Thread: audi 3.0tdi engine measurement blocks
Results 1 to 10 of 19
  1. audi 3.0tdi engine measurement blocks
    st pierre, France
    hi All,
    i just invested in Ross tech SW/cable and I can now be super smart when I arrive at the dealer on Monday morning for my long standing car cutting out when warm problem.
    However, I wonder does anyone have a list of the measurement blocks and what they represent? Some are obvious but many are not.
    Anyway the 1 that sticks out like a sore thumb is measurement block 20.
    It shows 1 of them reading -40 C !!! I think second from left.
    Bearing in mind it's a 34 C day out there I somewhat doubt that is correct.
    Can anyone shed light on these measurement blocks for me? They appear to not be in agreement with the ross tech wiki on the subject... which I notice says petrol engines
    cheers
    WJAM
  2. Re: audi 3.0tdi engine measurement blocks
    May 2007
    knee deep in clunge
    14 Post(s)
    vcds does not always read true compared to vas as I have also found.
    post your engine code and I will post all mvb and what they are.
    Since ross tech removed the log files from there site its become harder to source the mvb but I have all of them for vw and audi.
  3. Re: audi 3.0tdi engine measurement blocks
    st pierre, France
    Hi A8 tech
    Many thanks! The engine code is BKN...
    Let me know if you need any more info..
    best regards
    WJAM
  4. Re: audi 3.0tdi engine measurement blocks
    May 2007
    knee deep in clunge
    14 Post(s)
    Display groups for 3.0 L TDI CR as at 22.01. 2008
    Audi A4
    001 Quantity adjustment
    1) Engine speed
    At idle: 720 ... 820 rpm
    2) Injection quantity
    At idle: 4 ... 10,5 mg/stroke
    3) Rail pressure actual
    Check values with measured value block 022
    4) Coolant temperature
    Warmed-up: 70 ... 110 °C
    002 Idling speed
    1) Engine speed
    2) Accelerator pedal position
    At idle: 0 %
    At full throttle: 100%
    3) Pedal switch settings
    X X 1 Idling speed switch ON
    X 1 X Kickdown switch ON
    1 X X Idling speed increased
    003 Exhaust gas recirculation
    1) Engine speed
    2) Specified intake air mass
    [mg/stroke]
    3) Actual air mass
    [mg/stroke]
    4) EGR valve activation
    004 Main injection
    1) Engine speed
    2) Main injection, start of activation
    [°CA]
    3) Main injection, duration of activation
    [ms]
    4) Rail pressure actual
    005 Starting conditions
    Stored from last engine start
    1) Engine speed
    [rpm]
    2) Starting injection quantity
    [mg/stroke]
    3) Start synchronisation
    000 Basic initialisation
    001 Reset counter
    002 Engine standstill or fault
    003 Transitional states
    004 Plausibility check phase
    005 Plausibility check phase
    006 Plausibility check phase
    008 Plausibility check phase
    016 Phase definition
    032 Synchronisation phase
    033 System positioning
    048 Calculation sequences activated --> Start OK
    064 System waiting for engine standstill
    128 Dynamic plausibility check
    [°C]
    006 Cruise control system CCS
    1) Vehicle speed
    CCS activatable: above 35 km/h
    2) CCS status
    X X X X X X X 1 Brake light switch pressed
    X X X X X X 1 X Brake pedal switch pressed
    X X X X X 1 X X Clutch pedal switch pressed
    X X X X 1 X X X CCS enabled
    X X X 1 X X X X ACC enabled
    X X 0 X X X X X Main switch
    0 0 X X X X X X ACC/CCS mode inactive
    1 0 X X X X X X State overspill
    0 1 X X X X X X ACC/CCS in control range
    1 1 X X X X X X ACC not enabled
    3) CCS target speed
    [km/h]
    4) CCS switch settings
    X - X X X X X 1 Locked ON
    X - X X X X 1 X Touched OFF
