Thread: Do You have VCDS
Results 11 to 20 of 28
  1. Re: Do You have VCDS
    Oct 2009
    Staines, UK
    Quote Originally Posted by martin1810 View Post
    "I notice that Group 29 above has no soot and wear values for my oil, perhaps thats a feature of me being on longlife servicing? (or it has no soot & wear!)"
    This is the sort of thing I am trying to find out about. My BKC on longlife has soot & wear figures but the other two logs don't have a value. That's why I need as many logs as possible.
    Hmmmmmm. I almost certain I've seen a soot figure for mine somewhere. It might have been a calculated value rather than a sensor driven one though.
    In fact I know I saw it as I remember comparing it with my dads Octavia.
    I shall have another look when I get the chance.
    '56 Passat 2.0 TDi 140 SE Estate
    Fully registered VCDS HEX-USB+CAN
  2. Re: Do You have VCDS
    Oct 2009
    Staines, UK
    Might not be the same thing Martin but measuring block 16 in the instrument module gives a calculated value for "soot entry" and "thermal stress"
    016,0,Adaptation Channels 047 && 048
    016,1,Adaptation,Channel
    016,2,Soot Entry,,See Adaptation Channel 047
    016,3,Adaptation,Channel
    016,4,Thermal Load,,See Adaptation Channel 048
    A047,0,Soot Entry
    A047,5,Soot Entry
    A047,6,Arithmetic value used to calculate the amount of soot in
    A047,7,the engine oil referenced to a distance of 100 km and used
    A047,8,as comparison value for the service interval display.
    A047,9,
    A047,10,NOTE: Adaptation channels 40-49 must be
    A047,11,entered and stored in the following order:
    A047,12,45 > 42 > 43 > 44 > 49 > 40 > 41 > 46 > 47 > 48
    A048,0,Thermal Load
    A048,5,Thermal Load
    A048,6,Arithmetic value used to calculate the thermal stress of
    A048,7,the engine oil referenced to a distance of 100 km and used
    A048,8,as comparison value for the service interval display.
    A048,9,
    A048,10,NOTE: Adaptation channels 40-49 must be
    A048,11,entered and stored in the following order:
    A048,12,45 > 42 > 43 > 44 > 49 > 40 > 41 > 46 > 47 > 48
  3. Re: Do You have VCDS
    Norfolk
    That looks like where the calculations are done for the service interval based on engine load etc. Can't see any values though.
  4. Re: Do You have VCDS
    Aug 2007
    Ware, Herts
    When the above readings were taken for my BMR engine my service display showed 223days /11630miles left to next service. As I have done 7100miles since my last service 520days ago it shows its heading for the full 18k/2yr interval with no deduction for type of driving. So possibilites for the zero wear & soot are: Too far away from next service or no wear/soot values due to driving pattern. Favour the latter. Perhaps I will try and borrow the VCDS just before the next service in feb 11
  5. Re: Do You have VCDS
    Norfolk
    07 Passat SEL Sport TDI 170 BMR
    Group 001:
    Injection Quantity Measurement Type Value
    1 Engine Speed (G28) 802 /min
    2 Injection Quantity 5.0 mg/str
    3 Injection Duration (specified) 3.9°KW
    4 Coolant Temperature (G62) 89.0°C
    Group 002:
    Idle Speed
    1 Engine Speed (G28) 801 /min
