Instructions for Getting iPhone Working with High Telephone and data Services
Following a 20 page thread on the A7 forum, it seemed right to move across to the A6, the home of most people who have the problem.
UPDATE: The rest of this post must now be read with a pinch of salt. Everything works fine until you lose signal, or sometimes just go from 3G to 2G, then everything goes to pot. The developer is now saying that his software may not work with Audis and Porsches. Watch this space, but don't invest much time or effort for the moment.
Following a great deal of effort by gbjk I can now report how to get an iPhone working fully and properly with the High Telephone Preparation with Data Services.
You can read about this here. Note that the iPhone 4S is not yet supported, only the 3G, 3GS and 4. You might find it easier to follow the instructions on that web-page, but those below are a bit more Audi specific. Probably best to read both before you do anything.
This is a recipe, you must follow every step, though you need not understand it.
- Using your current "normal" Bluetooth connection, export your phonebook to an SD card.
- For the time being, the operating system on your iPhone should be 5.0.1. To check this, go to Settings/General/About. There probably will be a solution for 5.1 along shortly, but not yet.
- Log into Windows as Administrator or with administrator rights
- Plug your iPhone into the PC (this may all work on a Mac, I don't know.)
- On the Windows PC, Go to http://blog.iphone-dev.org/ and, about two pages down find the link redsn0w 0.9.10b6 for Windows, download that file.
- Run it in Windows, choose the Jailbreak button.
- You will see some alarmingly complex button presses to be done on the two buttons on the iPhone. Read them through so that you are ready to follow them (it's so many seconds on Home, then so many seconds on power, or whatever). You will have no chance of doing it correctly unless you are prepared.
- Install Cydia Only
- Disconnect the iPhone from the PC, you are now done with the PC, the rest is on the phone.
- Make sure that you are online (WiFi or 3G, doesn't matter.)
- Open the new Cydia App - Choose Developer
- Click on Manage/Sources/Edit/Add
- Enter http://www.jens-david-consulting.com/repo
- Choose the trial licence - if all goes well, you will need to buy the full licence within 10 days.
- Return to Cydia.
- Reboot the iPhone using the full reboot (ie hold down both buttons until you get the Apple symbol.)
- Go into Settings/General and switch Bluetooth off. (I am not sure if this is necessary, but it does no harm.)
- Back into main Settings you should find two new icons on the main page, BTStack and RSAP Server. On mine they are between the built in Apps, such as Safari and Store, and the bought Apps.
- Go into BTStack and switch on BTStack (the other option allows you to revert to normal vanilla Bluetooth.)
- Go into RSAP and set everything on except Fix reopen and Record Log. For a full explanation of all the settings go here. Look for Settings and Compatibility. As I get more familiar with the settings I may change this advice, but my reading of the instructions is that everything switched on except Fix reopen maximises the chances of success and stability. There seems to be a sense on the support forum that settings may depend on provider and maybe country. Give me time on this one.
- Get into car and switch on ignition. It should search for your phone, but, if it doesn't, use the MMI to search for a Bluetooth phone.
- When you select your phone it should have a Carphone profile - select that.
- It will give you a 16 digit number to type in, but in every case so far that we have seen it's actually each of four numbers repeated four times, so it's not too bad.
- You should now have a fully functioning phone service, with data, on your UMTS. Check that you have by making a call, going into Google Maps, checking the WiFi works etc.
- However, you will find that there is no phone directory. This is a bummer, so...
- Use the MMI to re-import your favourite 100 entries from your SD card in step (1) back to your phone.
You should now have a fully functioning, all singing, all dancing rSAP iPhone, except if you use the WiFi, which kills the telephone service, that is from any device, not just your iPhone. I will continue to experiment with this and advise.
Good luck, buddies!
Re: Instructions for Getting iPhone Working with High Telephone and data Services
Thanks to you both for all the hardwork and the simple step by step instructions.
I'm sure that this may well end being a "sticky" thread.
Please note that most of the thanks should go to gbjk, I am really only the secretary providing notes from the meeting!
Please note that I have changed my advice.
I now advise having Fix reopen switched off in SAPServer and not to use the WiFi from any device in the car.
I will continue to diagnose, but it's a long, painful process as sometimes a wrong setting will not manifest as a failure until you lose signal, and in the London area, total signal losses are few and far between.
