I'm in Bridport, Dorset. Have full VCDS Hex CAN. Let me know if I can help
Andy
Printable View
Andy
Hi Andy,
Are you still active here & have VCDS still?
~Dan
Hi Dan,
yes im still here and I've got the VCDS
cheers
Hi Andy - I have just moved to Bridport and own a SQ5 -I won't to add a sound booster (kufatec) but need 'drive select' which I don't have - are you able to enable it for me pls via vcds many thank Steve
Hi Steve - what year is your SQ5 - should be able to do it just need to check the instructions I have will cover your year
cheers
Andy
Hi Andy - it's 2015 only just picked it up cheers steve
Do you still have VCDS and possibly available to recode a radio on a VW passat 2011?
I have the instructions, its simply to enable the DAB digital reciever. I have the hardware just the software says no currently.
Obviously I'd repay with bear tokens or something similar for your time.
Regards,
John
Hi Andy,
Are you still in Bridport ? I have recently started servicing my car myself after doing a course at Yeovil college. It's a 2009 A4 Allroad 2.0l TDI. I can reset the oil change counter but not the inspection service. Is that something you could do, I'm not an expert on the technical side of things.
Thanks,
Ollie
Hi Ollie,
Sorry for the delay in replying, I have a new email so i've only just seen this. Yes I'm still in Bridport if I can help at all
cheers
