Thread: Dropping subframe to remove lower rear control arm bolt
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: Dropping subframe to remove lower rear control arm bolt
    If i remember rightly i swapped the bolts around as you say , it makes it easier to gain some purchase on the nut using a socket set that way around. i also have used all the bolts more than once without issue. tight is tight in my book plus half a turn
    here's a decent how to guide with pictures.
    http://www.myturbodiesel.com/1000q_h...controlArm.htm
  2. Thumbs up Re: Dropping subframe to remove lower rear control arm bolt
    passat 130tdi .
    Many thanks for link to the excellent "how to do it" . Will have a go at rear arm on passenger side at the weekend.
    passat tdi130
    Bath (no car lift!!)
    Drifting off topic a little bit but now found small split in ball joint gaiter on front lower control arm on driver side so suspect creaking coming from there - the guide doesnt mention spring compressors so guess that with ARB drop link disconnected the arms hinge down enough to refit shock over front control arm without needing to compress spring - can anyone advise ? ( mine is sports suspension BTW). Thanks again.
    Trevor
  3. Re: Dropping subframe to remove lower rear control arm bolt
    no need to compress the springs , you were correct in saying lever the arm down enough to pass strut over , just be sure to jack up the car on the chassis and not on any pART of the suspension .
  1. Question Lower suspension arm bush
    By talesy in forum Golf MK4 - 1999 - 2004
    Last Post: 18-09-2012, 11:39 PM
  2. New bentley continental supersports convertible
    Last Post: 02-03-2010, 08:04 PM
  3. New bentley continental supersports convertible
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
