Thread: Charge Pressure Control: Negative Deviation
  1. Charge Pressure Control: Negative Deviation
    Feb 2010
    bellshill
    Hi Guys, looking for a bit of information on the above, its actually my dads car, its an Octavia 1.9TDi ASV engine.
    When towing his caravan he has noticed lately that when faced with any incline the car 'bogs down' Iv run VCDS on it cleared all faults and given the car a good drive until the symptoms returned, re-scanned and the fault was as follows:
    1 Fault Found:
    17964 - Charge Pressure Control: Negative Deviation
    P1556 - 35-10 - - - Intermittent
    Readiness: N/A
    Any help on what is causing this would be greatly appreciated
    Thanks in advance
    Iain
  2. Re: Charge Pressure Control: Negative Deviation
    Mar 2010
    notts u.k
    Take a look here its likely a faulty N75 but there are other causes this will help you out http://wiki.ross-tech.com/wiki/index...4/P1556/005462
  3. Re: Charge Pressure Control: Negative Deviation
    Norfolk
    Probably a damaged vacuum pipe. Have a look here for further help http://sites.google.com/site/1810mar...-turbo-control
  4. Re: Charge Pressure Control: Negative Deviation
    Nov 2008
    folkestone.kent
    could also be a turbo with a snapped shaft i had that one today ,rare for it to be the turbo but worth taking the boost pipe of to check
  5. Re: Charge Pressure Control: Negative Deviation
    Nov 2008
    folkestone.kent
    you would think people would at least say thanks to forum members for helping with only 4 posts you never know when you might need helping again
  1. Fault code 462c
    By veedub76 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-06-2010, 06:23 PM
  2. Replies: 7
    Last Post: 29-11-2009, 10:25 AM
  3. auto shutdown of convenience systems
    By bigb in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 29-03-2009, 07:40 PM
  4. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
