Hi.
months that I'm looking for a solution to have music with my iPhone on the MMI 3G Basic (A6 facelift 2009).
according to several people it's impossible !!
there is no solution?
my audi A6 is equipped with the phone
thank you
Printable View
Hi.
thank you
Did you try Parrot?
I have a Tune2air and works fine but i do have a 3G high with an AMI
WMA3000 - PRODUCT - ViseeO Worldwide Official Site
bought then try, this one does not work with the MMI 3G Basic, returned to the store.
https://img4.hostingpics.net/thumbs/mini_7950646611.jpg
this one, the seller says that it is incompatible with the MMI 3G Basic!
https://img4.hostingpics.net/thumbs/mini_6842567722.jpg
what is parrot ? , there is another solution? interface? ..
I have a 2009 facelift with the 3G low. I brought the tune2air off eBay. It’s litrally a simple cable you plug into the back of the head unit. You have to access the green menu and make sure you select AMI on.
do we have the same car ? (my car 11/2009)
https://img4.hostingpics.net/pics/346818762.jpg
MMI with 2 SD and a CD player in the glove box, but no female jack
for that ?
is this object ?
https://img4.hostingpics.net/thumbs/mini_8696669833.jpg
Yes I have the same unit on the left with the SD card readers. I haven’t got the CD changer. I didn’t have the socket for the AMI to plug in the tune2air. You’ll need to by the wiring kit that includes the socket you need. You have to remove the head unit and plug the cables into the back and then activate AMI on your MMI.
Here’s a link to the cables
https://rover.ebay.com/rover/0/0/0?m...2F271532028913
You need to buy the tune2air too obviously.
Just make sure your into your music as it’s quite expensive for all the parts but it works well!
If you have ami then you need tune2air if not then dension500bt is your best option
Sent from my SM-G950F using Tapatalk
unbelievable ! you save my life!
traders who are specialists do not know, and you find the solution! weeks and months that I seek the solution by interoprogating the sellers ..
I do not know how to thank you.
I will look for a serious seller and buy the necessary material., thanks.
my english is limited, that's what I need? (MMI 3G Low)
Audi MMI 3G AMI + iPod iPhone 5 Leads Adpater - Lightning - 5N0035554G - Retrofit -
other question, is it possible to have an entry aux. R.C.A. ?
Once you’ve installed the AMI socket you can just buy different types of leads you need.
Aux leads like this.
https://rover.ebay.com/rover/0/0/0?m...2F152095057541