    2 Accel. Pedal Pos. Sensor 1 (G79) 0.00%
    3 Operation Status 1000
    Group 003:
    Exhaust Gas Recirculation (EGR)
    1 Engine Speed (G28) 798 /min
    2 Exhaust Gas Recirculat. (spec.) 280.0 mg/str
    3 Exhaust Gas Recirculat. (actual) 274.1 mg/str
    4 Exhaust Gas Recirc. Duty Cycle 52.60%
    Group 004:
    Pump-Jet Valves 803 /min
    1 Engine Speed (G28) 5.0 °ATDC
    2 BTDC Injection Start (specified) 3.9°KW
    3 Injection Duration (specified) 0.74°
    4 Torsion Value
    Group 005:
    Start Conditions (last Engine Start)
    1 Engine Speed (G28) 800 /min
    2 Start Injection Quantity 0.0 Nm
    3 Start Synchronisation 255
    Group 006:
    Cruise Control System (CCS)
    1 Vehicle Speed (actual) 0.0 km/h
    2 Pedal Monitoring 00001000
    3 Accel. Pedal Pos. Sensor 1 (G79) 0.0%
    4 Switch Monitoring 0
    Group 007: Temperatures
    1 Fuel Temperature (G81) 73.0°C
    2 Fuel Cooling status
    3 Intake Air Temperature (G72) 42.0°C
    Group 008: Injection Quantity Limitation I (Torque Limitation)
    1 Engine Speed (G28) 804 /min
    2 Torque Request (Driver) 0.0 Nm
    3 Torque Limitation 170.0 Nm
    4 Smoke Limitation 137.7 Nm
    804 /min
    Group 009: Injection Quantity Limitation II (Torque Limitation)
    2 Torque Request (Cruise Control) -993.6 Nm
    3 Transmission Limitation 1024.0 Nm
    4 Torque Restriction 137.7 Nm
    Group 010: Charge Pressure Control
    1 Mass Air Flow (actual) 284.0 mg/str
    2 Atmospheric Pressure 1016.8 mbar
    3 Boost Pressure (actual) 1003.2 mbar
    4 Accel. Pedal Pos. Sensor 1 (G79) 0.0%
    Group 011: Charge Pressure Control
    2 Boost Pressure (specified) 1003.2 mbar
    4 Charge Pressure Control Duty Cycle 85.00%
    Group 012: Glow Plugs
    1 Glow Status 11111111
    2 Pre-Glow Period 0.0 s
    3 Supply Voltage (Terminal 30) 13.664 V
    Group 013: Idle Stabilization (Injection Quantity Deviation)
    1 Injection Quantity Deviation Cyl. 1 0.36 mg/str
    2 Injection Quantity Deviation Cyl. 2 0.20 mg/str
    3 Injection Quantity Deviation Cyl. 3 -0.74 mg/str
    4 Injection Quantity Deviation Cyl. 4 0.16 mg/str
    Group 015:
    Fuel Consumption
    2 Engine Torque 37.7 Nm
    3 Fuel Consumption 1.31 l/h
    4 Torque Request (Driver) 0.0 Nm
    Group 016:
    Auxiliary Heating
    1 Generator Load 36.90%
    2 Auxiliary Heating,Shut-Off Conditions 11000001
    3 Heating Element Activation 0
    4 Supply Voltage (Terminal 30) 13.552 V
    Group 017: Readiness Code (EOBD)
    1 CARB Mode 01 DATA A 00000000
    2 CARB Mode 01 DATA B 00000110
    3 CARB Mode 01 DATA C 11100000
    4 CARB Mode 01 DATA D 00000000
    Group 018:
    Injector Status
    1 Injector Status Cylinder 1 0
    2 Injector Status Cylinder 2 0
    3 Injector Status Cylinder 3 0
    4 Injector Status Cylinder 4 0
    Group 019
    1 137.50 V
    2 133.25 V
    3 137.75 V
    4 134.25 V
    Group 020: Injection Quantity Limitation (from ABS)
    2 Engine Torque 37.1 Nm
    3 ASR Limitation 1024.0 Nm
    4 MSR Limitation 0.0 Nm
    Group 021: CAN-Databus Status (Powertrain)
    1 Engine Electronics 00000000
    2 Transmission Electronics 01000000
    3 Brake Electronics 00000000
    4 Brake Electronics (ESP) 00000100
