Thread: Help please with problem on my A6 (flashing Glowplug light)
  1. Question Help please with problem on my A6 (flashing Glowplug light)
    Jan 2009
    Hi guys,
    I have an A6 2.7 TDi Quattro Sline on 2007.
    Over the last couple of weeks,when on the motorway I have noticed that the glowplug warning light flashes and the car loses power and no matter how far I press the GO pedal, it won't GO any faster!!??
    If I turn the car off and turn it back on again, it will either be ok or come back on after 10 mins or so.
    I did a VAG com print out here:
    0-Steering Angle Sensor -- Status: Cannot be reached 1100
    01-Engine -- Status: Cannot be reached 1100
    02-Auto Trans -- Status: Cannot be reached 1100
    03-ABS Brakes -- Status: Cannot be reached 1100
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: Cannot be reached 1100
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: Cannot be reached 1100
    55-Xenon Range -- Status: Cannot be reached 1100
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4F1 910 401 HW: 4F0 907 401 C
    Component: 2.7L V6TDI G000AG 0040
    Revision: --H02--- Serial number:
    Coding: 0011372
    Shop #: WSC 02334 785 00200
    VCID: DAB019486C77
    4 Faults Found:
    005659 - Glowplug for Cylinder 2 (Q11): Open Circuit
    P161B - 001 - Upper Limit Exceeded
    Freeze Frame:
    Fault Status: 01110001
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 90104 km
    Time Indication: 0
    Date: 2010.03.19
    Time: 10:40:48
    Freeze Frame:
    RPM: 924 /min
    Torque: 132.6 Nm
    Speed: 2.2 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.68 V
    Duty Cycle: 22.1 %
    Temperature: 9.0°C
    005661 - Glowplug for Cylinder 4 (Q13): Open Circuit
    P161D - 001 - Upper Limit Exceeded
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 90104 km
    Time Indication: 0
    Date: 2010.03.19
    Time: 10:40:48
    Freeze Frame:
    RPM: 924 /min
    Torque: 132.6 Nm
    Speed: 2.2 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.68 V
    Duty Cycle: 22.1 %
    Temperature: 9.0°C
    000565 - Boost Pressure: Regulation Range not Reached
    P0235 - 001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00110001
    Fault Priority: 0
    Fault Frequency: 4
    Mileage: 93148 km
    Time Indication: 0
    Date: 2010.06.27
    Time: 09:50:58
    Freeze Frame:
    RPM: 2100 /min
    Torque: 187.2 Nm
    Speed: 118.7 km/h
    Absolute Pres.: 1785.0 mbar
    Absolute Pres.: 1479.0 mbar
    (no units): 0.0
    Temperature: 28.8°C
    004472 - Linear O2 Sensor; Pump Current: Open Circuit
    P1178 - 000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00110000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 94034 km
    Time Indication: 0
    Date: 2010.07.11
    Time: 15:52:27
    Freeze Frame:
    RPM: 1638 /min
    Torque: 280.8 Nm
    Speed: 90.7 km/h
    Duty Cycle: 31.9 %
    Mass Air / Rev.: 740.3 mg/str
    (no units): 0.80
    (no units): 8.0
    Readiness: 1 1 0 0 0
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F2 910 156 E HW: 09L 927 156 C
    Component: AG6 09L 2.7 TDI 132 0010
    Revision: --H01--- Serial number: 4190058
    Coding: 0000002
    Shop #: WSC 02325 785 00200
    VCID: 2756F0BCEF85
    No fault code found.
