Hi all
Does anyone know how to release the lower oil return pipe to free the turbo assembly please?
It's loose, but cant seem to figure out the lat bit!
Printable View
Hi all
They are always tight and take some force to lift up, often two people in the engine bay lifting up.
Cool, thanks. We got it out yesterday... Going to be tricky getting it back in? I assume its a new O ring and firm push... there is a 10mm bolt near the top of the pipe which I guess keeps it in place but doesn't necessarily pull the pipe into the turbo
New O ring and some lubricant. We use a silicone grease that comes in Powerflex bush kits but you don’t want any in the oil, if you were in a corner then a light wipe of the O ring and the top of the opening with washing up liquid should not hurt but it does contain salt.
Lovely, thanks. It went in ok in the end - with a nice positive ' snick' !
Sadly i still have a limp mode issue, see other thread :-(
I'm just about to remove the turbo on mine due to a failed actuator.
So it the lower oil return pipe push fit?
So hopefully no need to access from the wheel arch and remove a totally inaccessible bolt? Hope so!
Thanks.
Which car and engine?
Sorry, 2005 A6 3.0tdi Quattro.
Yes it is pushed in but can take some force to lift up, often you end up climbing in the bay to get the angle without pulling your back.
Thanks Crasher that's what I wanted to hear, I'll be better at wrestling from above than contorting from below unnecessarily.