    Group 022: Shut-Off Status
    1 Shut-Off Status Cruise Control 1
    2 Switch Monitoring Cruise Control 0
    3 Shut-Off Status Charge Pressure 0
    4 Shut-Off Status Climate Control 0
    Group 023:
    Injector Switch Time Deviation
    1 Switch Time Deviat. Cylinder 1 0.21 ms
    2 Switch Time Deviat. Cylinder 2 0.21 ms
    3 Switch Time Deviat. Cylinder 3 0.21 ms
    4 Switch Time Deviat. Cylinder 4 0.21 ms
    Group 024
    1 729
    2 746
    3 748
    4 759
    Group 025
    1 Engine Speed (G28) 799 /min
    2 Status Terminal 50 OFF
    3 Engine Condition Idle
    4 Start Cancel Conditions 237
    Group 027
    1
    2
    3 0.0 km/h
    4 300.0 km/h
    Group 028: Accelerator Pedal Position Sensor
    1 Accel. Pedal Pos. Sensor 1 (G79) 0.750 V
    2 Accel. Pedal Pos. Sensor 2 (G185) 0.375 V
    3 Operation Status 00001000
    Group 029: Temperature and Oil Level Sensor (TOG)
    1 Oil Temperature 90.0°C
    2 Oil Level 26.0 mm
    3 Wear Index 0 km
    4 Soot Index 0 km
    Group 30
    1 Resistance 69 ohms
    2 -0.01
    3 Lambda, 0.80%
    4 1
    Group 31
    1 Count, 8
    2 Duty Cycle 60.20%
    3 Voltage 0.927 V
    4 Voltage 2.842 V
    Group 32
    1 Count 8
    2 Temperature 20.2°C
    3 Pressure 1027.5 mbar
    4 Voltage 2.842 V
    Group 33
    1 RPM 804 /min
    2 Temperature 5.0 mg/str
    3 Pressure 10
    4 Mass Flow 4.25
    Group 041
    1 Duty Cycle 96.00%
    2 Duty Cycle 54.30%
    3 Lambda 54.50%
    4 Lambda 17.50%
    Group 042
    1 Voltage 0.726 V
    2 Bits 0
    3 Lambda 96.00%
    4 Lambda 54.50%
    43
    1 Lambda 85.10%
    2 Lambda 85.00%
    3 Voltage 3.515 V
    4 Voltage 3.515 V
    Group 044
    1 798 /min
    2 Mass Air / Rev 270.4 mg/str
    3 0
    4 5.00%
    Group 045
    1
    2 Pressure 0.0 mbar
    3 Mass Flow 7.41 g/s
    4 Absolute Pres 1003.0 mbar
    Group 046
    1 Duty Cycle 96.00%
    2 Duty Cycle 96.00%
    3 Lambda 95.80%
    4 Lambda -12.40%
    Group 047
    1 Voltage 0.512 V
    2 Voltage 4.628 V
    3 Lambda -11.90%
    4 Lambda 95.80%
    Group 051: Engine Speed Recognition
    1 Engine Speed 803 /min
    2 Camshaft Speed 401 /min
    4 Shut-Off Status Injection Sequence 0
    Group 053
    1 0.050 Nm
    2 0.049 Nm
    3 0.051 Nm
    4 0.050 Nm
    Group 054
    1 5.25
    2 5.51
    3 5.39
    4 5.64
    Group 062:
    Engine Cooling (Temperatures)
    1 Coolant Temperat. Engine Output 89.0°C
    2 Coolant Temperat. Cooler Output 87.0°C
    3 Ambient Temperature 20.2°C
    4 Intake Air Temperature 42.0°C
    Group 063:
    Engine Cooling (Climate Control)
    1 Refrigerant Pressure 7.00 bar
    2 Load Torque 0.0 Nm
    3 Cooling Request 1.20%
    Group 064:
    Engine Cooling
    1 Coolant Temperature (G62) 89.0°C
    3 Coolant Fan 1 Duty Cycle 10.20%
    Group 67
    1 Temperature 157.0°C
    2 Temperature 182.6°C
    3 Absolute Pres 10.4 mbar
    4 Pressure -1 mbar
    Group 68
    1 Lambda 18.30%
    2 33.35
    3 Lambda -11.30%
    Group 71
    1 RPM 801 /min
    2 Inj. Quantity 0.0 mg/str
    3 Ign. Timing 44.0 °ATDC
    4 Idle Stabilization 0.0°KW
    Group 73
    1 Tank Cont 15.7 l
    2 Mileage 232 km
    3 3 h
    Group 74
    1 RPM 803 /min
