Thread: Do You have VCDS
Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. Re: Do You have VCDS
    #21
    Nov 2011
    Chile
    Quote Originally Posted by martin1810 View Post
    The 1.9 tdi PD BXE will happily be mapped from 105 hp to 130hp. Driven carefully it will still produce good fuel consumption.
    I will start with fine tuning the timing of my car. After that, I will try to get a good re-mapping of my Octavia.
    Tks,
    Oldbeaver
    I have a site: https://sites.google.com/site/rd28engineswap/home
    The car is still running smooth.
  2. Re: Do You have VCDS
    #22
    Nov 2011
    Chile
    Dear Martin 1810,
    How can I attach my Octavia II log for you?
    However, mine goes until address 72. The one you show in the site is giving results in groups, mine give them in addresses. Is there any way to make a more complete scan? Or do you mean to make them one by one and put them together?
    Please, explain.
    Tks, Oldbeaver
  3. Re: Do You have VCDS
    #23
    Norfolk
  4. Log of a 1.9 TDI PD available.
    #24
    Nov 2011
    Chile
    Dear Martin 1810,
    Yr site is the most complete and to the point about 1.9 TDI ´s I have found so far. Again, tks to share with us all.
    I learned how to produce a all in a run log. I will take one for you and send it to you or to the site.
    I have one question: do you need some particular variables or just the set that is given in a "all in a run" ?
    By the way, I made an adjustment of the timing (fine tune, monitored using torsion value) and diminished fuel spent from 0.6 lt/hour to 0.4 lt/hour. Next step will be spend a whole tank to see performance. In local 50 km tests I am getting significant improvement in fuel performance. Is there a thread in this site to report that?
    Best,
    Oldbeaver
  5. Re: Do You have VCDS
    #25
    Jun 2010
    lisboa portugal
    Hello Martin 1810
    I have put here a log of my car and comparing with the others here and the information on your page (great job) and i see in the Group 51 i have the same value of rotation, should be half of where it is written in red, or not?
    Group 51
    798 / minRPM
    798 / minRPM
    255.0 (in unit
    Bin 0. bits
    You know why?
    Thank you in advance
  6. Re: Do You have VCDS
    #26
    Norfolk
    Yes I would expect the RED figure to be half. That is odd, I don't know why. If the camshaft sensor had failed you would have a fault code, so that can't be the reason.
  7. Re: Do You have VCDS
    #27
    Apr 2010
    Orkney, Scotland
    Will be glad to help Martin, soon as I can suss out what's reqd. Will email you/post a reply with the info.
    BTW thanks for all your help to date, you are a 'bottomless pit' of info and don't know where I'd be without your assistance.
    Steve
  8. Re: Do You have VCDS
    #28
    Jul 2012
    United Kingdom
    Passat 2006 TDI BKP 172,000 miles
    Address 01: Engine (03G 906 018 CK)
    16:40:56 Group 001: Injection Quantity
    799 /min Engine Speed (G28)
    6.5 mg/str Injection Quantity
    3.0°KW Injection Duration (specified)
    84.0°C Coolant Temperature (G62)
    16:40:56 Group 002: Idle Speed
    0.0 % Accel. Pedal Pos. Sensor 1 (G79)
    00001000 Operation Status
    16:40:56 Group 003: Exhaust Gas Recirculation (EGR)
    803 /min Engine Speed (G28)
    1388.8 mg/str Exhaust Gas Recirculat. (spec.)
    476.2 mg/str Exhaust Gas Recirculat. (actual)
    -2.0 % Exhaust Gas Recirc. Duty Cycle
    16:41:17 Group 004: Unit Injector
    4.8 °ATDC Injection Start (specified)
    3.1°KW Injection Duration (specified)
    -3.72° Torsion Value
    16:41:17 Group 005: Start Conditions (last Engine Start)
    802 /min Engine Speed (G28)
    0.0 Nm Starting Torque
    255.0 Start Synchronisation
    16:41:17 Group 006: Cruise Control System (CCS)
    0.0 km/h Vehicle Speed (actual)
    00001100 Cruise Control Pedal Monitoring
    00000000 Cruise Control Switch Monitoring
    Thursday,30,January,2014,16:42:05:32264
    VCDS Version: Release 11.11.3
    Data version: 20120401
    16:41:43 Group 007: Temperatures
    77.0°C Fuel Temperature (G81)
    25.0°C Intake Air Temperature (G72)