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
    Component: ESP8 quattro H01 0060
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020876
    VCID: 66C8BDB8280F
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0220
    Revision: 31050601 Serial number: 10601000443601
    Coding: 0000147
    Shop #: WSC 00654 210 86418
    VCID: E3CE24AC5B3D
    Part No: 4F0 910 131 E
    Component: FBSAUDIC6 EZS H45 0080
    Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H01 0040
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
    Part No SW: 4F1 910 732 D HW: 4E0 035 729
    Component: Interfacebox H43 5570
    Revision: 00000000 Serial number: 350ES067691284
    Coding: 0011002
    Shop #: WSC 12345 123 12345
    VCID: 254AFAB49589
    Part No: 4F0 910 609 E
    Component: Bedienteil MMIC6H02 0060
    2 Faults Found:
    01319 - Control Module for Distance Control (J428)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 194
    Mileage: 90103 km
    Time Indication: 0
    Date: 2010.03.18
    Time: 16:14:19
    01964 - Control Module for Seat & Steering Column Memory (J136)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 194
    Mileage: 90103 km
    Time Indication: 0
    Date: 2010.03.18
    Time: 16:14:19
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 HW: 4F2 820 043 N
    Component: KLIMABETAETIGUNGH20 0170
    Revision: 00000030 Serial number: 00000000271674
    Coding: 0001302
    VCID: DBBE1C4C634D
    1 Fault Found:
    00796 - Fan for Interior Temp Sensor (V42)
    003 - Mechanical Failure - Intermittent
    Freeze Frame:
    Fault Status: 00100011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 171
    Mileage: 93669 km
    Time Indication: 0
    Date: 2010.07.08
    Time: 17:46:57
    Freeze Frame:
    Voltage: 13.20 V
    Temperature: 35.0°C
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 K HW: 4F0 907 279
    Component: ILM Fahrer H17 0240
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0013122
    Shop #: WSC 00681 210 91829
    VCID: 31621EE4D141
    Part No: 4F2 910 113 A
    Component: Wischer AudiC6 H04 0190
    Coding: 00064784
    Shop #: WSC 00681
    Part No: 4E0 910 557 A
    Component: REGENLICHTSENSORH12 0090
    Coding: 00146221
    Shop #: WSC 00681
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
    Component: CD-Changer H44 0470
    Revision: 00000000 Serial number: AUZ5ZBF8129823
    Shop #: WSC 00000 000 00000
    VCID: 1C3CDF50A6C3
    Address 15: Airbags Labels: 4F0-910-655-8R.lbl
    Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
    Component: 4E AIRBAG AUDI8RH29 0280
    Revision: 08H29000 Serial number: 0037LD0EZWGC
    Coding: 0013381
    VCID: 2952F684F991
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenksäulenmodul H08 0230
    Revision: 00H08000 Serial number: 90025061490208
    Coding: 0102142
    Shop #: WSC 02323 785 00200
    VCID: E6C83DB8A80F
    Part No: XXXXXXXXXXX
    Component: Lenkradmodul H07 0090
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 930 C HW: 4F0 920 981 F
    Component: KOMBIINSTR. M73 H18 0070
    Revision: 00000000 Serial number: 5HS54VX56
    Coding: 2113443
    Shop #: WSC 00726 210 88151
    VCID: 234EE4AC9BBD
    Address 19: CAN Gateway Labels: 4F0-910-468.lbl
    Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
    Component: Gateway H11 0070
    Revision: 11 Serial number: 13008065238135
    Coding: 6CFE73C41B3104
    VCID: 2756F0BCEF85
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
    Component: MNS ECE H52 1060
    Revision: 00000000 Serial number: 364LW057512456
    Shop #: WSC 00681 210 85507
    VCID: 3B7E3CCC030D
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
    Component: TSG FA H12 0120
    Revision: 00000000 Serial number: g'e
    Coding: 0003706
    Shop #: WSC 02327 785 00200
    VCID: 2C5C0F90F663
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
    Component: Komfortgeraet H22 0170
    Revision: 01700022 Serial number: 01014154720000
    Coding: 0142075
    VCID: 2E580598C07F
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    Address 47: Sound System Labels: 4F0-910-223-BO.lbl
    Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
    Component: DSP-High C6 H09 0240
    Revision: PROD_01 Serial number: 00000000002481
    Coding: 0000113
    Shop #: WSC 02324 785 00200
    VCID: 254AFAB49589
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H10 0080
    Revision: Serial number: 00000000243290
    Coding: 0001103
    Shop #: WSC 02335 785 00200
    VCID: DEB81558705F
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
    Component: TSG BF H12 0120
    Revision: 00000000 Serial number: VIe
    Coding: 0003706
    VCID: 2C5C0F90F663
