Re: Q7 4M Homelink RetroFit
Good thinking about not to install in the rear bumper! This is the reason (being in the bumper) I thought to order with the car (Ł200 option in Hungary) and not to try to retrofit.
Love it Andy! Do you actually have a garage door to open or is it the challenge [emoji6]
Great work mate. May do the same when you finish.
Quote:
Originally Posted by
srbsq7
Haha. Not yet but I'm moving house in March and I will then so preparing now. Lol
Plus a bit of me likes the challenge.
anemeth
Thanks Anemeth.
Do you have vcds or odbeleven but any chance? I need an adaption map of module 5f to see what needs changing to enable it in the mmi.
No worries if not, I'll just trial and error it! [emoji2]
Andy,
My car will be delivered mid March only, but ODIS 3.0.3 already installed on my Toughbook CF-19. I will see how it will go with that first before other hardware/software.
If you have not figured it out by mid March, I can look at my car for you of course.
Update.
Now all working after figuring out all the necessary coding.
Had to Wire into the necessary communication lines and get power etc sorted Then it was a matter of getting fuse connector and fuse added to the luggage compartment fuse block and so forth.
Then coding figured and voila
https://uploads.tapatalk-cdn.com/201...5d73e6b606.jpg
https://uploads.tapatalk-cdn.com/201...7d2881431e.jpg
https://uploads.tapatalk-cdn.com/201...cb6902c110.jpg
https://uploads.tapatalk-cdn.com/201...b3077b0e7d.jpg
https://uploads.tapatalk-cdn.com/201...2ded97ae11.jpg
Now I just need my garage opener installed [emoji2]
However I have another system which can control lights etc en route so when it's arrived I'll use that to test with and do a quick video.
Andy
andyhud007
Magnificent effort Andy, think u need to seriously need to start thinking about setting up a retrofit shop!
