Thread: A/C compressor pulley/plate and bolt
Page 4 of 4 FirstFirst ... 234
Results 31 to 39 of 39
  1. Re: A/C compressor pulley/plate and bolt
    #31
    tony-1977 Guest
  2. Re: A/C compressor pulley/plate and bolt
    #32
    Sep 2008
    chester
    17 Post(s)
    Got my regas today,much better lovely cold air, 135 gramms recovered,500 recharged plus 12ml of pag,so its leaked slowly, I've had it three and a half years and its not been touched so cant complain.
  3. Re: A/C compressor pulley/plate and bolt
    #33
    tony-1977 Guest
    Well I've given up! Got it booked in to an air conditioning specialist this afternoon
    Compressor is still not engaging!
    No fault codes. Condensor plate is present and spins freely by hand. Re-gassed. No leaks. G65 sensor changed. Fuses all ok. Econ light goes out when pressed.
    Getting sick of driving round with both front windows open to keep cool!
    Got my wallet at the ready. Arrrggghhhhhhhhhh.........!!!!!!!!!
    Will keep you lot updated when I collect it later on
  4. Re: A/C compressor pulley/plate and bolt
    #34
    tony-1977 Guest
    Well that's that..... I need a new compressor There is current there, and the clutch plate is present. Just burnt out with age
    Arrrggghhhhhhh!!!!!!!!! Anyone got a compressor?!?!?!?!?
  5. Re: A/C compressor pulley/plate and bolt
    #35
    Oct 2006
    Quote Originally Posted by tony-1977 View Post
    Doh!!
    Hmm how does the compressor burn out, it has pistons like a mini engine, so long as there is gas there it should be OK, I'd expect it to get rattly before dieing!!
    Try Autoklima24 for a compressor, in germany, but seems decent, have ordered a new pulley from them this week!
    A4 Avant 1.9 TDi160 for when the weather is on the damp side - Sold after 9yrs. Now A5 3.0TDI Q Sport Coupe (310bhp/480ft/lbs - Yamaha R6 for when its dry and want some 'High octane Petrol' fun.
  6. Re: A/C compressor pulley/plate and bolt
    #36
    tony-1977 Guest
    Not sure how it burns out!! I've owned the car for a couple of months but the air con had not worked for 18 months ( I know the prev owner). All tested, all sensors OK and there is current at the compressor. Assuming internal electrical fault in comp?? Car has 148k on the clock and the prev owner NEVER had the climate control off, until it packed up.
  7. Re: A/C compressor pulley/plate and bolt
    #37
    Oct 2010
    Middx, UK
    how do you remove the compressor? I assume that the belt will have to be de-tensioned then presumably you cant run the car until the comoressor is fitted back on? Tony - did you get any pics etc of the change/repair?
    A4 B6 S-line, 90k miles
  8. Re: A/C compressor pulley/plate and bolt
    #38
    tony-1977 Guest
    Quote Originally Posted by fla View Post
    I never got the car repaired. It got written off in an accident (non fault) about a week after I posted the above message
  9. Re: A/C compressor pulley/plate and bolt
    #39
    Feb 2011
    Driffield
    Had the same problem with the middle screw unscrewing and splines on shear plate braking off. Was quoted £1165 from VW dealership. Bought a new plate from X8R on ebay for£29.99. took an hour to fit and now have perfect cold air con
  1. Aux belt tensioner bolt snapping
    By jgreenwell in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-05-2012, 08:07 PM
  2. Dropping subframe to remove lower rear control arm bolt
    By trevMk2 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-06-2010, 09:46 AM
  3. Rounded Wheel Nuts?
    By Kyojitsu in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-06-2010, 07:23 PM
  4. Question driveshaft boot
    By mickofcram in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-01-2010, 10:50 PM
  5. Polo brake caliper bolt seized
    By trevh in forum Polo - Derby - Lupo - Fox
    Last Post: 11-08-2007, 12:23 PM