    2 Temperature 157.0°C
    3 4.18
    4 Inj. Quantity 0.00 mg/str
    Group 75
    2 Temperature 154.7°C
    3 Lambda 18.30%
    4 Temperature 183.3°C
    Group 090: EOBD/OBD-2 Exhaust Gas Recirculation (EGR) I
    1 Engine Speed (G28) 797 /min
    2 Injection Quantity 5.1 mg/str
    3 Exhaust Gas Recirculat. (spec.) 280.0 mg/str
    4 Status Control Deviation 0
    Group 091
    1 Lambda 100.00%
    2 Lambda -100.00%
    3 Mass Air / Rev 280.0 mg/str
    4 Lambda -0.40%
    Group 093
    1 0
    2 0.99
    3 Mass Flow 7.18 g/s
    4 Mass Flow 16.00 g/s
    Group 115
    1 Lateral Accel. 3.00 m/s^2
    2 Torque -28.0 Nm
    3 Torque 0.0 Nm
    4 Torque 0.0 Nm
    Group 117
    1 0
    2 99
    3 Lateral Accel. 3.00 m/s^2
    4 Lateral Accel. 0.00 m/s^2
    Group 131
    1 0
    2 Inj. Quantity 5.1 mg/str
    3
    4 Temperature 89.0°C
    Group 133
    1 Engine Speed (G28) 803 /min
    2 Mass Air / Rev 283.1 mg/str
    3 Absolute Pres. 1003.4 mbar
    4 0
    Group 150
    2 Torque 0.0 Nm
    3 255
    Group 151
    2 Torque 37.6 Nm
    3 Torque 169.6 Nm
    4 Torque 137.7 Nm
    Group 152
    1 Engine Speed (G28) 794 /min
    2 Torque -3.0 Nm
    3 Torque 38.5 Nm
    4 Load 37.30%
    Group 154
    2 Mass Air / Rev. 280.0 mg/str
    3 Mass Air / Rev. 266.9 mg/str
    4 Duty Cycle 51.10%
    Group 155
    2 800 /min
    3 1000
    4 Duty Cycle 0.00%
    Group 156
    2 Speed 300.0 km/h
    3 Speed 0.0 km/h
    4 Torque 37.5 Nm
    Group 157
    2 Time 0.00 s
    3 Temperature 89.0°C
    4 11111111
    Group 158
    1 Engine Speed (G28) 795 /min
    2 Torque 0.0 Nm
    3 Torque 38.6 Nm
    4 0
    Group 161
    2 29
    3 Tank Cont 15.7 l
    4 Mileage 232 km
    Group 165
    1 800 /min
    2 Lambda 52.00%
    3 Mass Air / Rev. 288.2 mg/str
    4 Duty Cycle 54.30%
    Group 166
    2
    3 Absolute Pres 1003.5 mbar
    4 Lambda 3.515 V
    Group 167
    2 73.0°C
    4 Temperature
    Group 168
    1
    2 Voltage 0.750 V
    3 Voltage 0.375 V
    4 Duty Cycle 0.00%
    Group 194
    3 Speed 0.0 km/h
    4 Temperature 90.0°C
    Group 213
    1 Engine Speed (G28) 796 /min
    2 Duty Cycle 0.00%
    3 Speed 0.0 km/h
    4 (no units), 0
    Group 235
    2 Lambda 52.80%
    3 Mass Air / Rev 279.2 mg/str
    4 Duty Cycle 53.60%
    Group 236
    2
    3 Pressure 6.80 bar
    4 no units 0
    Group 237
    2
    3 Absolute Pres 1003.7 mbar
    4 Voltage 3.515 V
    Group 238
    2
    3 Load 38.40%
    4 Voltage 13.664 V
    Group 239
    2
    3 Mass Air / Rev 274.0 mg/str
    4 Voltage 13.664 V
    Group 240
    2
    3 Mass Air / Rev 270.7 mg/str
    4 Duty Cycle 96.00%
    Group 241
    2
    3 Temperature 90.0°C
    4 Voltage 13.664 V
    Group 242
    2
    4 Voltage 13.552 V
    Group 243
    2
    3 Bin. Bits 11111111
    4 Voltage 13.552 V
    Group 244
    2
    4 Duty Cycle 12.90%
    Group 245
    2
    3 Mass Air / Rev 278.3 mg/str
    4 Voltage 13.552 V
    Group 246
    2
    4 Voltage 13.552 V
    Group 247
    2
    3 Bin. Bits 11000001
    4 Voltage, 13.664 V
    Group 248
    2
    4 Voltage 13.552 V
    Group 252
    1 Airbag 1
    2
    3
    4 HVAC 1
    courtesy TomboyC
  6. Re: Do You have VCDS
    Jun 2010
    lisboa portugal