    X - X X X 1 X X Touch-Down, reduce
    X - X X 1 X X X Touch-Up, increase
    X - X 1 X X X X Set
    X - 1 X X X X X Resume
    1 - X X X X X X Locked ON from hardware
    007 Temperature senders
    1) Fuel temperature
    to 70 °C
    2) Oil temperature
    3) Intake air temperature
    to 75 °C
    008 Limiting torques
    1) Engine speed
    [rpm]
    2) Internal torque
    [Nm]
    3) Torque limitation
    [Nm]
    4) Smoke limitation
    [Nm]
    009 Limiting torques
    1) Engine torque specification
    [Nm] Driver input via accelerator pedal
    2) Limiting torque gearbox control unit
    [Nm] during gearshifting
    3) Limiting torque MSR
    [Nm] of engine drag torque control
    4) Limiting torque TCS
    [Nm] of traction control
    010 Air quantities
    1) Actual air mass
    At idle: 210 ... 280 mg/stroke
    At full throttle: > 1050 mg/stroke
    At ambient air pressure 970 ... 1020 mbar
    2) Ambient air pressure
    [mbar]
    3) Actual charge pressure
    At idle: 950 ... 1080 mbar
    At full throttle: > 2150 mbar
    4) Accelerator pedal position
    - With exhaust gas recirculation switched off, e.g. due to
    high intake air temperature the air mass at idle may be increased
    In this case press the accelerator in short bursts and check
    whether the air mass then decreases.
    - Additionally check air mass via basic setting of EGR
    and turbocharger basic setting.
    011 Charge pressure control
    1) Engine speed
    [rpm]
    2) Specified charge pressure
    [mbar]
    4) Charge pressure adjuster specification
    012 Preheating system
    1) Preheating system status
    0 0 0 0 0 0 0 0 Waiting for coolant temperature
    0 0 0 0 0 0 0 1 Waiting for start request
    0 0 0 1 0 0 0 0 Glow period
    0 1 0 1 0 0 0 0 No glow
    1 0 1 1 0 0 0 0 After-glow
    1 1 0 0 0 0 0 0 No start glow
    1 1 1 1 0 0 0 0 Intermediate glow
    0 0 1 1 0 0 0 0 Readiness glow
    0 1 1 1 0 0 0 0 Start glow
    1 0 1 1 0 0 0 1 Waiting for after-glow
    1 1 0 1 0 0 0 0 No after-glow
    1 1 1 1 0 0 0 1 Waiting for intermediate glow
    1 1 1 1 1 1 1 1 No glow
    2) Glow period
    [s]
    3)Vehicle voltage
    [V]
    [°C]
    013 Smooth running control
    1)Cyl. 1 Injection quantity variation
    [mg/stroke]
    2)Cyl. 2 Injection quantity variation
    [mg/stroke]
    3)Cyl. 3 Injection quantity variation
    [mg/stroke]
    4) Vacant
    Permissible values at idle: +- 2,99 mg/stroke
    A If the permissible tolerance is exceeded
    first check injector IQA-IVA adaption values
    014 Smooth running control
    1)Cyl. 4 Injection quantity variation
    [mg/stroke]
    2)Cyl. 5 Injection quantity variation
    [mg/stroke]
    3)Cyl. 6 Injection quantity variation
    [mg/stroke]
    4) Vacant
    015 Fuel consumption
    1) Engine speed
    [rpm]
    [mg/stroke]
    3) Fuel consumption
    [ltr/h]
    4) Engine torque specification
    016 Additional heater
    1) Vacant
    2) Additional heater shut-off conditions
    0 0 0 0 0 0 0 0 No shut-off condition
    0 0 0 0 0 0 0 1 Coolant temperature
    adequate
    0 0 0 0 0 0 1 0 Alternator load signal error
    0 0 0 0 0 1 0 0 Battery voltage too high
    0 0 0 0 1 0 0 0 Engine speed too low
    0 0 0 1 0 0 0 0 Start delay active
    0 0 1 0 0 0 0 0 Water temperature sensor, air temperature
    sensor or output stage defective
    0 1 0 0 0 0 0 0 Operating switch (not active)
    1 0 0 0 0 0 0 0 Intake manifold temperature adequate
    3) Additional heater relay activation
    0 0 Relay not activated
    0 1 Low heat output relay
    1 0 High heat output relay
    1 1 Both relay contacts active
    4) Vehicle voltage (to 11.2005)
    [V]
    4) Alternator DF signal (from 11.2005)
    [%] Alternator load
