Thread: Fitted dis and cruise but having problems with coding etc
  1. Fitted dis and cruise but having problems with coding etc
    swindon uk
    Ok so i fitted dis and cruise today.
    Cruise working ok but cannot get dis to work.
    I got all parts from e-bay.
    New steering control module part number is - 8E0 953 549 T which replaces original unit- 8E0 953 549 S (maybe this is my problem?)
    anyway here is a scan log done before the retrofit-
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E75A499928 Mileage: 159530km/99127miles
    Address 01: Engine Labels: 03G-906-016-BLB.lbl
    Part No SW: 03G 906 016 GN HW: 028 101 211 3
    Component: R4 2,0L EDC 0000SG 9618
    Revision: 12345678 Serial number:
    Coding: 0000072
    Shop #: WSC 00487 210 88474
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 8E0-910-517.lbl
    Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT
    Component: ESP8 front H04 0180
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004401
    Shop #: WSC 06335 000 00000
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AJ
    Component: A4 Klimaautomat 2731
    Coding: 00000
    Shop #: WSC 00000
    Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
    Part No: 8E0 907 279 H
    Component: int. Lastmodul ECE 0503
    Coding: 00001
    Shop #: WSC 06335
    Address 15: Airbags Labels: 8E0-959-655-94.lbl
    Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
    Component: Airbag 9.41 H10 3230
    Revision: 91H10323 Serial number: 0036M002P0R%
    Coding: 0033622
    1 Fault Found
    01794 - Control Module - Incorrect Chassis (VIN) Number
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00110000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 99
    Time Indication: 0
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 S
    Component: Lenksáulenmodul 0611
    Coding: 01001
    Shop #: WSC 06335
    Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
    Part No SW: 8E0 920 950 S HW: 8E0 920 950 S
    Component: KOMBI+WFS 4 H12 0040
    Revision: 0040 Serial number: 00000000000000
    Coding: 0006441
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 BM
    Component: Komfortgerát T3B 2431
    Coding: 06907
    Shop #: WSC 06335
    Part No: 8E2959802B
    Component: Tőrsteuer.FS BRM 0205
    Part No: 8E2959801B
    Component: Tőrsteuer.BF BRM 0205
    Part No: 8E0959801A
    Component: Tőrsteuer.HL BRM 0205
    Part No: 8E0959802A
    Component: Tőrsteuer.HR BRM 0205
    1 Fault Found
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 186 D
    Component: concert II GRO 0004
    Coding: 01001
    Shop #: WSC 06335
    1 Fault Found
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    36-10 - Open Circuit - Intermittent
    Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
    Part No SW: 8E0 919 283 B HW: 8E0 919 283 B
    Component: Parkhilfe 4-Kan H06 0020
    Revision: 00H06000 Serial number: 00067802030504
    Coding: 0000104
    And this one after i attempted to code things...(notice steering wheel fault).-
    69 75 76 77
    VIN: WAUZZZ8E75A499928 Mileage: 162440km/100935miles
    Component: R4 2,0L EDC G000SG 9618
    Coding: 0000072
    Readiness: 0 0 1 1 1
    Coding: 0004401
    Coding: 00000
    Shop #: WSC 00000
    Coding: 00001
    Shop #: WSC 06335
    Coding: 0033622
    Address 16: Steering wheel Labels: 8E0-953-549-T.lbl
    Part No: 8E0 953 549 T
    Component: Lenksáulenmodul 0301
    Coding: 06021
    Shop #: WSC 00000
    3 Faults Found
    00532 - Supply Voltage B+
    53-10 - Supply Voltage Too Low - Intermittent
    01426 - Controls in Steering Wheel (E221)
    49-00 - No Communications
    01044 - Control Module Incorrectly Coded
    35-00 - -
    Coding: 0006401
    Coding: 06907
    Shop #: WSC 06335
    Part No: 8E2959802B
    Part No: 8E2959801B
    Part No: 8E0959801A
    Part No: 8E0959802A
    1 Fault Found
    35-00 - -
    Coding: 01001
    Shop #: WSC 06335
    Coding: 0000104
    Any one able to help?
    Audi A4 saloon, 2.0L tdi s-line. Retrofitted cruise control, DIS and MFSW. VCDS user.
  2. Re: Fitted dis and cruise but having problems with coding etc
    swindon uk
    Forgot to mention, 2005 A4 2.0L tdi S-Line saloon B7
  3. Re: Fitted dis and cruise but having problems with coding etc
    swindon uk
    Ok so ive figured out that 8E0 953 549 T is the steering control module for an RS4 according to etka.
    Im assuming the sccm is saying 'where is the RS4 steering wheel'?
    I only have the standard 3 spoke steering wheel.
    Can it be coded out and why does dis not work?
  4. Re: Fitted dis and cruise but having problems with coding etc
    May 2008
    I think you might struggle with the RS4 SCSM as the three spoke flat bottom RS4 wheel features different buttons to the rest of the A4 range. It has the trip computer buttons on the steering wheel, as well as the sport button. None of these feature on lower model A4's.
    If address #16 wont accept the correct coding for your car (use long coding helper or look it up on the ross tech wiki) then you need a non-RS4 SCSM.
  5. Re: Fitted dis and cruise but having problems with coding etc
    swindon uk
    Thanks, didn't know the RS4 had the trip computer functions on the steering wheel.
    That explains a lot.
    Probably why the dis buttons on the wiper stalk don't work.
    Oh well i'll have to keep a look out for the correct scsm.
  6. Re: Fitted dis and cruise but having problems with coding etc
    May 2007
    knee deep in clunge
    14 Post(s)
    you need revision q or r steering control unit, however s will work with dis but not for cruise
  7. Re: Fitted dis and cruise but having problems with coding etc
    swindon uk
    Yeah realised that after i pm'd you.
    Thanks anyway looks like im down another Ł150 (going to order an 'R' from audi tomorrow).
  1. How To DIS AND CRUISE RETRO FIT b6+b7
  2. cruise control/ DIS
    By winnie070383 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-05-2010, 09:54 PM
  3. Please Help retro fit dis cruise con. in n yorks
    By andymartin045 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-09-2009, 10:10 AM
  4. DIS & cruise
    By bez101 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-04-2009, 05:53 PM
  5. Newbie - a few questions about the A4 Quattro cabriolet
    By beavere38 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-03-2008, 11:24 PM
