AIRBAG FAULT warning light and VAGCOM Fault Code 00588
:(AIRBAG FAULT warning light and VAGCOM Fault Code 00588
My MFD / dashboard instrument cluster shows AIRBAG FAULT whilst VAGCOM reports the following:
Address 15: Airbags
Controller: 6Q0 909 605 B
Component: 05 AIRBAG VW5 0003
Coding: 12341
Shop #: WSC 00028
1 Fault Found:
00588 - Airbag Igniter: Driver Side (N95)
32-10 - Resistance too High - Intermittent
Does this suggest simply (hopefully) a poor wiring connection to any of (i) the airbag within the steering (ii) the crash sensor under the driver's seat cross member or (iii) the airbag control unit J234 by the bulkhead on the right of the accelerator.
Or maybe it suggests a faulty crash sensor or airbag controller unit.
Or maybe it suggests that I should GSI (get Someone In) because it is none of the above and it is very complicated?