    017 Readiness code
    1) EOBD data A
    X 0 0 0 0 0 0 0 No fault messages stored in engine control unit
    0 X X X X X X X Emissions warning lamp (MIL) OFF
    1 X X X X X X X Emissions warning lamp (MIL) ON
    2) EOBD data B
    - X X - - X X 1 Misfire monitoring activated
    - X X - - 1 X X Complete system monitoring activated
    - X 0 - - X X X EOBD test fuel system completed with OK
    - 0 X - - X X X EOBD test overall system completed with OK
    3) EOBD data C
    X X X X - X X 1 Catalytic converter monitoring activated
    X X X X - X 1 X Catalytic converter hot monitoring activated
    X X X X - 1 X X Evaporation system monitoring activated
    X X X 1 - X X X Air conditioner coolant monitoring activated
    X X 1 X - X X X Lambda probe monitoring activated
    X 1 X X - X X X Lambda probe heating monitoring activated
    1 X X X - X X X EGR monitoring activated
    4) EOBD data D
    0 - - - - - - X EOBD test EGR completed with OK
    018 Throttle valve
    Only for throttle valves with 4 cables on connector
    If 5 cables, see measured value block 038
    1) Engine speed
    [rpm]
    2) Throttle valve activation
    [°C]
    4) Actual air mass
    [mg/stroke]
    019 Fan activation
    1) Coolant temperature
    [°C]
    2) Air conditioner fan activation
    3) Radiator fan 1 activation
    4) Radiator fan 2 activation
    020 AC compressor
    1) Ambient temperature
    [°C]
    2) Vacant
    3) AC compressor shut-off status 1
    X X X X X X X 1 Vehicle starting off
    X X X X X X 1 X Shut-off due to starting off state
    X X X X X 1 X X Vehicle acceleration
    status
    X X X X 1 X X X Shut-off due to acceleration
    X X X 1 X X X X Shut-off due to starting
    X X 1 X X X X X System fault detected
    X 1 X X X X X X Shut-off due to system fault
    1 X X X X X X X Shut-off due to inadequate idling
    speed
    4) AC compressor shut-off status 2
    X X X X X X X 1 Shut-off due to excessive coolant temperature
    X X X X X X 1 X Shut-off by gearbox control unit
    X X X X X 1 X X Shut-off by ABS/ESP control unit
    X X X X 1 X X X Shut-off due to refrigerant pressure or
    ambient temperature
    X X X 1 X X X X Power reduction due to overheating
    X X 1 X X X X X Shut-off due to fault in a radiator fan
    X 1 X X X X X X Shut-off due to fault in both radiator fans
    1 X X X X X X X Minimum on-time
    022 Rail pressure control
    1) Engine speed
    2) Specified rail pressure
    [bar]
    [bar]
    4) Pressure regulating valve activation
    At idle: 15 ... 30 %
    - Values for warmed-up engine
    - Permissible difference between specified and actual value at
    Idle: maximum +-20 bar
    023 Rail quantity control
    1) Engine speed
    4) Quantity adjuster valve activation
    At idle: 35 ... 48 %
    024 Pre-injection 1
    1) Engine speed
    [rpm]
    2) Pre-injection 1 start of activation
    [°CA]
    3) Pre-injection 1 duration of activation
    [ms]
    025 Pre-injection 2
    1) Engine speed
    [rpm]
    2) Pre-injection 2 start of activation
    [°CA]
    3) Pre-injection 2 duration of activation
    [ms]
    026 Post-injection 1
    1) Engine speed
    [rpm]
    2) Post-injection 1 start of activation
    [°CA]
    3) Post-injection 1 duration of activation
    [ms]
    029 Adaptive cruise control ACC
    1) ACC specification adjustment
    001 Specification adjustment free-wheeling
    002 Specification adjustment ON
    003 Specification adjustment OFF
    2) ACC status
    X X X X X X 0 0 ACC inactive
    X X X X X X 0 1 ACC active
    X X X X X X 1 0 ACC passive
    X X X X X X 1 1 ACC initialisation
    X X X X X 0 X X No neutral value
    X X X X X 1 X X Neutral value
    X X 0 X X X X X Not permitted
    X X 1 X X X X X Permitted
