Alhambra non start. 2.0 petrol.
Hi all. I've got an issue with a 1999 2.0 petrol Alhambra. It was started and moved the other day, stopped for 5 minutes and when I tried to start it next it just turns over & doesn't fire up. Code reader shows no faults!! Have replaced crank sensor just in case, bridged terminals on relay 30, but fuel pump does prime. HELP?!?!?!
Thanks.
Re: Alhambra non start. 2.0 petrol.
The most common problem with the ADY engine is the ignition coil, replace it with a top quality unit, avoid ying tong no brand stuff.
Thanks Crasher. All sorted. :beerchug:
I would keep a spare in the car, they are very unreliable.