    I would like to send you my data blocks from my car but dont know how, once I have it in excel
  7. Re: Do You have VCDS
    #17
    Jun 2011
    Barnsley, UK
    06 Passat SE 2.0 TDI 140 BKP
    Thursday,07,July,2011,19:53:39:26365
    VCDS Version: Release 805.0
    Data version: 20080625
    Address 01: Engine (03G 906 018 CE)
    19:53:25 Group 001
    799 /min RPM
    4.9 mg/str Inj. Quantity
    3.0°KW Idle Stabilization
    86.0°C Temperature
    19:53:25 Group 002
    801 /min RPM
    0.0 % Duty Cycle
    00001000 Bin. Bits
    86.0°C Temperature
    19:53:25 Group 003
    801 /min RPM
    1388.8 mg/str Mass Air / Rev.
    410.6 mg/str Mass Air / Rev.
    0.0 % Duty Cycle
    19:54:21 Group 004
    798 /min RPM
    4.0 °ATDC Ign. Timing
    3.2°KW Idle Stabilization
    1.49° Steering Angle
    19:54:21 Group 005
    800 /min RPM
    0.0 Nm Torque
    255.0 (no units)
    86.0°C Temperature
    19:54:21 Group 006
    0.0 km/h Speed
    00001000 Bin. Bits
    0.0 % Duty Cycle
    00000000 Bin. Bits
    19:54:48 Group 007
    72.0°C Temperature
    45.0°C Temperature
    87.0°C Temperature
    19:54:48 Group 008
    799 /min RPM
    0.0 Nm Torque
    190.0 Nm Torque
    126.7 Nm Torque
    19:54:48 Group 009
    801 /min RPM
    -990.6 Nm Torque
    1024.0 Nm Torque
    126.7 Nm Torque
    19:54:53 Group 010
    403.8 mg/str Mass Air / Rev.
    985.4 mbar Absolute Pres.
    1002.6 mbar Absolute Pres.
    0.0 % Duty Cycle
    19:54:53 Group 011
    801 /min RPM
    1002.2 mbar Absolute Pres.
    80.0 % Lambda
    19:54:53 Group 012
    11111111 Bin. Bits
    0.00 s Time
    14.003 V Voltage
    87.0°C Temperature
    19:55:05 Group 013
    -0.05 mg/str Inj. Quantity
    -0.62 mg/str Inj. Quantity
    0.06 mg/str Inj. Quantity
    0.61 mg/str Inj. Quantity
    19:55:05 Group 015
    800 /min RPM
    33.2 Nm Torque
    0.57 l/h Fuel Consump.
    0.0 Nm Torque
    19:55:05 Group 016
    33.3 % Load
    11000001 Bin. Bits
    252 Count
    14.003 V Voltage
    19:55:18 Group 017
    00000000 Bin. Bits
    00000110 Bin. Bits
    10000000 Bin. Bits
    00000000 Bin. Bits
    19:55:18 Group 018
    0.0 (no units)
    0.0 (no units)
    0.0 (no units)
    0.0 (no units)
    19:55:18 Group 020
    800 /min RPM
    33.6 Nm Torque
    1024.0 Nm Torque
    0.0 Nm Torque
    19:55:28 Group 021
    00000000 Bin. Bits
    01000000 Bin. Bits
    00000000 Bin. Bits
    00000100 Bin. Bits
    19:55:28 Group 022
    1 Count
    0.0 (no units)
    0.0 (no units)
    0.0 (no units)
    19:55:28 Group 023
    0.22 ms Time
    0.21 ms Time
    0.21 ms Time
    0.21 ms Time
    19:55:41 Group 025
    802 /min RPM
    Idle
    237.0 (no units)
    19:55:41 Group 028
    0.750 V Voltage
    0.375 V Voltage
    00001000 Bin. Bits
    0.0 % Duty Cycle
    19:55:41 Group 029
    83.0°C Temperature
    29.4 mm Content
    0 km Mileage
    0 km Mileage
    19:56:04 Group 039
    19:56:04 Group 040
    19:56:04 Group 041
    96.0 % Duty Cycle
    0.0 % Duty Cycle
    -0.1 % Lambda
    -10.0 % Lambda
    19:56:13 Group 042
    0.629 V Voltage
    00000000 Bin. Bits
    96.0 % Lambda
    -0.1 % Lambda
    19:56:13 Group 044
    796 /min RPM
    413.5 mg/str Mass Air / Rev.