    3) Vehicle speed
    [km/h]
    4) Vacant
    030 Accelerator pedal position
    1) Accelerator pedal sender 1
    [V]
    2) Accelerator pedal sender 2
    [V]
    3)Switch settings
    032 Camshaft edges (from 11.2005)
    1) Engine speed
    [rpm]
    2) Start synchronisation
    001 Reset counter
    3) Camshaft edge 1
    [°CA]
    4) Camshaft edge 2
    [°CA]
    034 Charge pressure control
    1) Engine speed
    2) Charge pressure adjuster specification
    At idle: 20 ... 80 %
    3) Charge pressure adjuster actual value
    At idle: 19 ... 81 %
    4) Actual charge pressure
    [mbar]
    035 Temperature protection
    1) Engine speed
    2) Exhaust gas temperature before turbocharger
    At idle: 140 ... 310 °C (with radiator fluid > 75 °C)
    At full throttle: 540 ... 830 °C
    3) Exhaust gas governing factor
    At idle: 99 ... 101 % or 0.99 ... 1,01
    4) Overall governing factor
    036 Intake manifold flap bank 1
    1) Engine speed
    2) Intake manifold flaps bank 1 specification
    3) Intake manifold flaps bank 1 actual value
    4) Actual air mass
    [mg/stroke]
    Idle: maximum +/- 2 %
    037 Intake manifold flap bank 2
    1) Engine speed
    2) Intake manifold flaps bank 2 specification
    3) Intake manifold flaps bank 2 actual value
    4) Actual air mass
    [mg/stroke]
    038 Throttle valve
    Only for throttle valves with 5 cables on connector
    If 4 cables, see measured value block 018
    1) Engine speed
    [rpm]
    2) Throttle valve activation control motor
    3) Throttle valve specification
    4) Throttle valve actual
    040 Lambda probe
    1) Probe calibration value internal resistance
    [%] to 11.2005
    [Ohm] from 11.2005
    2) Oxygen signal
    [V]
    3) Oxygen concentration
    4) Oxygen signal calibration status
    0 inactive
    1 active
    041 Lambda probe
    1) Air mass throughput
    2) Probe heater activation
    3) Probe temperature signal
    [V]
    4) Lambda signal
    042 Lambda probe
    2) Ambient temperature
    [°C]
    3) Lambda probe pressure
    [mbar]
    4) Oxygen concentration
    [mV]
    043 Lambda probe
    1) Engine speed
    [rpm]
    2) Exhaust gas temperature at lambda probe
    [°C]
    3) Exhaust gas counterpressure
    [mbar]
    4) Exhaust gas mass flow
    044 Lambda probe
    1) Engine speed
    [rpm]
    2) Lambda probe electronics
    X X X X X X X 1 Full throttle regulator on/off
    X X X X X X 1 X Full throttle
    X X X X X 1 X X Control deviation negative, i.e. mixture too rich
    X X X X 1 X X X System fault
    X X X 1 X X X X Oxygen signal invalid or no correction
    by lambda probe adaption
    X X 1 X X X X X Engine starting
    X 1 X X X X X X Torque limitation or quantity limitation active
    1 X X X X X X X Regeneration exhaust gas treatment
    3) Lambda probe plausibility check
    001 Current oxygen concentration implausibly high
    002 Current oxygen concentration implausibly low
    004 Oxygen concentration stationary
    008 Plausibility checking enabled
    016 Oxygen concentration zero
    032 In last time interval no rich operation
    4) Lambda probe diagnosis
    004 Dynamics of signal too low
    008 Cable open circuit
    016 Oxygen signal in overrun implausibly low
    032 Oxygen signal in overrun implausibly high
    064 Oxygen signal at part throttle implausibly low
    128 Oxygen signal at part throttle implausibly high
    051 Speed recording
    1) Engine speed
    [rpm]
    2) Camshaft speed
    [rpm]
    001 Reset counter
    4) Injection sequence shut-off status
    0 0 0 0 0 0 0 1 Defective external watchdog
    0 0 0 0 0 0 1 0 Invalid engine speed
    0 0 0 0 0 0 1 1 Run-on
    0 0 0 0 0 1 0 0 Shut-off request for time-sync.
