G130073D & 03G130073S.
    Can I fit with any of the above part numbers in lieu of the faulty injector -
    03G130073M .
    Appreciate a quick response, so that I can order the Correct part to fix my car please
    Siva
  2. Re: 2.0tdi passat bkp 2005 - injector?
    #22
    1836 Post(s)
    The M should not even be in there, it is from a BMR 170 engine! The only good one is the S, the current VAG part number is 000 130 073 SX at £463. Always fit new bolts 03G 103 385 A
  1. Please Help Passat 2005 B5.5 gamma 6 cd changer,add usb/bluetooth
    By mockingbird in forum In Car Entertainment
    Last Post: 03-12-2009, 02:06 PM
  2. 2007 B6 Passat estate 2.0TDi SE Service/Workshop Manual
    By Dtwo in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-04-2009, 07:23 PM
  3. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
  4. Auto1 Award: The Passat is Europe’s Number One
    Last Post: 07-03-2006, 08:56 PM
  5. First Pictures of the New Passat Revealed!
    Last Post: 15-12-2004, 12:10 PM