    Address 53: Parking Brake Labels: 4F0-910-801.lbl
    Part No SW: 4F0 910 801 B HW: 4F0 907 801 A
    Component: EPB CB4C0060 H04 0060
    Revision: --H04---
    Coding: 0000521
    VCID: 1F46E85CB7D5
    Address 55: Xenon Range Labels: 4F0-910-357.lbl
    Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
    Component: AFS 1 H01 0020
    Revision: 00000001 Serial number:
    Coding: 0000016
    VCID: 2952F684F991
    Part No: 4F0 941 329 B
    Component: AFS-Modul links H02 0020
    Component: AFS-Modul rechtsH02 0020
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4F0 035 541 E
    Component: TUNER EU/US/RDW H42 0630
    Revision: 00000000 Serial number: 352DZ067645975
    Coding: 0000001
    VCID: 31621EE4D141
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: J0644 BEM H12 0590
    Revision: 00000000 Serial number: 00000000046352
    VCID: 234EE4AC9BBD
    Part No: 4F0 915 105 D
    Component: von VA0 2606020951
    Coding: 344630393135313035442056413032363036303230393531
    Shop #: WSC 00000 512 00290
    5 Faults Found:
    02272 - Quiescent Current Stage 1
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 12
    Mileage: 90103 km
    Time Indication: 0
    Date: 2010.03.18
    Time: 15:40:57
    02273 - Quiescent Current Stage 2
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 7
    Mileage: 90103 km
    Time Indication: 0
    Date: 2010.03.18
    Time: 15:51:17
    02276 - Quiescent Current Stage 5
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 5
    Mileage: 90103 km
    Time Indication: 0
    Date: 2010.03.18
    Time: 15:51:27
    02274 - Quiescent Current Stage 3
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 4
    Mileage: 90103 km
    Time Indication: 0
    Date: 2010.03.18
    Time: 16:16:02
    02277 - Quiescent Current Stage 6
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 4
    Mileage: 90103 km
    Time Indication: 0
    Date: 2010.03.18
    Time: 16:16:12
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
    Component: TSG HL H21 0050
    Coding: 0003114
    VCID: 2E580598C07F
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
    Component: TSG HR H21 0050
    Coding: 0003114
    VCID: 2E580598C07F
    Address 77: Telephone Labels: 4E0-910-336.lbl
    Part No SW: 4E0 910 336 M HW: 4E0 862 335
    Component: Handyvorb2 H13 1130
    Revision: 00000000 Serial number: 00000007542955
    Coding: 0010920
    VCID: 2C5C0F90F663
    Anyone give me any advice please?!! - it's driving me crazy!!!
  2. Re: Help please with problem on my A6 (flashing Glowplug light)
    Oct 2009
    Dublin Ireland
    I had a similar problem with my '05 A6 2,7 tdi Avant. It turned out to be the Turbocharger. I sourced a new unit from STK Turbo Technik. Best price I could find. €650.00 + €35.00 for shipping. It is now running perfectly. This may be of help. Regards
    Fergus
  3. Smile Re: Help please with problem on my A6 (flashing Glowplug light)
    Apr 2007
    hi same problem with my a4 2005 19tdi in warrenty fitted a new brake light switch problem gone running great hope this will help peter
  4. Thumbs up Re: Help please with problem on my A6 (flashing Glowplug light)
    Jan 2009
    Hi Walshy.
    Mine is sorted now, it was a split hose that went from the Turbo to the (rad?) i think....
    anyway, £45 for part and £70 fitting (not audi!) all the front had to come off..
    all back to normal now anyway!
  5. Re: Help please with problem on my A6 (flashing Glowplug light)
    Sep 2009
    Broxburn
    Yes this would check - it does go to the radiator but not as you think - the turbocharger is a device that increases the air to the engine by using the exhaust to spin a turbine that compresses the intake. this also increases the air temperature so it is passed through an intercooler (basically an air radiator) to cool down the air which is then fed to the engine.
    If the pipe splits then the compressed air escapes and you end up with an unboosted engine, which feels lethargic !
    2014 Andi 3.0 V6 TDi S-Line Quattro
    Full LeatherIHeated SeatsIElectric SeatsISunroofIMatt Brushed Aluminium InlaysIBi-Xenon HeadlightsIRear Park AssistIBluetooth
  1. HID Aftermarket kits - Not Legal....
    By RickT in forum Chat - Anything with wheels
    Last Post: 13-05-2011, 12:44 PM
  2. caddy glow plug/brake light problem
    By bruwalsh in forum The Commercial Range
    Last Post: 24-02-2011, 12:00 PM
  3. "How To" change a rear light bulb on an A3
    By djgilson in forum Audi
    Last Post: 16-04-2010, 03:54 PM
  4. ABS light on with flashing red brake light
    By P471 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-11-2007, 09:26 PM
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
