Engine strip inspect and possible rebuild.
So I recently brought a 1990 1.8 8v mk 2 golf gti. Which had a blown head gasket and a few other electrical issues. They've all been sorted. But now the engine is miss firing and down on compression on cylinder 4. And also now sounds like a small end has gone. Time to tear it down and inspect.
Re: Engine strip inspect and possible rebuild.
Post pics as you go, don't want a broken phone to spoil the thread.....
Nope. Going to get the old digital camera out this time and make sure it's uploaded daily. Well when I aventualy get it in a parking space so I can get the engine out. Got a stand coming from a friend so all should be hopefully good. Anyone no any good places for quality parts.
Finally got round to taking the sump off. And I have decided I need a new set of big end bearings on no2 cylinder. All other bearings have no play just this one.
Can you see what's wrong with this PAIR of bearings.
http://images.tapatalk-cdn.com/15/04...3bc98a0d9b.jpg
Did you remove the engine? It's not really necessary on that engine. I can't see the face of the bearing what's wrong with it?
Oh dear. I'd replace them all and take a close look at the oil pump
I checked the pump a while ago and was getting really good pressure so don't thing that's at fault. Got another bottom end I'm collecting on Saturday if I can find some transport.
So picked up a short block on Saturday. And have stripped it down for parts. It's supprisingly in really good nick and the internals look like it's come from a low millage engine by the lack of wear and marks. Not bad for £10 :)
I do have a slight issue with the cam followers. I found one of mine was bust so brought another. All of them has a little bit of a spring in them then go hard. But the new one is just solid.
Going to pick up a new oil pump as a matter of course now and run an air line through all oil ways.
A short motor for a tenner! now that's cheap motoring nice find