    0.0 (no units)
    19:56:13 Group 045
    0.0 mbar Pressure
    10.64 g/s Mass Flow
    19:56:26 Group 046
    96.0 % Duty Cycle
    96.0 % Duty Cycle
    95.8 % Lambda
    -9.4 % Lambda
    19:56:26 Group 047
    0.507 V Voltage
    4.628 V Voltage
    -9.5 % Lambda
    95.8 % Lambda
    19:56:26 Group 050
    19:56:44 Group 051
    800 /min RPM
    400 /min RPM
    255.0 (no units)
    00000000 Bin. Bits
    19:56:44 Group 055
    00000000 Bin. Bits
    00100000 Bin. Bits
    19:56:44 Group 056
    00100000 Bin. Bits
    00100000 Bin. Bits
    19:56:55 Group 062
    87.0°C Temperature
    52.0°C Temperature
    19.5°C Temperature
    47.0°C Temperature
    19:56:55 Group 063
    8.00 bar Pressure
    0.0 Nm Torque
    0.0 % Duty Cycle
    0.0 (no units)
    19:56:55 Group 064
    87.0°C Temperature
    52.0°C Temperature
    9.8 % Duty Cycle
    19:57:53 Group 089
    00000000 Bin. Bits
    00000110 Bin. Bits
    10000000 Bin. Bits
    00000000 Bin. Bits
    19:57:53 Group 090
    799 /min RPM
    5.0 mg/str Inj. Quantity
    00000000 Bin. Bits
    19:57:53 Group 091
    100.0 % Lambda
    -100.0 % Lambda
    -58.9 % Lambda
    19:58:10 Group 093
    00000000 Bin. Bits
    0.95 (no units)
    10.79 g/s Mass Flow
    10.39 g/s Mass Flow
  8. Re: Do You have VCDS
    #18
    Jun 2010
    lisboa portugal
    06 Passat Variant 2.0 TDI 140 BKP
    Address 01: Engine (03G 906 018 CD)
    Group 1
    800 /min RPM
    4.5 mg/s Mass Air
    2.9°KW Idle Sta
    86.0°C Temperature
    Group 2
    803 /min RPM
    0.0 % Duty Cyc
    1000 Bin. Bit
    86.0°C Temperature
    Group 3
    800 /minRPM
    260.0 mgMass Air
    257.3 mgMass Air
    18.8 % Lambda
    Group 4
    800 /min RPM
    3.9 °ATD Ign. Tim
    2.9°KW Idle Sta
    -0.35° Steering Angle
    Group 5
    800 /min RPM
    0.0 Nm Torque
    255.0 (no unit
    86.0°C Temperature
    Group 6
    0.0 km/h Speed
    1000 Bin. Bit
    0.0 % Duty Cyc
    0Bin. Bits
    Group 7
    65.0°C Temperature
    21.0°C Temperature
    86.0°C Temperature
    Group 8
    798 /minRPM
    0.0 Nm Torque
    190.0 NmTorque
    143.5 NmTorque
    Group 9799 /minRPM
    -990.6 NmTorque
    1023.5 NmTorque
    143.5 NmTorque
    Group 10
    254.4 mgMass Air
    1003.8 mAbsolute
    1004.0 mAbsolute
    0.0 % Duty Cycle
    Group 11
    798 /minRPM
    1003.7 mAbsolute
    1003.7 mAbsolute
    75.0 % Lambda
    Group 12
    11111111 Bin. Bit
    0.00 s Time
    14.229 V Voltage
    86.0°C Temperature
    Group 13
    -0.42 mgInj. Qua
    -0.16 mgInj. Qua
    0.25 mg/Inj. Qua
    0.34 mg/Inj. Quantity
    Group 15
    806 /minRPM
    28.4 Nm Torque
    0.48 l/hFuel Com
    0.0 Nm Torque
    Group16
    33.7 % Load
    14.118 VVoltage
    Group 17
    0 Bin. Bit
    110 Bin. Bit
