Thread: Revs on idle
Results 1 to 8 of 8
  1. Revs on idle
    Banchory, Scotland
    1995 2.6 E Coupe, On idle i've noticed that she sits at around the 1100 rpm mark & while motoring if i take the foot off the gas even slightly there is a marked hesitation instead of a smooth decelleration, on idle prior to the below comments she idled around 800 rpm.
    I've recently added fuel additive to help with emissions on a near empty tank for the MOT, but in draining down the tank i more or less flatened the battery....Had to use a portable battery starter.
    Having read some of the comments posted previously i guess my question is, " would either the additive or flat battery contribute to this symptom ? "
    cheers,
  2. Re: Revs on idle
    Gwent
    I've read a few posts where 2.6's have idle problems after a flat battery. It seems the Throttle Position sensor is affected, and needs to be aligned. This can be done using Vag com or this DIY method may work - can't hurt to try it?
    Post by Vampire: https://www.vwaudiforum.co.uk/forum/s...ad.php?t=34879
    The ECU fuses are the big ones at the front labelled 'moteur'
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: Revs on idle
    Banchory, Scotland
    Yeah i've read the posts, thanks scotty33....looks like the battery is goosed, had it on charge all last night & this morning it looks like at least one cell is dead & it's not holding charge.....Oh well new battery needed.
    Anybody any idea of battery type, this one has no markings that i can find other than it's heavy duty ?
  4. Re: Revs on idle
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Hello lawser,just took a peep at mine ,'95 2.6 abc coupe, and it has the following written on it
    12v 74AH 680A
    Hope that helps
    Stuart
  5. Exclamation Re: Revs on idle
    Jun 2008
    Burnham
    Hello Audi lovers
    I hope it is OK to jump into others thread but why wasting server space.
    My 2.0l 16 v L reg coupe has similar issue.
    1100 steady idle.
    Very very occasionally drops back into 800 and only for maybe a half an hour.
    Any idea what to try?
    Did the ECU reset thing but nothing really changed.
    The throttle position sensor clicks properly and upon driving the rev falls back nicely no hesitation or playing up and down.
    Just sits at 1100 idle
    Thank you in advance!
    Norbee
  6. Re: Revs on idle
    Banchory, Scotland
    Sorry forgot to post back, new battery sorted out my issues, no need to reset anything....purring like a cat now !
  7. Re: Revs on idle
    Jun 2008
    Burnham
    Well my battery is only 1 years old...
    Do you think it could be alternator related?
    If not enough in the battery then ECU revs up to have enough voltage?
    Thanks for comments!
    Norbee
  8. Re: Revs on idle
    Gwent
    That sounds like the Idle Stabiliser Valve is sticking 'open'. Try soaking/flushing out the mechanical end with carb cleaner or petrol
  1. Please Help Very rough idle/ revs rising to 2000 rpm
    By Duke3d in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 15-11-2017, 10:14 PM
  2. Varying revs at fast idle ten flashing warning?
    By freddyuk in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-02-2010, 11:45 AM
  3. Revs drop at idle in cold weather with heater on.
    By Animal Man in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-01-2010, 11:14 PM
  4. Tune Weber carb (not type specific)
    By bishbosh66 in forum Volkswagen
    Last Post: 30-01-2008, 11:34 AM
  5. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