    shut-off
    0 0 0 0 0 1 0 1 Solenoid valve fault
    0 0 0 0 0 1 1 0 Overrun
    0 0 0 1 0 0 0 0 Minimum post-injection quantity
    not reached
    0 0 1 0 0 0 0 0 Minimum post-injection duration
    not reached
    0 1 0 0 0 0 0 0 Deactivation of post-injection via
    Speed
    1 0 0 0 0 0 0 0 Deactivation of post-injection due to
    Error
    056 Rail pressure control (from 11.2005)
    If not available, see measured value block 110
    1) Engine speed
    [rpm]
    2) Fuel temperature
    [°C]
    3) Rail pressure control status
    0 Ignition on, open-loop control mode
    4 Closed-loop control via pressure regulating valve
    (normal operating mode)
    5 Closed-loop control via solenoid valve
    7 Open-loop control (engine is stopped)
    15 Closed-loop control via pressure regulating valve and
    metering unit
    4) Vacant
    058 Engine mounting
    1) Engine speed
    [rpm]
    2) Vehicle speed
    [km/h]
    3) Engine mounting valve, right
    0 = Off
    1 = On
    4) Engine mounting valve, left
    0 = Off
    1 = On
    060 Ancillaries
    1) Engine speed
    [rpm]
    2) Indexed engine torque
    [Nm]
    3) Engine torque loss
    [Nm]
    4) Ancillaries
    [Nm]
    061 Ancillaries
    1) Engine torque loss
    [Nm]
    2) Internal friction torque
    [Nm]
    3) AC compressor torque
    [Nm]
    4) Alternator output
    [W]
    070 Zero quantity calibration ZQC
    1) ZQC learning cycle counter 1st calibration pressure
    2) ZQC learning cycle counter 2nd calibration pressure
    3) ZQC learning cycle counter 3rd calibration pressure
    4) Vacant
    072 Zero quantity calibration ZQC
    1) ZQC cyl. 1 Activation time 1st calibration pressure
    [ms]
    2) ZQC cyl. 1 Activation time 2nd calibration pressure
    [ms]
    3) ZQC cyl. 1 Activation time 3rd calibration pressure
    [ms]
    4) Vacant
    073 Zero quantity calibration ZQC
    1) ZQC cyl. 2 Activation time 1st calibration pressure
    [ms]
    2) ZQC cyl. 2 Activation time 2nd calibration pressure
    [ms]
    3) ZQC cyl. 2 Activation time 3rd calibration pressure
    [ms]
    4) Vacant
    074 Zero quantity calibration ZQC
    1) ZQC cyl. 3 Activation time 1st calibration pressure
    [ms]
    2) ZQC cyl. 3 Activation time 2nd calibration pressure
    [ms]
    3) ZQC cyl. 3 Activation time 3rd calibration pressure
    [ms]
    4) Vacant
    075 Zero quantity calibration ZQC
    1) ZQC cyl. 4 Activation time 1st calibration pressure
    [ms]
    2) ZQC cyl. 4 Activation time 2nd calibration pressure
    [ms]
    3) ZQC cyl. 4 Activation time 3rd calibration pressure
    [ms]
    4) Vacant
    076 Zero quantity calibration ZQC
    1) ZQC cyl. 5 Activation time 1st calibration pressure
    [ms]
    2) ZQC cyl. 5 Activation time 2nd calibration pressure
    [ms]
    3) ZQC cyl. 5 Activation time 3rd calibration pressure
    [ms]
    4) Vacant
    077 Zero quantity calibration ZQC
    1) ZQC cyl. 6 Activation time 1st calibration pressure
    [ms]
    2) ZQC cyl. 6 Activation time 2nd calibration pressure
    [ms]
    3) ZQC cyl. 6 Activation time 3rd calibration pressure
    [ms]
    4) Vacant
    095 Starter control
    1) Terminal 50
    0 or 1
    2) P/N signal
    Only vehicles with automatic gearbox
    Signal from selector lever switch
    Interlock signal
    Only vehicles with manual gearbox
    Signal from clutch pedal switch for engine start
    0 or 1
    3) Vacant
    4) Vacant
    096 Starter control
    1) Terminal 50-back
    0 or 1
    2) Vacant
    3) Starter control shut-off conditions
    X X X X X X X 1 Start rejection speed reached
    X X X X X X 1 X Road speed threshold
    surpassed
    X X X X X 1 X X Maximum start time depending on glow period
    surpassed
    X X X X 1 X X X Maximum start time exceeded
    X X X 1 X X X X Terminal 15 deactivated
    X X 1 X X X X X Terminal 15 lock
    X 1 X X X X X X Terminal 50 or 50-back missing
