Re: Wet Carpet Driver’s Side
Coolant level dropping? If you have what appears to be the original header tank and it appears to be at the max level, double check by looking inside as many get stained on the inside giving the impression of it being at the correct level. If coolant is dropping could be the heater matrix otherwise I would suspect the bulkhead drain tube(s) are blocked.
Thanks Mitch, no problems with the coolant and it would smell of anti-freeze anyway. The bulkhead drains are clear, at least now, will have to pull the carpet up I guess and see if there is anything obvious.....
Could it be the pollen filter blocked?
