Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
Tell me if Im wrong here but I didnt think the audi car quattro set ups had a separate transfer box like the larger 4x4s? I thought it was all built up into the drivers side of the auto gearbox?
Quote:
Originally Posted by
jubbly
Iirc only 26 quid per litre from land rover dealers for the real stuff and as it only needs doing every 100 odd K Im not sure the saving is worth the potential risk?
I didn’t believe the Audi had a transfer box, isn’t that what gives hi and low range on land rovers?
jubbly
Yep land rover have had tfer boxes since 1948, Im not sure what the latest crop has ie the evoque/discovery sport and the d5.
Dear colleagues,
I'm preparing oil change in my tiptronic it is 6HP19A. I read posts here but I'm confused for which oil I should use. I bought 6HP Ravenol before I read this post (I know my fault). Can I use this oil? Did somebody try it? If I use this oil can I make SW update of the gearbox (if it will be available)?
I have problem with the gearbox only if it is cold and I'm slowing down with engine (without brake) the RPM oscillating. I don't know if it is oil problem or SW problem but when the gearbox warming up the problem is gone.
Thank you for any help.
Martin
vajkooo
Dear colleagues,
Martin
It wont . Oil or sw update wont help. Tourque konverter is failing
Sent from my SM-G950F using Tapatalk
What??[emoji23][emoji23][emoji23][emoji23]
New converter , £1k minimum
I read some threads on other forums and there was sw update which solve this problem with oscilating RPM with cold gearbox.
Tried somebody oil ZF Lifeguard 6 with new sw update?
niedzial1983
Dr Tranny 12 quid and no I dont mean will young!
