The main supply fuses are F1 & F2 on the engine bay fusebox. The ignition is supplied via F2 in the dash fusebox but I doubt you're diag tool would have comms with the ECU if that was blown.
Printable View
Just want to say a massive thankyou for your help and advice ,coding accepted and fault found ,fuse no1 engine bay ! Showing voltage with tester but when removed was heavily corroded ,new fuse wd40 spray and abs fired up back to life once again thanks for all your time and help
Hi All
Vehicle: 2006 Golf MKV TDI 2.0 GT
In the past week my transaction control light appearing on the dash during a normal drive. I tried to turn it off using the ESP button but this makes no difference and traction control stays off.
I got my friend to do a code read on his scanner and the G201 – brake pressure sensor failure and was advised by him that it is a common fault for the ECU on the unit to fail and would edit need to have it repaired or replaced. So I decided to get it replaced with a second hand one from a breakers.
Today I have had the ABS replaced and would have thought I just need to clear the code however clearing the code did not do anything and the ABS and transition control light still appear. When I read the ABS Module it says Control Module Incorrectly Coded, codes below:
5 Faults Found:
01486 - System Function Test Activated
000 - -01435 - Brake Pressure Sensor 1 (G201)
005 - No or Incorrect Basic Setting / Adaptation
00778 - Steering Angle Sensor (G85)
01423 - Lateral Acceleration Sensor (G200)
01044 - Control Module Incorrectly Coded
003 - Mechanical Failure
I have read up and realised in order to reprogram the ABS unit I require the long code from the original ABS unit and logging and soft code to programme the ABS? my understanding of this process is not very good and would appreciate if there is anyone in the East Midlands area who can program this for me as I am willing to travel.
Cheers.
Please, I need the login and the code for my 2006 passat 2.0T vehicle ABS Module. Please find vehicle label here; http://imageshack.com/a/img924/3848/92kTFp.jpg and advice.
Please help me with ABS pump long coding.
Lost coding- 00000000000000000
all detail car.
vin VSSZZZ5FZGR201691
typ: 5F8 2NV
leon st 1.6cr
style 5t81 dk5 5g
MOTOR : CXXB
OPTIONS:
X2B B0N DK5 G0C 1AT 8GG
J0V C7Q H6L V1P 1G8 1NL
I8E 8ZH 8RM 8IT 8WH 8TB
-- --- 2ZQ
2B2 --- 5SJ 5RQ QG1
7MM G01
login?
Coding??
preview coding :
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 614 517 AF HW: 5Q0 614 517 AF
Component: ESC H62 0398
Revision: 00000000 Serial number: 51746000000200
Coding: 19EE8A922420096D407D060941C42498512490026082247200 410070C00202
Shop #: WSC 00049 770 00104
ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
ROD: EV_Brake1UDSContiMK100ESP_034_SK37.rod
Hi, I'm having the same issue with the ABS unit on my VW T5 MULTIVAN, i have found a replacement with the same part numbers but cannot access the old unit to find out the original coding.
Can anyone help by working out what my login & coding details from the following vehicle info ?
WV2ZZZ7HZ4H056706
7HM C11
Multivan Come. KR
128kw TDISG6
AXE GWB
LA5W 0000 0000 EJ
X10 B0A CS3 G0K H2N J1U MS0
1AT 1G2 2PW 1NL 5RQ 5SL T86
3S4 3U4 QG1 8UT 8GV 8L6
1BA 0GE
0E1 4UF 4X3 4R1 4K3 N0H 5MA
9VK 2JG E0A 2V1 0JE 0YB
1D2 A8E 8EL U5A 1N1 3L3 4A3 8N1
Any help would be greatly appreciated ?
WV2ZZZ7HZ4H056706
7HM C11
Multivan Come. KR
128kw TDISG6
AXE GWB
LA5W 0000 0000 EJ
1BA 0GE
Well just to close out this thread on my part, I received the replacement ABS pump and controller, disconnected the battery installed the unit and the existing coding was accepted by the main ecu. Reinstated all hydraulics, used vcds to reset all stored fault codes, reset steering angle sensor and now no more lights on dash and running sweet! Result. Thanks for everyone’s assistance.
:1zhelp:Hi all:aargh4: had a new abs pump fitted.
now left with constant beeping. please has anybody got the code before i drive off a cliff?
i need the long code number
vin number : wvwzzz1K z 9W118803
abs : 1K0614517BD
vw golf bluemotion 1.9 tdi mk5..
Your supposed to record the long coding values before removing the original pump assembly, then enter them into the replacement.
If you still have the original unit you can plug it into the harness and read the coding. Failing that you will need to either visit your VW dealer
or contact Ross-Tech to see if they can help, assuming your a registered VCDS user.