    10000000 Bin. Bit
    0 Bin. Bits
    Group 18
    0.0 (no unit
    0.0 (no unit
    0.0 (no unit
    0.0 (no units)
    Group 20
    800 /minRPM
    29.1 Nm Torque
    1023.5 NTorque
    0.0 Nm Torque
    Group21
    0 Bin. Bit
    1000000 Bin. Bit
    0 Bin. Bit
    100 Bin. Bits
    Group 22
    1Count
    0.0 (no unit
    0.0 (no unit
    0.0 (no units)
    Group 23
    0.22 ms Time
    0.22 ms Time
    0.22 ms Time
    0.22 ms Time
    Group 25
    808 /minRPM
    OFF
    Idle
    237.0 (no units)
    Group 27
    0.0 km/hSpeed
    300.0 kmSpeed
    Group 28
    0.742 V Voltage
    0.371 V Voltage
    1000 Bin. Bit
    0.0 % Duty Cycle
    Group 29
    76.0°C Temperat
    29.0 mm Content
    0 km Mileage
    0 km Mileage
    Group 51
    798 /minRPM
    798 /minRPM
    255.0 (no unit
    0 Bin. Bits
    Group 55
    0 Bin. Bit
    100000 Bin. Bits
    Group 56
    100000 Bin. Bit
    100000 Bin. Bit
    Group 57
    B0C7ABDD Bin. Bits
    Group 62
    86.0°C Temperat
    25.0°C Temperat
    16.5°C Temperat
    21.0°C Temperature
    Group 63
    5.00 barPressure
    0.0 Nm Torque
    0.0 % Duty Cyc
    0.0 (no units)
    Group 64
    86.0°C Temperat
    25.0°C Temperat
    9.8 % Duty Cyc
    Group 86
    10011 Bin. Bit
    1000 Bin. Bit
    101011 Bin. Bit
    Group 89
    0 Bin. Bit
    110 Bin. Bit
    10000000 Bin. Bit
    0 Bin. Bits
    Group 90
    802 /minRPM
    4.5 mg/sMass Air
    260.0 mgMass Air
    0 Bin. Bits
    Group 91
    100.0 % Lambda
    -100.0 %Lambda
    260.0 mgMass Air
    -0.1 % Lambda
    Group 93
    0 Bin. Bit
    1.07 (no unit
    6.97 g/sMass Flo
    11.40 g/Mass Flow
    Group 125
    ABS 1
    Instrume
    Airbag 1
    Group 126
    HVAC 1
    Group 127
    El.Ign.L
    St. Whee
    Group 128
    Gateway
    Parking
    Group 131
    0.0 (no unit
    4.5 mg/sMass Air
    86.0°C Temperature
    Group 133
    803 /minRPM
    254.4 mgMass Air
    1004.0 mAbsolute
    0.0 (no units)
    Group 134
    33.7 % Load
    14.229 VVoltage
    Group 140
    110 Bin. Bit
    0 Bin. Bits
    Group 150
    800 /minRPM
    0.0 Nm Torque
    255.0 (no unit
    86.0°C Temperature
    Group 151
    807 /minRPM
    29.0 Nm Torque
    190.0 NmTorque
    143.5 NmTorque
    Group 152
    803 /minRPM
    -2.9 Nm Torque
    29.1 Nm Torque
    33.3 % Load
    Group 154
    797 /minRPM
    260.0 mgMass Air
    261.2 mgMass Air
    14.1 % Lambda
    Group 155
    798 /minRPM
    800 /minRPM
    1000Bin. Bit
    0.0 % Duty Cycle
    Group 156
    802 /minRPM
    300.0 kmSpeed
    0.0 km/hSpeed
    29.1 Nm Torque
    Group 157
    799 /minRPM
    0.00 s Time
    86.0°C Temperat
    11111111Bin. Bits
    Group 158
    797 /minRPM
    0.0 Nm Torque
    29.8 Nm Torque
    0.0 (no units)
    Group 161
    800 /minRPM
