Thread: Oil coming out of cam cover breather
  1. Oil coming out of cam cover breather
    Oct 2006
    My nephew overfill the engine by a litre of engine oil and ran it for over 500miles. , He only told me when oil was coming out though the cam breather into air filter and a oil leak, i have change the oil, clean up the air box and throttle, The crank case breather was full of mayo, i clean the pipe up but cant get the plastic box mounted of the engine off to clean it.
    Oil is still coming from the cam cover breather into airbox it will stop if i take the oil cap off, the car runs fine, no fault code, idle smooth, So whats causing it?
  2. Re: Oil coming out of cam cover breather
    Sep 2009
    London/Bucks England
    It may be residual oil in the breather system, i guess taking the oil cap gives it a new way to let the pressure out of the crank case
  3. Re: Oil coming out of cam cover breather
    Oct 2006
    The intake system was all clean up, oil is coming from the pipe on the cam cover itself
  4. Re: Oil coming out of cam cover breather
    Norfolk
    The one way valve in the breather is probably not working so pressure is building up in the top of the engine.
  5. Re: Oil coming out of cam cover breather
    Oct 2006
    where is the one way valve, the engine is a 1.4 8v 2001
  6. Re: Oil coming out of cam cover breather
    Norfolk
    I am not sure with that engine. If you pull the beather pipe off the cam cover, does the engine breath ok through the breather hole. If it des the valve wil be in the pipework somewhere. Keep blowing through pipes until you find something that restricts air flow.
  1. Question Car breakdwon cover who do you recomend?
    By con1981 in forum Chat - Anything with wheels
    Last Post: 02-06-2009, 01:08 PM
  2. Answers From The Oil Expert
    By oilman in forum Archive posts
    Last Post: 22-10-2007, 08:28 AM
  3. '92 MKII no oil pressure (0)!
    By 2old2turbo in forum Jetta MK2 - 1984 -1992
    Last Post: 12-10-2007, 02:30 AM
  4. '92 MkII 1.8 NO oil pressure
    By 2old2turbo in forum Golf MK2 - 1984 - 1992
    Last Post: 06-10-2007, 09:58 PM
