Thread: How to access settings menu?
  1. How to access settings menu?
    May 2010
    Birmingham, UK
    Can anyone tell me how to access the settings menu on an SE? I tried following the manual, but either I don't have the option on mine, or I'm just doing something wrong.
    I want to change the doors so they all open at the same time with one press of the keyfob.
    Grateful,
    James
  2. Re: How to access settings menu?
    Oct 2009
    Staines, UK
    Unless you have the highline mfd you won't have a menu at all.
    These sorts of changes need to be done by VCDS (Vag com).
    Have a look here https://www.vwaudiforum.co.uk/forum/s...ead.php?t=5319
    There might be someone close to you who can help.
    '56 Passat 2.0 TDi 140 SE Estate
    Fully registered VCDS HEX-USB+CAN
  3. Re: How to access settings menu?
    DSG4ME Guest
    If it's a SE it'll be a midline one, and no options, way to tell is the top half only shows the door open warning.
  1. Convenience Menu
    By djah in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-05-2010, 02:20 PM
  2. Key Fob program settings
    By Malarith in forum Golf MK6 - 2009 - 2013
    Last Post: 01-04-2010, 04:27 PM
  3. Accessing hidden menu on 2g MMI
    By MarkBS in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-03-2010, 03:34 PM
  4. Mk5 TDi settings menu
    By mk5tdi in forum Golf MK5 - 2004 - 2009
    Last Post: 28-01-2010, 01:25 PM
  5. Operating the menu
    By RNTSI in forum Golf MK6 - 2009 - 2013
    Last Post: 07-11-2009, 01:37 PM
