Thread: Where is the CAN BUS gateway?
  1. Where is the CAN BUS gateway?
    Aug 2009
    london england
    Well, after my old radio/cd player died, I purchased an RCD 510 and fitted it quite easilly into the Passat.
    Three days later the battery was flat.
    After reading all the threads on this issue, I decided to go to the VW dealership in Chesterfield to ask them to fit a new CAN BUS gateway.
    they didn't know what I was talking about.
    so I went to the VW dealership in Loughborough. They also didn't know what I was talking about. In fact, they advised me that my flat battery was not a result of a new radio.
    I was so pleased with them I put the fuse back in and once again within three days, the battery was flat.
    So I have decided to go to a scrap yard and get one myself and fit it myself.
    I will also buy a Ross Tech dongle and code it myself.
    My question to those who know is:
    Where is the CAN BUS gateway....????
    My car is a 2006 VW Passat Estate 2.0 TDi
    Thanking you all in advance
  2. Re: Where is the CAN BUS gateway?
    Feb 2010
    Louth Ireland....
    Sorry to hijack, but i think an easier fix is to run an ignition wire from the fuse box on the passenger side ( black/white wire) to power the unit. Of course it will only work when ignition is on or started but may be of some help to you. I read this somewhere just recently so please correct me if i'm wrong .............
    Sure someone will be along to tell you the location anyway, but just thought i'd mention this and see where it goes...........Richie..
    Ex Passat B6 owner......to many retrofits to mention !
  3. Re: Where is the CAN BUS gateway?
    Aug 2009
    london england
    Thanks Richie...
    I know how to do this but the radio keeps turning off every 20 minutes or so which can be a real pain.
    i'm not sure a live wire will fix this
    maddogphysics
  4. Re: Where is the CAN BUS gateway?
    Oct 2009
    Staines, UK
    Its behind the air con controls and ashtray. Remember to save the old can bus coding before you do the swap
  5. Re: Where is the CAN BUS gateway?
    Aug 2009
    london england
    Got my Ross-Tech yesterday and tried it out.
    Had a few fault codes in there, in particular the CAN Gateway:
    Address 19: CAN Gateway Labels: 3C0-907-530.lbl
    Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
    Component: Gateway 007 0040
    Revision: 00007000 Serial number: 0700C06606030D
    Coding: 3DFDAC04C02003
    Shop #: WSC 05311 000 00000
    2 Faults Found:
    01333 - Door Control Module; Rear Left (J388)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 150
    Mileage: 149354 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 16:24:38
    01044 - Control Module Incorrectly Coded
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 1
    Faulhs agot Frequency: 1
    Reset counter: 154
    Mileage: 149628 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 15:35:04
    Not surprising really as I changed the RCD 300 for an RCD 510 a few months ago.
    Control module incorrectly coded must mean it can't communicate with the radio?
    When I re-programme the new gateway, is it this that I save from the old gateway and re-code into the new gateway?
    thanks
  1. How To Fitting a Dension Gateway (100) to an A4 B6 / B7
    By toff in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-05-2011, 10:08 PM
  2. Replies: 1
    Last Post: 20-12-2009, 03:18 AM
  3. Please Help Powertrain data bus probs on 02 polo
    By mobitune in forum Polo - Derby - Lupo - Fox
    Last Post: 09-10-2009, 09:46 PM
  4. How To Retrofit Installation of AMI in 2003 A8 (D3/4E)
    By NeilA8 in forum A8 - S8 - V8
    Last Post: 03-09-2009, 06:12 PM
  5. The Who to rock International Bus Meeting
    Last Post: 07-09-2007, 07:22 AM
