Thread: Passat B6 2.0tdi Sport 2005, glowplug issues
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
  1. Passat B6 2.0tdi Sport 2005, glowplug issues
    Jun 2010
    ireland
    Can someone shed some light on these issues!!!
    1.Emissions workshop warning:
    I have changed all 4 glowplugs due to code reader stated 2 glowplugs faulty.
    1 week later its back again, lived with it but had the codes read recently and all 4 showing faulty!!!! going to changed them again next week sometime but is their any suggestions!!! have been advised that the BKP engine glowplug wiring loom tends to rub on the head and short them, causing these to blow, but really all 4?????
    2. Engine fault warning:
    Now have this coming on, only after starting the car when the engine is warm, doesn't come on when cold!!! if it comes on and i key the car on and off quickly so the engine doesn't cut it stays off!!!!!
    This is the only issue i have with this car, its a shame as its a great car and i don't want to get rid of it because its to tempermental!!!
    Help please
  2. Re: Passat B6 2.0tdi Sport 2005, glowplug issues
    Norfolk
    What code reader did you use and what codes did you get. What glowplugs did you fit. Only VW genuine ones or NGK are correct, you may have fitted the wrong ones, it does happen.
  3. Re: Passat B6 2.0tdi Sport 2005, glowplug issues
    Jun 2010
    ireland
    Thanks for your post, the codes were read by a VW, Audi specialist!!! so couldn't tell you!!! i installed 4 x Beru glowplugs given to me by a GSF dealer from my vin number but if thats right then NGK i'll need to get, any idea of the part numbers for the NGK etc!! is the YE14 right
    Any idea on the second issue or could it be because all 4 showing gone!!!
    thanks for your help!!!
  4. Re: Passat B6 2.0tdi Sport 2005, glowplug issues
    Norfolk
    You used the wrong glowplugs. I hope you haven't blown the glowplug control module. Niether Bosch or Beru make glowplugs for the passat B6. As you have been running 4.5V glowplugs on a 7V system you may have just damaged the plugs.
    NGK part No.s
    BMP, BVD = CZ104
    BKP, BMA, BMR, BWV, BVE, BUZ = CZ304
    BLS, BXE, BKC = Y-607AS
  5. Re: Passat B6 2.0tdi Sport 2005, glowplug issues
    Jun 2010
    ireland
    Great, will get some this week, NGK all the way!!! i have searched the net for glowplugs for my BKP engine but they all come back as 4.4v with the NGK YE14!!!! just need to confirm the BKP 103kW 2.0 tdi engine is definately 7v 10mm glowplugs!!!
    http://www.sparkplugs.co.uk/pages/pr.../cross-ref.asp
    this shows beru as spec for VW N10579802!!! am i looking at the right info etc.... thanks again
  6. Re: Passat B6 2.0tdi Sport 2005, glowplug issues
    Norfolk
    If you do a search for NGK you can download their catalogue. If you check Beru website you will see they don't make glowplugs for a passat B6. Make sure you search PASSAT B6, not just engine code. When the same engine is fitted in different VW models, they use different glowplugs. So a 2.0 tdi can have different glowplugs in a golf compared to a passat.
  7. Re: Passat B6 2.0tdi Sport 2005, glowplug issues
    Jun 2010
    ireland
    Thanks Martin You've been a great Help, will let you know how it works out, have a great Day!!!!!!!
  8. Re: Passat B6 2.0tdi Sport 2005, glowplug issues
    Jun 2010
    ireland
    Well an update to this post, i have now installed 4 x CZ304 NGK 7v glowplugs but my warnings remain, is there a way to reset the fault codes without a VAG reader, also as the warnings are still on does that mean my control module is blown???
    Any takers, please help
  9. Re: Passat B6 2.0tdi Sport 2005, glowplug issues
    Norfolk
    VW warning codes don't reset. You need VCDS or a dealer to reset them. With luck that's all you need to do.
  10. Re: Passat B6 2.0tdi Sport 2005, glowplug issues
    Jun 2010
    ireland
    Martin,
    Thanks fella, when i replaced the glowplugs with the wrong ones last-time the warning reset itself with a number of key on/offs.
    Didn't work this time!!! also where is the control module situated, i have ordered one to be safe it arrives tomorrow.
    Many thanks
    Darren
  1. B6 Passat or Saab 93
    By OzzyDan in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-01-2010, 04:21 PM
  2. Question Will 2004 audi A4 17" sport wheels fit on my 2005 passat tdi?
    By woody_lee in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-09-2009, 08:38 PM
  3. Replies: 0
    Last Post: 15-01-2008, 09:05 PM
  4. Some advice please needed on wheel offsets - ET37 vs ET35
    By Staz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-12-2007, 05:48 PM