    1 X X X X X X X Starter activated, but engine
    speed is 0 rpm
    4)Vehicle voltage
    [V]
    100 Emergency regeneration
    Only on vehicles with particulate filter
    Note:
    Starting emergency regeneration is only possible via Guided Fault Finding
    if the <emergency regeneration> test procedure was
    entered in the test plan.
    1) Engine speed
    In emergency regeneration: approx. 1500 rpm
    2) Exhaust gas temperature before particulate filter
    Regeneration active: above 550 °C
    Max. permissible: 820 °C
    Abort: 720 °C exceeded for more than 12 sec.
    3) Em.regen. current duration
    0 ... 255
    Total duration: 10 to 40 minutes, depending on loading state
    4) Em. regen. Abort detected
    0 = Not aborted
    1 = Aborted
    101 Emergency regeneration
    Note:
    With this measured value block fault causes can be located
    if the emergency regeneration was aborted by the engine control unit
    1) Em. regen. Enable conditions 1
    Before start of emergency regeneration:
    0 0 0 0 0 0 0 0 OK, because no emergency regeneration active
    After start of emergency regeneration:
    1 1 1 1 1 1 1 1 All enable conditions 1 OK
    X X X X X X X 1 Minimum waiting time before start of emergency regeneration
    with engine running was observed
    X X X X X X 1 X Coolant temperature above 70 °C
    X X X X X 1 X X Oil temperature above 70 °C
    X X X X 1 X X X Ambient air pressure high enough
    X X X 1 X X X X Fuel temperature below 70 °C
    X X 1 X X X X X Battery voltage adequate
    X 1 X X X X X X No clutch pressed
    1 X X X X X X X No gear engaged
    2) Em. regen. Enable conditions 2
    1 1 1 1 1 1 1 1 All enable conditions 2 OK
    X X X X X X X 1 Road speed = 0
    X X X X X X 1 X Engine speed in range
    X X X X X 1 X X Injection quantity in permissible range
    X X X X 1 X X X Accelerator pedal not pressed
    X X X 1 X X X X Particulate filter temperature in permissible range
    X X 1 X X X X X Pre-catalyst temperature in permissible range
    X 1 X X X X X X Soot mass in particulate filter in permissible
    Range
    1 X X X X X X X No fault memory entries leading to
    disabling of emergency regeneration
    3) Em. regen. Abort conditions
    X X X X X 1 After monitoring time temperatures not
    reached
    --> Cause: Consumers not switched on,
    ambient temperature too cold
    X X X X 1 X Temperature for particulate filter exceeded
    X X X 1 X X Temperature for pre-catalyst exceeded
    X X 1 X X X Abort via enable conditions
    --> See zone 1 or 2
    X 1 X X X X Abort due to total regeneration time
    1 X X X X X Abort by diagnostic tester
    4) Em. regen. Phase
    000 Start emergency regeneration or not activated
    001 Warm-up
    010 Regeneration active
    100 Cool-down
    102 Exhaust gas cleaning
    1) Exhaust gas temperature after pre-catalyst (to 11.2005)
    At idle: 90 ... 270 °C
    At full throttle: 490 ... 830 °C
    1) Exhaust gas temperature before pre-catalyst (from 11.2005)
    [°C] Calculated value
    At idle: 70 ... 250 °C
    3) Particulate filter differential pressure
    0 ... 950 mbar
    4) Differential pressure offset particulate filter
    [mbar]
    103 Field regeneration
    1) Regeneration mode
    0 = No field regeneration active
    1...100 = Regeneration stages
    2) Regeneration request
    X X X 1 Counter request active
    X X 1 X Request by fuel consumption
    X 1 X X Request by operating time
    1 X X X Request by distance driven
    3) Engine running time since last successful
    Regeneration (from 11.2005)
    [s]
    4) Regeneration disable
    X 1 Regeneration disabled
    1 X Maximum regeneration time elapsed
    104 Particulate filter
    1) Oil ash
    [Ltr]
    2) Soot mass calculated
    [g]
    Displayed value is only valid when the engine has been
    running for at least 5 minutes.
