Service Reset now mileometer shows "trA612"
Hi all,
Car is a 2008 B6 Passat Estate with 1.9TDi BXE Engine with approx 131K miles.
Not too sure if the VDCS forum is the correct place for this. If not, please can a Mod move it - thanks.
I ran a scan - nothing particularly exciting found - Air con pressure low.
Cleared all the codes.
The Service Reminder kept coming up although she was fully serviced a few weeks ago. I guess the garage didn't reset it properly so I did what I though was a straightforward Service Reset
All appeared to go OK then I saw the "trA612" where the mileage normally is.
The third character looks like an A maybe R? definitely not an 8.
Erm....
What have I gone into by mistake and/or messed up?
I'll post some logs if you let me know which ones might help.
Thanks in advance.
Andy.
Re: Service Reset now mileometer shows "trA612"
Never seen that, very odd. Do a scan of the SRI data and post it.
OK.
Here goes:
All a bit weird.
The time only moved on when the car was running and the date was locked on 10-09-19.
Anyway, did another Service Reset and it seems to have sorted itself out.
Mileometer back to showing total mileage and the clock showing the correct time, all the time.
VCDS Release 19.6.1: SRI Reset
Control Module Part Number: 3C0 920 971 E Labels: 3C0-920-xxx-17.lbl
Component:KOMBIINSTRUMENT VD1 1216, Coding:0007405
Operation: Please select an operation
Channel Description Unit Current val. New val.
02 Service Reminder Status 1 ---
40 Distance since Service miles x100 99 ---
41 Time since Service Days 310 ---
42 Minimum Distance to Service --- --- ---
43 Maximum Distance to Service --- --- ---
44 Maximum Time to Service --- --- ---
45 Oil Quality 1 ---
47 Soot Quantity km x100 256 ---
48 Thermal Load km x100 99 ---
49 Minimum Time to Service --- --- ---
50 Basic Distance Value for Oil Change miles x100 93 ---
51 Basic Time Value for Oil Change Days 372 ---
02 Service Reminder Status 0 ---
40 Distance since Service miles x100 0 ---
41 Time since Service Days 0 ---
47 Soot Quantity km x100 1 ---
48 Thermal Load km x100 0 ---
Address 17: Instruments (3C0 920 971 E)
16:25:45
16:26 Time
213470 km Mileage
60.0 l Fuel Level (G)
91 ohms Fuel Level Sender (G)
26.0°C Ambient Temperature
OK Oil Level
12.30 V Voltage (Terminal 30)
-- Service Exceeding (Distance)
-- Service Exceeding (Time)
150 Remaining to Service (Distance)
372 Remaining to Service (Time)
Hope this means something sensible to those that know!
Cheers.
Andy.
It is on variable servicing so the reset figures look confusing, the stabilise after a few weeks and miles. I reset them all to fixed annual 9300 mile now to protect the engine.
Cheers mate.
That's what I wanted it on - don't like the variable thing.
Thanks.
Andy.
