Thread: injector removal
  1. injector removal
    Dec 2007
    hi. could anyone tell me if there is a special tool for removing the injectors from my 2.5 t4 engine code ajt. i,v removed the injector pipes and the clamps that hold the injectors in but the injectors won,t budge.
  2. Smile Re: injector removal
    Apr 2010
    Manchester UK
    Not sure, there might be a special tool but I use my cheap ol' grips lock them up as tight as I can on the injector body, tap them up left and right pull a bit tap again ...
    they always come off in the end :-)
  3. Re: injector removal
    Dec 2007
    hi George thanks for your reply. i got them out in the end by locking a pair of mole grips on them and twisting them. bit like a dentist would twist a tooth out. anyway job done. thanks again.