    3) Soot mass measured
    [g]
    Notes as field 2)
    4) Distance since last regeneration
    [km]
    107 Particulate filter (from 11.2005)
    1) Vacant
    2) Loading limit 3
    [g]
    - Value changes according to software part number
    - If this limit is exceeded, the engine switches
    to emergency running and the fault memory entry
    "Particulate filter overloaded" is stored
    3) Loading limit 1
    [g]
    - If this limit is exceeded, an attempt is made
    to start field regeneration (during driving)
    4) Exhaust gas volumetric flow particulate filter
    [m^3/h]
    Calculated value
    110 Rail pressure control (to 11.2005)
    If not available, see measured value block 056
    1) Engine speed
    [rpm]
    2) Fuel temperature
    [°C]
    metering unit
    4) Vacant
    125 CAN communication
    1) CAN communic. Automatic gearbox
    2) CAN communic. ABS/ESP
    3) CAN communic. Instrument cluster
    4) CAN communic. AC
    0 = inactive
    1 = active
    126 CAN communication
    1) CAN communic. ACC
    2) Vacant
    3) CAN communic. Airbag
    4) Vacant
    0 = inactive
    1 = active
    127 CAN communication
    1) Vacant
    2) Vacant
    3) CAN communic. Steering column module
    4) Vacant
    0 = inactive
    1 = active
    CAN = Controller Area Network
    The CAN bus is a network for local interconnection of
    control units.
    1 1 0
  5. Re: audi 3.0tdi engine measurement blocks
    st pierre, France
    Dude! you are a star!
    Many many thanks.
    Looks like the -40 is vacant.. so it's nonsense.
    Good to know
    thanks again
    Aaron
  6. Re: audi 3.0tdi engine measurement blocks
    st pierre, France
    Ok I did a comprehensive check of the engine measurement blocks with the car warmed up.
    2 notables..
    003 EGR
    engine speed 756 1100 1900 2300
    specified intake air mass 534 329 517 1198
    actual air mass 423 440 470 580
    Err that can't be right! Does it look like a MAF is telling the EGR a load of rubbish? Or am I misinterpreting??
    Also air mass at idle is not even close to the specified 210 to 280 mg/stroke
    So this lead on to 022 Rail pressure control (at idle)
    specified pressure 227
    actual fluctuating form 220 to 235
    THEN
    Car tried to die, but the engine caught itself on and stayed running
    BUT
    022
    specified pressure now 482 bar
    Actual fluctuating from 460 to 480 bar
    Now that is weird, but could be related to mad MAF??