    16:41:43 Group 008: Injection Quantity Limitation I (Torque Limitation)
    0.0 Nm Torque Request (Driver)
    190.0 Nm Torque Limitation
    155.0 Nm Smoke Limitation
    16:41:43 Group 009: Injection Quantity Limitation II (Torque Limitation)
    -990.6 Nm Torque Request (Cruise Control)
    496.0 Nm Transmission Limitiation
    154.0 Nm Torque Restriction
    Thursday,30,January,2014,16:42:28:32264
    16:42:27 Group 010: Charge Pressure Control
    456.2 mg/str Mass Air Flow (actual)
    1009.2 mbar Atmospheric Pressure
    1050.8 mbar Boost Pressure (actual)
    16:42:27 Group 011: Charge Pressure Control
    1051.0 mbar Boost Pressure (specified)
    85.0 % Charge Pressure Control Duty Cycle
    16:42:27 Group 012: Glow Plugs
    11111111 Glow Status
    0.00 s Pre-Glow Period
    14.229 V Supply Voltage (Terminal 30)
    Thursday,30,January,2014,16:42:51:32264
    16:42:49 Group 013: Idle Stabilization (Injection Quantity Deviation)
    -0.25 mg/str Injection Quantity Deviation Cyl. 1
    0.06 mg/str Injection Quantity Deviation Cyl. 2
    0.08 mg/str Injection Quantity Deviation Cyl. 3
    0.09 mg/str Injection Quantity Deviation Cyl. 4
    16:42:49 Group 015: Fuel Consumption
    38.8 Nm Engine Torque
    0.67 l/h Fuel Consumption
    16:42:49 Group 016: Auxiliary Heating
    29.8 % Generator Load
    Shut-Off Status Aux. Heater
    Heater Element Activation
    14.118 V Supply Voltage (Terminal 30)
    Thursday,30,January,2014,16:43:16:32264
    16:43:14 Group 017: Readiness Code (EOBD)
    00000000 EOBD/CARB Mode 01 DATA A
    00000110 EOBD/CARB Mode 01 DATA B
    10000000 EOBD/CARB Mode 01 DATA C
    10000000 EOBD/CARB Mode 01 DATA D
    16:43:14 Group 018: Piezo Unit Injector Status
    0.0 Injector Status Cylinder 1
    0.0 Injector Status Cylinder 2
    0.0 Injector Status Cylinder 3
    0.0 Injector Status Cylinder 4
    16:43:14 Group 020: Injection Quantity Limitation (from ABS)
    801 /min Engine Speed (G28)
    39.1 Nm Engine Torque
    1023.5 Nm ASR Limitation
    0.0 Nm MSR Limitation
    Thursday,30,January,2014,16:43:58:32264
    16:43:56 Group 023: Unit Injector Switching Time Deviation
    0.21 ms Switch Time Deviat. Cylinder 1
    0.22 ms Switch Time Deviat. Cylinder 2
    0.21 ms Switch Time Deviat. Cylinder 3
    0.21 ms Switch Time Deviat. Cylinder 4
    16:43:56 Group 025
    OFF Terminal 50 Status
    Idle Engine Status
    237.0 Start Abort Conditions
    16:43:56 Group 028: Accelerator Pedal Position Sensor
    0.756 V Accel. Pedal Pos. Sensor 1 (G79)
    0.375 V Accel. Pedal Pos. Sensor 2 (G185)
    Thursday,30,January,2014,16:45:05:32264
    16:45:03 Group 029: Temperature and Oil Level Sensor (TOG)
    78.0°C Oil Temperature
    29.0 mm Oil Level
    0 km Wear Index
    0 km Soot Index
    16:45:03 Group 062: Engine Cooling (Temperatures)
    85.0°C Coolant Temp. Engine Outlet
    25.0°C Coolant Temp. Radiator Outlet
    3.0°C Ambient Temperature
    29.0°C Intake Air Temperature (G42)
    16:45:03 Group 064: Engine Cooling
    85.0°C Coolant Temperature (G62)
    9.8 % Coolant Fan 1 Duty Cycle
    Thursday,30,January,2014,16:46:28:32264
    16:46:26 Group 090: EOBD/OBD-2 Exhaust Gas Recirculation (EGR) I
    800 /min Engine Speed (G28)
    6.1 mg/str Injection Quantity
    00000000 Status Control Deviation
    16:46:26 Group 091: EOBD/OBD-2 Exhaust Gas Recirculation (EGR) II
    100.0 % Positive Control Deviation
    -100.0 % Negative Control Deviation
    -55.0 % Control Deviation
    16:46:26 Group 093: EOBD pTn-Diagnose
    00000000 pTn Status
    0.92 pTn Ratio
    12.29 g/s Average Mass Air Flow
    11.24 g/s Mass Air Flow (calculated)
  1. A6 C6 VCDS Changes - Post & Pre Facelift
    By MFGF in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-11-2022, 09:33 PM
  2. VCDS OR VAG CAN Commander
    By Tariq Malik in forum VCDS - Help Requests
    Last Post: 12-03-2010, 03:02 PM
  3. VCDS Apprentice
    By johnvw in forum VCDS - Help Requests
    Last Post: 10-03-2010, 10:32 AM
  4. Can VCDS check cruise control ?
    By BILKO1 in forum VCDS - Help Requests
    Last Post: 23-10-2009, 03:21 PM
  5. VCDS for SKC?
    By k6rff in forum VCDS - Help Requests
    Last Post: 13-10-2009, 10:43 PM