    Group 165
    809 /minRPM
    OFF
    260.0 mgMass Air
    15.1 % Lambda
    Group 166
    798 /minRPM
    OFF
    1003.2 mAbsolute
    75.0 % Lambda
    Group 167
    799 /minRPM
    OFF
    65.0°C Temperat
    86.0°C Temperature
    Group 168
    0.742 V Voltage
    0.371 V Voltage
    0.0 % Duty Cycle
    Group 169
    0 Bin. Bit
    Group 200
    0.0 (no unit
    Group 213
    801 /minRPM
    0.0 % Duty Cyc
    0.0 km/hSpeed
    0.0 (no units)
    Group 225
    0.0 (no unit
    0.0 (no unit
    0.0 (no units)
    Group 226
    0.0 (no unit
    Group 227
    0.0 (no unit
    0.0 (no units)
    Group 228
    0.0 (no unit
    0.0 (no units)
    Group 235
    800 /minRPM
    OFF
    257.8 mgMass Air
    13.4 % Lambda
    Group 236
    805 /minRPM
    OFF
    5.20 barPressure
    0.0 (no units)
    Group 237
    793 /minRPM
    OFF
    1003.2 mAbsolute
    75.0 % Lambda
    Group 238
    800 /minRPM
    OFF
    33.7 % Load
    14.118 VVoltage
    Group 239
    809 /minRPM
    OFF
    259.6 mgMass Air
    14.118 VVoltage
    Group 240
    797 /minRPM
    OFF
    264.3 mgMass Air
    14.118 VVoltage
    Group 241
    805 /minRPM
    OFF
    86.0°C Temperat
    14.118 VVoltage
    Group 242
    796 /minRPM
    OFF
    86.0°C Temperat
    14.118 VVoltage
    Group 243
    798 /minRPM
    OFF
    11111111 Bin. Bit
    14.118 VVoltage
    Group 244
    807 /minRPM
    OFF
    86.0°C Temperat
    9.8 % Duty Cycle
    Group 252
    Airbag 1
    Cent. El
    HVAC 1
  9. Re: Do You have VCDS
    #19
    Nov 2011
    Chile
    Dear Martin1810,
    I have a VCDS and a 1.9 TDI PD engine in my car. Is it useful for you?
    By the way, I run into a blog of yours about a Passat 1.9 TDI PD remapping: the best and more tech site I have seen for this cars, please, allow me to congratulate you and to say tks for sharing that valuable info with us.
    My wish is remapp my Octavia 1.9 TDI PD BXE to get more HP and more mileage. Do you think it is possible?
    Sincerely,
    Oldbeaver (newbee in this forum)
  10. Re: Do You have VCDS
    #20
    Norfolk
    The 1.9 tdi PD BXE will happily be mapped from 105 hp to 130hp. Driven carefully it will still produce good fuel consumption.
  1. A6 C6 VCDS Changes - Post & Pre Facelift
    By MFGF in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-11-2022, 09:33 PM
  2. VCDS OR VAG CAN Commander
    By Tariq Malik in forum VCDS - Help Requests
    Last Post: 12-03-2010, 03:02 PM
  3. VCDS Apprentice
    By johnvw in forum VCDS - Help Requests
    Last Post: 10-03-2010, 10:32 AM
  4. Can VCDS check cruise control ?
    By BILKO1 in forum VCDS - Help Requests
    Last Post: 23-10-2009, 03:21 PM
  5. VCDS for SKC?
    By k6rff in forum VCDS - Help Requests
    Last Post: 13-10-2009, 10:43 PM