    I have all the fuel pressure related error codes
    004195 - Fuel Pressure Regulation: Control Range Not Reached
    P1063 - 006 - Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00110011
    Fault Priority: 0
    Fault Frequency: 9
    Mileage: 143934 km
    Time Indication: 0
    Freeze Frame:
    RPM: 672 /min
    Torque: 128.7 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.76 V
    Pressure: 106.5 bar
    Duty Cycle: 20.5 %
    P1063 - 005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 9
    Mileage: 143934 km
    Time Indication: 0
    Freeze Frame:
    RPM: 672 /min
    Torque: 128.7 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.76 V
    Pressure: 106.5 bar
    Duty Cycle: 20.5 %
    001025 - EGR System: Insufficient Flow
    P0401 - 002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Status: 01110010
    Fault Priority: 0
    Fault Frequency: 5
    Mileage: 144050 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1722 /min
    Torque: 113.1 Nm
    Speed: 43.7 km/h
    Duty Cycle: 65.7 %
    Duty Cycle: 20.9 %
    Mass Air / Rev.: 581.6 mg/str
    Duty Cycle: 63.1 %
    004120 - Intake Manifold Runner (Bank 2): Lower limit not reached
    P1018 - 001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 144397 km
    Time Indication: 0
    Freeze Frame:
    RPM: 714 /min
    Torque: 85.8 Nm
    Speed: 0.0 km/h
    Voltage: 14.06 V
    Duty Cycle: 80.9 %
    Duty Cycle: 88.8 %
    Duty Cycle: 80.9 %
    Readiness: 1 2 0 0 0
    Methinks the EGR is doing mad stuff and the P1018 is also due to trying to do something impossible.. but maybe not :-|
    Anyway I am ready for the Audi franchise Monday... Any further hints tips greatly appreciated.
    ciao
    WJAM
  7. Re: audi 3.0tdi engine measurement blocks
    st pierre, France
    Oops! missed the top of the errors log
    VCDS Version: Release 10.6.0
    Address 01: Engine Labels: Redir Fail!
    Control Module Part Number: 8E0 910 401 F
    Component and/or Version: 3.0L V6TDI
    7 Faults Found:
    P1063 - 003 - Mechanical Failure - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 9
    Mileage: 143934 km
    Time Indication: 0
    Freeze Frame:
    RPM: 672 /min
    Torque: 128.7 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.76 V
    Pressure: 106.5 bar
    Duty Cycle: 20.5 %
    P1063 - 001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 9
    Mileage: 143934 km
    Time Indication: 0
    Freeze Frame:
    RPM: 672 /min
    Torque: 128.7 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.76 V
    Pressure: 106.5 bar
    Duty Cycle: 20.5 %
    P1063 - 002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 9
    Mileage: 143934 km
    Time Indication: 0
    Freeze Frame:
    RPM: 672 /min
    Torque: 128.7 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.76 V
    Pressure: 106.5 bar
    Duty Cycle: 20.5 %
    ciao
    WJAM
  8. Re: audi 3.0tdi engine measurement blocks
    My car has the same mistakes and cuts out when it is hot. How did you fixed yours?
  9. Re: audi 3.0tdi engine measurement blocks
    st pierre, France
    Hi Sedefcha
    It was the high pressure fuel pump. In fact it was the fuel metering valve into the high pressure pump, but guess what... that metering valve is not sold separately. Look for a distributor of Bosch pumps where you live and you will save a lot of money.. then find a decent independent mechanic to fit it.. Or if you can find a local Bosch specialist they may be able to repair. Mine has been perfect for 2 years since.
    good luck
    wjam
    Aaron
  10. Re: audi 3.0tdi engine measurement blocks
    Thank you for your fast replay
    I am sure that VAG and Bosch are happy to sell bigger and more expensive details... I will follow your advice and will take remanufactured pump from Bosch or will buy second hand pump. I am skilled enough to install it and still keep warranty
    Tomorrow I will only try swaping the fuel pressure regulating valve from a known good car, just to be sure.
    Interesting thing is that when i unplug the fuel pressure sensor engine stops cutting but enters limp mode and power is significantly reduced... love diesel smell
  1. The efficiency standard – the audi a8 hybrid
    Last Post: 02-03-2010, 07:58 PM
  2. New audi s4 raises the benchmark for handling dynamics
    Last Post: 12-05-2009, 08:10 PM
  3. New audi s4 raises the benchmark for handling dynamics
  4. 16 important OIL questions and answers
    By oilman in forum Archive posts
    Last Post: 25-01-2008, 12:49 AM
  5. Replies: 0
    Last Post: 29-06-2006, 08:27 PM
