Thread: Fuse Blowing
  1. Fuse Blowing
    Jan 2009
    1993 Audi 1.9TDI. Just developed a fault where fuse 14- instrument illumination and number plate light blows when sidelights are turned on. I've pulled out the bulbs on the number plate lamps, lamps around ventilation controls, lamp under bonnet and disconnected instrument cluster completely to no avail, any ideas? Only thing I can think of is the switch stalk itself. How can something like this suddenly go short?
  2. Re: Fuse Blowing
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    It could be the wiring loom itself rather than the actual consumer. have a look at the Boot/Tailgate loom what carries the wiring to the Numberplate lamps. It`ll be iside a rubber sheath.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: Fuse Blowing
    Nov 2008
    folkestone.kent
    typical fault as alan02 has suggested
  4. Re: Fuse Blowing
    Jan 2009
    Thanks Guys good suggestion, turned out to be the glove box. light switch which had become jammed up by the service manual and was shorting out! All I need now is a load of new fuses. I always have trouble getting the glove box to shut and the manual binder doesn't really seem to fit. cheers John
  1. Instrument cluster fuse Keeps blowing
    By mm#2 in forum 80 - 90
    Last Post: 06-05-2009, 11:30 PM
  2. 1996 Polo blowing fuse 21 (interior lights and locking)
    By GavHT in forum Polo - Derby - Lupo - Fox
    Last Post: 24-11-2007, 04:46 AM
  3. A4 95/96 Engine Management Fuse blowing
    By PClements in forum Archive posts
    Last Post: 01-11-2007, 09:46 PM
  4. ECM Fuse blowing
    By mikespain in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-05-2007, 01:08 PM
  5. BORA fuses blowing ? Which fuse how many Ampere ?
    By henri in forum Bora - 1998 - 2005
    Last Post: 22-02-2006, 11:23 PM
